I want a seperate volume dial for the Aleph, at the minute its run off the second set of pre-outs on the NAD. Means I have to fanny around with the switchbox and I'd like rid of that irritation. Cheapest pre-amp i've spotted is the little pro-ject box at
Saltpeanuts had one for sale a while ago. I don't know what the input specs of my amp are though for configuring one. Unless that doesn't matter much.
If you have some sort of a volume pot and an enclosure then the only thing you need is some RCA jacks. The input goes to one pin of the pot, the output is the next one and then there is ground. It's even easier then pie...
There there should be some passive pre kits on ebay...
sonically you are better off with an axiom or the evs attentuators frankly either are great solutions. I have both and the axiom is easier from a functional standpoint but I recommend short interconnects and a source that has a standard output volume or higher.
