October 12Oct 12 comment_972485 Based on the research that I was able to do it is essentially a known forum bug. I can't find a way to shut them off or to even assign a generic (very small) image to each of them to kill the void caused by the lack of image. If someone else finds a link that explains how it can be changed/fixed shoot it my way and I'll see what I can do. Report
October 12Oct 12 comment_972486 I haven’t used this technique in many years, but any chance you can apply CSS tags to them and either position off-screen or display off? Ex..ipsType_richText img { position: absolute; left: -9999px;}or.ipsType_richText img { display: none !important;} https://chatgpt.com/share/6acce6f6-9554-83e8-bf4a-f5dc88363f26 Report
October 14Oct 14 comment_972523 I asked my local AI the same question , and suggested the stylus plugin and this script for the home page@-moz-document url("https://www.head-case.org/forums/"), url("https://www.head-case.org/forums") { /* * HEAD-CASE — COMPACT FORUM HOMEPAGE * * Trial stylesheet: selectors are not verified against * Head-Case's live HTML. * * Applies only to the two homepage URLs above. */ /* 1. Replace forum grids with a single-column list. Only target lists containing forum-category links. */ :is(.ipsData, .ipsDataList):has(a[href*="/forums/forum/"]) { display: flex !important; flex-direction: column !important; gap: 6px !important; } /* 2. Remove fixed heights and excessive row spacing. */ :is(.ipsData, .ipsDataList):has(a[href*="/forums/forum/"]) > :is(.ipsData__item, .ipsDataItem) { width: 100% !important; max-width: none !important; min-height: 0 !important; height: auto !important; margin-block: 0 !important; padding: 10px 12px !important; box-sizing: border-box !important; } /* 3. Hide decorative forum cover-image containers. Do not hide all images: avatars and posted pictures should remain untouched. */ :is(.ipsData__item, .ipsDataItem) :is(.ipsData__image, .ipsDataItem_image) { display: none !important; } /* 4. Let the text area use the space left by the image. */ :is(.ipsData__item, .ipsDataItem) :is(.ipsData__main, .ipsDataItem_main) { flex: 1 1 auto !important; min-width: 0 !important; width: auto !important; min-height: 0 !important; padding-block: 0 !important; } /* 5. Clear any reserved image-column layout. Keep information arranged in a simple vertical stack. */ .ipsData__item:has(a[href*="/forums/forum/"]) { display: flex !important; flex-direction: column !important; gap: 4px !important; aspect-ratio: auto !important; } /* 6. Keep forum titles readable without oversized headings. */ :is(.ipsData__item, .ipsDataItem) :is(.ipsData__title, .ipsDataItem_title) { font-size: 17px !important; line-height: 1.35 !important; margin-block: 0 4px !important; } /* 7. Tighten descriptions without shrinking their text. */ :is(.ipsData__item, .ipsDataItem) :is(.ipsData__desc, .ipsDataItem_meta) { line-height: 1.45 !important; margin-block: 2px !important; } /* 8. Slightly smaller padding on phones. */ @media (max-width: 700px) { :is(.ipsData, .ipsDataList):has(a[href*="/forums/forum/"]) > :is(.ipsData__item, .ipsDataItem) { padding: 8px 10px !important; } }}Before:After:HTML Jockeys may be able to do a better job, but the advantage is its client side, so your choice, fairly easy to implement, and reversibleAdd the Stylus plugin / extension to your browserGo to the Head Case forum page - or whatever page is annoying youClick on the Stylus extension icon in your toolbar(click on the + to) Add a Style for the Website / URL in QuestionPaste the above code inSave re visit / refresh the siteSee the before and after by noting that the Stylus icon has 1 rule applied for the page, and by clicking on it you can toggle it on or off More design oriented people could have a deeper, better conversation with their AI of choice, but not bad for a first vibe coded attempt? Report
October 14Oct 14 comment_972524 It does look better without the image placeholders. I've gotten used to looking at them, but there must be a way to get rid of them permanently, particularly for the mobile users. Report
October 14Oct 14 comment_972527 My typical use case is just click unread content, and take it from there, but, that does miss Today's Birthday's, and who's Online, so there is that. Report
