Jolida Glass FX Dac
bhjazz
Yet another futher different dac.
Seems like a decent product, the Joloda Glass FX tube dac. I agree, the name is a little pretentious. I have a Jolida tuner here somewhere, the JD 402. (Out of production now.) After digging around, there were a few places for a while that offered some upgrades to the unit, which caught my attention. And when I got inside it myself, I saw that yes, there were some obvious things to change that would be both easy and useful. For starters, caps, wiring, wire routing, tubes, etc.
So on to the tube dac. A standard round of questions apply. Anyone heard it? Anyone have one? Anyone think this is a great/crappy buy? I'm asking since there are very few reviews of this unit online. The price seems decent at ~$375. For any DIYer it might also hold some "ultold riches" once it's been hotrodded...
Thanks.
(I am adding the upgrade items for the tuner here just to give an idea what might be able to be done with the dac....)
This is Underwood Hi-Fi's ungodly price for upgrades on the old tuner. $400! Jebus. Here is the list. (Thank God I can do these on the cheap all by meself)
New Jolida JD-402 tube tuner modification
Jolida JD-402 Level-1 mod - $790 plus freight ($400 retrofit) -
Our Level-1 mod installs
4 x small EAR brand compliant Sorbothane isolation feet
2 sheets of SoundCoat chassis damping material
3 feet of DH Labs 23-gauge pure 99.999% silver signal wirewith foamed Teflon tape-wrap dielectric
2 x Auricap signal path metalized polypropylene coupling capacitors
3 x Soeln feedback coupling and power supply decoupling metalized polypropylene film capacitors
12 x Kiwame brand carbon-film 0.5 and 1-watt signal path resistors
TRT WonderSolder used throughout
3.5 hours labor
Edited by bhjazz
I'm poor at best at judging DACs by their design, but I can tell very little by the specs that underlie the tube stage. I guess someone who has knowledge of the Burr-Brown 1793 can chip in on that, but I don't have my hopes up for this DAC yet.
Edited by manaox2
1793 is BB's performance grade voltage output dac. It's OK; nothing amazing. Then again, with a distortion spec that high on the final output, I'm not sure how much it matters.
I know. I was thinking that might be due to the tubes. Not sure.
I found this. Includes some crappy cellphone pics of the internals. He has left the thread hanging so who knows. Sounds like the build quality was iffy, but that happens once on a while.
12AX7 cathode followers are worthless, even paralleled. They just don't have enough current across them or Gm to drive anything. Generally, for lowest distortion, a tube wants to see a load several times higher than its rp (even when the load is on the cathode). rp on an AX7 is ~80K, both sides ||, 40K. That means that if your next stage has an input Z of lower than 250K, distortion will be high. Maybe it will sound toobey.
What's with the Ultra Linear class AB, 1W into 8 ohms, and the 240W power requirement? Just a sloppy cut and paste job?
Forgive my naivete, but what exactly do you use in a single ended tube output stage other than a cathode follower, eg in a headphone/speaker amplifier? As in, wouldn't the output distort as speakers are 4-8 ohms, most tube amplifiers have output impedances at best of roughly the same, and the distortion is based on the ratio of the rp of the output tubes to the headphones/speakers? And in a push pull output stage, which typically uses pentodes, the rp is even much higher.
Edit: Nvm, forgot about the output trafo. :palm:
Edited by mypasswordis
Well, overall output stage design (as opposed to just the tubes) is likely the determinative factor. This product doesn't seem very interesting to me from a performance or design standpoint.
Any voltage output DACs you like, Filburt?
Uh...I guess the WM8740/41, and AK4396/7 are decent. You can use an ESS Sabre in v-out mode which may be better than the other four due to the filter and modulator design but I've never tried it. I'm not a big fan of voltage output dacs for applications where you don't need that specific functionality as they're uniformly lower performance than what can be obtained with current output dacs.
I purchased this DAC, and it was a huge mistake. It is noisy, and the support from Jolida and AudioForce is not good. I purchased this unit based on the good experience I have had with my Jolida 502 power amp.
This is my first bad exprience with Jolida product and service, hopefully its just a fluke. I was looking forward to trying the JD-9A phono stage as well, but a noisy DAC is keeping me from pulling the trigger on that purchase.
I emailed Michael Allen at Jolida regaurding the specs, as well, (no reply).
Dave
Ouch that.
As for Michael Allen, he just sent me an email reply. I guess I have to remember that in much of the world, people just don't worry a lot about email. There is other work to do. Here is what he wrote:
FX Tube DAC Specifications
Inputs : 1 x coaxial
1 x toslink
1 x USB PC digital input
Audio outputs : 1 x pair gold plated RCA outputs
D/A converters: Texas Instruments PCM1793
USB Transceiver: CM102S
Tubes: 2 x 12AX7
Frequency response:10Hz to 70KHz (±1dB)
THD: <0.02% Tube Out(1kHz)
SNR: 80dB
Dynamic Range: 113dB
Supported digital input upsampling frequencies:
32kHz, 44.1kHz, 48kHz, 88.2kHz, 96kHz
Audio output upsampling:Fixed 24 bit 192kHz
Power consumption: <25W
Dimensions: (H x W x D) 52 x 215 x 191mm (2.0 x 8.6 x 7.6")
Weight: (net) 6.2 lbs., 2.8 kg
Finishes: Silver / Black
Ouch that.
1 x toslink
Tubes: 2 x 12AX7
SNR: 80dB
That just sucks, the SNR is worse than the published specs.
I made a poor DAC choice, but thankfully it's going back today.
Dave
