June 27, 201313 yr comment_585226 I only confirmed with Sine wave… I’m used 2SA1930/2SC5131 and my friend used MJE15031/15030 for the power stage. We will compare sound after finish casing. https://picasaweb.google.com/inuponken/KSA5#5894178191153371122 Report
June 27, 201313 yr comment_585265 my guess is that the output transistors and the 2 ohm resistors are toast. I replace the pot with fixe resistor to test, and everything run fine Put sine wave in the input and get an nice sine wave at the output !! Need just to wait to get the right pot... Report
June 27, 201313 yr Author comment_585286 Inu, nice use of Teflon tubing to get all the small transistors exactly the same height. Report
June 28, 201313 yr Author comment_585430 http://gilmore.chem.northwestern.edu/ksa5klone.jpg the fat version of the pot fits perfectly. I figure about 5 hours of build time total if I had all the parts ready to go without having to start and stop waiting for multiple orders. Edited June 28, 201313 yr by kevin gilmore Report
June 28, 201313 yr comment_585452 Can someone PM me the gerbers? Thanks! Edit: I should ask, does anyone have a board? Edited June 28, 201313 yr by holland Report
June 29, 201313 yr comment_585558 Thank you for another great project. Is there a preferred version of the LSK389? Trendsetter. com has both the B & the C variant in stock. Report
June 29, 201313 yr comment_585641 Yeah, the B-job. It's better, you know that. Hell, it will only cost you a buck more. What are you waiting for? Dew eet! Or look at it this way - would you buy a crappy Escort when you got the dosh to throw down on a GT? I thought so. Report
June 29, 201313 yr comment_585656 Doesn't really matter which version you pick but it's normally good to go for the lowest noise. Report
June 30, 201313 yr comment_585767 Yeah, the B-job. It's better, you know that. Hell, it will only cost you a buck more. What are you waiting for? Dew eet! Or look at it this way - would you buy a crappy Escort when you got the dosh to throw down on a GT? I thought so. If the B-job makes the KSA5 Klone go better like the GT, then I am tempted to pay the extra few bucks. But I might come back and complain if my KSA5 ends up with the (reported) reliability of the GT Doesn't really matter which version you pick but it's normally good to go for the lowest noise. Excellent. Thanks. Report
June 30, 201313 yr Author comment_585851 original power supply version of the krell ksa5 power supply also suitable with lower voltages for the singlepower squarewave the later version coming shortly http://gilmore.chem.northwestern.edu/ksa5psorig.jpg http://gilmore.chem.northwestern.edu/ksa5psorig.zip and here is the alternate version of the krell ksa5 power supply http://gilmore.chem.northwestern.edu/ksa5psg.jpg http://gilmore.chem.northwestern.edu/ksa5psg.zip Edited June 30, 201313 yr by kevin gilmore Report
June 30, 201313 yr comment_585864 Only problem, finding some HV ones that are not for TV use and with horrible Cob.... Edit. And who ever thought it was a good idea to call the new ones TO-3P needs to be taken out back and shot. Edited June 30, 201313 yr by spritzer Report
July 8, 201313 yr comment_587497 original power supply version of the krell ksa5 power supply also suitable with lower voltages for the singlepower squarewave the later version coming shortly http://gilmore.chem.northwestern.edu/ksa5psorig.jpg http://gilmore.chem.northwestern.edu/ksa5psorig.zip and here is the alternate version of the krell ksa5 power supply http://gilmore.chem.northwestern.edu/ksa5psg.jpg http://gilmore.chem.northwestern.edu/ksa5psg.zip Silkscreen on the original board = I think R4 is 562 not 750. Report
July 8, 201313 yr Author comment_587509 fixed silkscreen http://gilmore.chem.northwestern.edu/ksa5psorig.zip Report
July 9, 201313 yr comment_587637 Has someone finish and listening to his KSA-5 ? I just finished mine, and I'm very disappointed Sound very "thin" and clip very quickly.... Not exactly what I was waiting for ! Edit : I use a Beyerdynamic T1, which is not very difficult to drive... Report
July 9, 201313 yr Author comment_587642 don't know about T1, but sounds great on hd800 and lcd2. this amp does not have as much voltage swing as you might expect for something that runs on +/-21v. Report
July 9, 201313 yr comment_587644 Mine actually run with +/-25V ! and I expect to rise to 28V... Report
July 9, 201313 yr Author comment_587652 better change the opamp to something that can handle that like opa445. Report
July 9, 201313 yr comment_587655 better change the opamp to something that can handle that like opa445. I have a OPA445 The headphone output from my old CD player is far better ! I hope that with burn in time he will get better... Report
July 9, 201313 yr comment_587693 Has someone finish and listening to his KSA-5 ? I just finished mine, and I'm very disappointed Sound very "thin" and clip very quickly.... Not exactly what I was waiting for ! Edit : I use a Beyerdynamic T1, which is not very difficult to drive... My origional KSA5v with the blackgates has never shown any signs of clipping even when driving my k1000s at full volume( it drives them to a reasonable listening level at full volume ,but definetly could use more power then the krell can produce) but it is very clean sounding with no clipping at all. No way would I call the Krell thin sounding. I have found the T1 to sound best with tube amps,I have never tried the T1 with it. I do own A Blackdragon recabled T5p I will have to give a listen with the Krell when I get a chance. I also find the T5p to be picky with some portable amps but sounds great directly out of My Dell laptop listening to CDs go figure. Edited July 9, 201313 yr by bozebuttons Report
July 9, 201313 yr comment_587712 I go to buy a function generator to see how and when he clip. Like this I can measure the output power too... Any recommendation for the generator ? The amp run since 5 hours and he is getting to sound better ! Report
