This stream auto-updates
  1. Past hour
  2. Today
  3. Yesterday
  4. For those in the Bay Area, the Fraenkel Gallery has a Katy Grannan exhibit titled Mad River, portraits from Humboldt. Small (it’s not the main show), but great.
  5. I didn't really show it, but running the doors through the table saw would have been a PITA. It's too cumbersome and would have left scratches in the already finished flat sections. So instead I opted for the track saw. One thing that I love about the track saw is that you just measure where you want your cuts, set the track right on those lines. No adding inches or subtracting inches. Set your track right to the cut line and that's it. 3 of the tool review shows that I watch have tested all brands of track saws. The Makita topped all except two. Those two are the Festool and the Mafel. Those are about three times the cost of the Makita. On two of those three reviews, the Makita tied with the Festool. The Mafel edged both out just by a hair. But I do love this Makita. So well thought out, and easy to micro adjust. One of my best investments. And if you're working alone it's the only way to go. Add in your wealthier buddies Festool dust extractor and even the cleanup is easy. That doesn't mean that the shop is clean. It's a disaster. That's next weekends project, but it saves you breathing in a ton of sawdust! More pics tomorrow.
  6. Another tidbit... Finish the bottom and top of the doors too. Wether it be paint or stain and sealer. You'll never see them once installed, but it keeps the doors from warping in the future. Whatever you to one side/edge of any wooden object, you want to do to all sides/edges. We knew that the length of these doors would have to be cut for final install, but didn't know that measurement yet. So know that I'm doing the final cuts all surfaces will get the hardwax finish. Both doors cut, milled for hinges, sanded and refinished. Tomorrow will be installation. And then I'm done until dresser and door hardware arrive. Hopefully my measurements are correct.
  7. I had to cut all four edges of both doors, because the contractor didn't listen and built out the doors jambs. I got a little nervous when I pulled out the track saw and discovered a thin curf blade on it. I learned that thin curf blades on a track saw cutting hardwood can be a disaster. The thinner blade will actually bend into the track, destroying your project and your track. I've been buying specific Makita track saw blades, but no time to order one now. So instead I just went very slowly, watching the edge of the blade the whole time. Made four beautiful cuts. One door down, one to go. Then it's hinge recessing time.
  8. These caps are extremely transparent in the many uses I did. Both high voltage 600 and 1000 volts I’ve used them in dc blocking and seem to have a neutral sound has anyone tried these in Amps and pre amps I’m curious to know what others think I’m not a fan of anything oil as I feel they color the sound. In addition in stat amp builds 400 vdc seems on the edge of max range why don’t builders use 1000 vdc rated caps ? ABD0000C255.pdf
  9. The part tested ok and seems to a 15 volt reg mc 7915ctg mc 7815ctg
  10. Where the Amish (and Mennonite) go on holiday https://www.bbc.com/reel/video/p08p2rws/where-the-amish-go-on-holiday
  11. Hey, San Anselmo The Tom Finch Band and a Good Boy Is Rockin' under the redwoods into the night
  12. Ok thanks. At first I thought exploded lol I removed them and replaced them. I tested them and they work fine
  13. They seem to be some sort of discrete voltage reg made to replace std. 78xx/79xx regs. Sparkos makes some, and I saw some on aliexpress, but nothing that looks exactly like these.
  14. The part tested ok and seems to a 15 volt reg mc 7915ctg mc 7815ctg Bottom right is where the reg were Below the vishey 4700uf caps
  15. Last week
  16. Fair warning: Incoming gratuitous cat photos. I've been editing a bunch of shots I took 12-15 years ago. Two friends of mine (who are now married and have son about to turn eight) lived in an apartment in a former mill town. They had two cats. Ozzie was a Russian Blue and exhibited the characteristics of his breed. He was inquisitive, always tuned into what the silly humans were doing, but also very independent. He was not a lap cat. The other kitty was Mauro, who ...a bit heavyset (he was an absolute chonker) and possibly the extreme example of a polydactyl cat I have ever seen. Ozzie's antics were legendary and I took many photos of him "helping" me DJ. These four I posted when I took them in the spring of 2010: Note the first photo being used as the wallpaper in this shot. Ozzie helping me wire up my Korg Z1's MIDI connections. I mentioned in another thread that Kate (one half of the couple mentioned above) had a birthday on the 11th of this month. I had plans (of the "mice and men") variety to send her a bunch of photos from early 2010s on her birthday, but it took me a week to finish editing them. I mean, I'm still editing them, but that's another matter. All of the above were photos I edited and posted around the time they were taken. The following are newly edited. In August of 2010, we (and by "we" I mean "me and I have no idea who else") did a "photo shoot" with Ozzie and some accessories: Ozzie was mostly cooperative (not a guaranteed thing) an held still while we placed smokes, Snapple, a phone and some kibble in front of him. Another shot of Ozzie with wallpaper Ozzie behind him. I used the 50mm DoF separate the actual cat from the photo of him, but still keep the latter recognizable. Ozzie, warming himself on the exhaust fan of a Windows laptop. He's got his paws on a USB battery. Part of the "Where is your god meow?" series I did with Ozzie. Circle cat could use a good brushing, but I wouldn't recommend trying it. Ears back momentarily, for aerodynamics. Mauro being chill, which was his normal state. He was very stead in a windstorm. Tune in next time for pre-civil war bridges!
  17. Seems legit!
  18. Buckingham Nicks by Buckingham Nicks (1973) https://album.link/bm8z6jfzcrdrs Example: Happy to see it given some attention. Been a fav for many years.
  19. swt61
    Deals
    Does this make Stretch an honorary musician?
  20. In case you're interested. Wiki: The album was a commercial failure on its original release,[8][9] and despite the duo's subsequent success, it remained without a commercial remaster or digital re-release for over five decades.[10] It was revealed on July 22, 2025, that the album had been remastered and would be released on CD, vinyl, and streaming September 19, 2025.[11] Rhino Records will handle distribution.[12]
  21. mikeymad
    Deals
    https://vinyl.sonymusic.com/products/pink-floyd-wish-you-were-here-50th-anniversary-lp-box-set Deal?
  1. Load more activity
