I wasn't sure where to put this but this is a PS Audio Perfect Wave DAC so might as well be here.  Found this thing dirt cheap in Japan, clearly modded and thought... why not.  Might be fun... but boy ohh boy this is utter insanity.  It was showed as up and running by the seller so I needed to go in and see how I could change the voltage on it.  I didn't snap any pics of it when it arrived but here is one once the felt strips had been pulled off... yeah felt strips:
That's the bottom so it was covered in these strips.  Now I dug deeper:
So there was this layer of aluminum tape that was painted and sealed on the edges with this rather coarse paint, almost like the stuff you'd use to make chalkboard finish.  Then underneath there was come copper tape and the adhesive on this was nasty shit.  I attacked it with IPA, acetone and adhesive cleaner (mineral spirit) and now it is mostly off the outside.  I had to use plastic scrapers to get it off and machine polish the top over (due to all the small scratches from cleaning it) but it looks okey.  Now I had yet to open it as the top cover is pushed up through the bottom and you need 4-40# screws to do that... something that is impossible to get here.  Two weeks ago I found myself in Chicago on my annual visit and Kevin hooked me up with some that did the trick and here is what I found:
Now one starts to wonder about sanity and what hose clamps have to do with audio quality but yeah... this is the most insane shit I've ever seen.
This is the top cover and here is this paint the whole unit is covered in.  No idea what it is but it is rather inert and I had to scrape it off the top and bottom panels.
Seriously... hose clamps.  This is so retarded it isn't even funny.  A few things to note, see those felt strips, same as were on the outside of the unit and those ferrite beads and rods are all over it.
Now to switch things up a bit, here is what looks like a brillo pad around the transformer.  It's not steel wool and it was around it all.
Here is another shot of the steel what ever and those rods glued to the bottom of the chassis.  Also see the silver bits attached to the cables... yeah more on that later.
Here it is with the cotton? pulled out of it showing what I've stepped into.  How many hours did this take?
Our lovely hose clamps again but look at that transformer.  It is wound in aluminum tape, then the felt, then some rod, then more aluminum tape...  Then those rods on the bottom of the chassis...
I've started to peel stuff off and it is like an onion
Main transformer and in the bottom right hand corner are all the cable ties holding those silver bits on the cables.  Yeah, that is about 10 layers of aluminum plus some small ferrites and rods...  Why?  Fuck knows...
Main transformer peeking through the madness as I need to get to it and read its markings to covert it to 230V.  I'll have to do some more cleaning but this was just too good not to post...
  • Haha 3
  • Confused 3
This is something special as none of this actually does anything.  Ferrites work at certain frequencies but the wire has to pass through it... not just have it vaguely in the same area.  Lumps of aluminum tape and felt on the cables... yeah nothing at all.  It seems like a bad DIY project but I have a sneaking suspicion that somebody is doing this as a service and charging a boatload for it.
