February 16, 200917 yr comment_206869 Yes another USB converter.... I have an easy one for you: do these USB converters are that truly different from each other? I mean are they realy on different levels if you compare the ones you can find used like the affordable RedWine Audio to the crazy expensive Empirical stuff? I like the Canto presentation but at $500 (US) this need to be good. Thanks in advance. Amicalement Report
February 16, 200917 yr comment_206870 http://www.head-case.org/forums/audio-accessories/5000-bel-canto-high-rez-usb-playback-last.html Report
February 16, 200917 yr Author comment_206872 http://www.head-case.org/forums/audio-accessories/5000-bel-canto-high-rez-usb-playback-last.html Thanks......but after reading the linked thread I learned only one interesting fact: Justin is working on a similar device.... Amicalement Report
February 16, 200917 yr comment_206873 Thanks......but after reading the linked thread I learned only one interesting fact: Justin is working on a similar device.... Amicalement Yep, and I'm willing to bet it'll come in better looking case. Report
February 16, 200917 yr Author comment_206875 Yep, and I'm willing to bet it'll come in better looking case. OK you win.... But I'm still wondering if the iMac I will buy next month will benefit from such a costly converter if I want to use it with my Ack Dack 2.0 I like this dac but a $500. converter seems a bit over the top unless there is no real gain from these higher level converters. Just wondering. Amicalement Report
February 16, 200917 yr Author comment_206889 the iMac has a bit perfect optical output. Yes but I dont think it will work with the Ack Dack. Amicalement Report
February 16, 200917 yr Author comment_206921 does the Ack Dack only have a coax connector? in that case, a toslink to coax adapter would be a better bet, i would think. I just looked into that option. And indeed this will cost a lot less (around $50). I just hope this will (the adapter) keep the sound at a the same quality level as the one I was looking for with a converter. Thanks for your suggestions. Amicalement Report
February 16, 200917 yr comment_206938 Rat Shack had digital converts (coaxial to optical or coptical to coaxial) converters on closeout for $10 each about a month ago. I bought one, kind of wish I'd bought them out. Report
February 16, 200917 yr comment_206939 I just hope this will (the adapter) keep the sound at a the same quality level as the one I was looking for with a converter.I doubt converting one format of digital to another will introduce, amplify, or attenuate jitter. I suspect it will be exactly the same. Report
February 16, 200917 yr Author comment_206949 [url=http://images.google.ca/imgres?imgurl=http://www.audioauthority.com/images/products/977rpo_scaled_740.jpg&imgrefurl=http://www.audioauthority.com/product_details/977RPO&usg=__JWUsTMqbuWMSat3cjZZ_pus_haQ=&h=555&w=740&sz=19&hl=fr&start=1&tbnid=oxZPUZf_e5gBIM:&tbnh=106&tbnw=141&prev=/images%3Fq%3D977%2BRPO%26gbv%3D2%26hl%3Dfr]R Report
February 16, 200917 yr comment_206960 I would get something like this instead: AudiogoN ForSale: Theta Digital TLC Or the popular Monarchy DIP. It can convert TOSlink to coax and vice versa, but it also acts as a jitter reducer. You can find these used for around $100. If you can find one, these are a better value than a strict TOS-coax converter. The first time I heard the Ack! dAck! 2.0 was through the Theta TLC being fed from a computer with Chaintech AV710 outputting TOSlink and it sounded great. Report
February 16, 200917 yr comment_206961 They're only a better value if you believe that jitter is a problem with modern digital gear. Report
February 21, 200917 yr comment_208085 I still don't get what the fuck this Bel Canto unit does that's so great (according to Bel Canto, at least). Report
February 22, 200917 yr comment_208641 I thought it's claim to fame was being able to get bit perfect jitter free 24/96 music out of a computer that only has USB and no coax or optical out, so your coax capable DAC can decode it splendidly. Of course for the same price you could get a Mac mini with optical out, but some peeps claim it will have more jitter than something like the Bel Canto. Report
February 22, 200917 yr comment_208654 As has been said here repeatedly, most modern DACs worth their salt re-clock the signal, thus making jitter all but irrelevant. Report
February 22, 200917 yr comment_208672 As has been said here repeatedly, most modern DACs worth their salt re-clock the signal, thus making jitter all but irrelevant. Right, so that still leaves reason #1. Report
February 23, 200917 yr Author comment_208947 There's jitter in my thread.... OK I found what I was looking for and it's from M-Audio. Many thanks for the $ saved. Amicalement Report
February 23, 200917 yr comment_208952 There's jitter in my thread.... OK I found what I was looking for and it's from M-Audio. Many thanks for the $ saved. Amicalement Not nearly expensive enough..... heresy Report
February 23, 200917 yr Author comment_208953 Not nearly expensive enough..... heresy LOL....dont worry there's more cables involved with this new configuration.... Amicalement Report
