19 minutes ago, VPI said:
Everything seems to be working and already dramatically better than the shitty Jet it replaced.
So quiet…
So far I’ve really enjoyed my Voyager, at some point I want to put a good keyless chuck in.
  • Replies 2k
  • Views 405.8k
  • Finished the mini bedroom audio rack with Rubio Monocoat and glued it up. Now in place and making me happy. Also shown are the Bendy Head headphone stand from Peter @Iron_Dreamer and coasters from Nat
  • I had previously talked about the bookstore I'm working on. It's almost open for business and I thought I'd show a few of the projects. The shelves are all solid Cyprus. The boardwalk in the back is R
  • Change of Command is this week, which means I get my 4th boss in three years (FML) so I decided I'd fabricobble the command gift.  The outgoing skipper is a Navy diver who has a penchant for clapping
Even Dr. Wood can make a mistake.
Sorry about your larger holes Doug.
Tossed together this simple pocket hole machine. Just waiting on the router bit to show up to give it a try.
kinky tv land GIF by #Impastor
Is that the bit that you're going to use in your pocket hole? I really don't like that clamp placement, but I guess it depends on which way you face when you sit on that thing. :postjack:
It’s making the pocket just like a Castle machine would, clamp is just there to hold the material while the pocket is cut.  Offset to make the alignment mark easy to see. Operated from the side the picture was taken.
Edited by naamanf
Cool, but why does it have a toilet paper holder?
I got a bidet and no longer need it in the bathroom.
Oh, that's the lever to raise the router bit. Got it. Sweet indeed!
When will mine be ready?
It really is a great idea!
I can send you a flat pack of the parts, saved the ping pong files.
Hell yeah, I'll buy it!
Edited by swt61
Did you really not get my "joke"? 🥺
See, if that thing were a fuck machine and you sat on it facing the clamp then the clamp would crush your junk. While being penetrated. Get it? 😣
Cool idea for pocket holes tho, bro.
What happens in the shop stays in the shop!
Can you make a venm diagram?
It all sounds terribly and I’m considering burning my phone to hopefully forget the visual of a spiral btt attacking my taint. But at least it will be clean, thank you bidet.
Once again, proof that twinks are much tougher than your average straight male.
Has anyone used either the Omniwall or Wall Control products in your shops?
Thinking of going with one of those behind the drill press table instead of French cleats.
For the short term at least, I threw up some French cleats and threw together a holder for the Clamp Squares and the Infinity Tools Woodworkers First Aid kit.
Nice!
tested out my new pocket hole machine. It makes holes.
Those are some serious holes. My Castle and Foreman both put the screws well inside the holes, yours seems to get more of the meat of the board involved. How does yours adjust for different screw lengths?
51 minutes ago, naamanf said:
Nice!
That is very cool!
I'll do the Dad jokes here!
Mocking up a MCM step stool for the guest bathroom for the cousins’ kids after building another french wall tool holder this afternoon.
Thanks. I would have preferred to do something bigger but most everything left out in my shop develops rust so I just put the cheap stuff out.
Are you running a dehumidifier, Jeff?  If not, might be worth trying to see if it helps even if it is unlikely to cure the issue.  I know my shop, without the DH running, goes through huge swings of humidity.   Given the heat/coldsink that most tools represent they attract condensation like crazy which is likely the cause of some of your rust problems.
