Kevin Gilmore Circlotron Output, Large Enclosure [high-slew] Electrostatic Amplifier
I have seen bigger caps than the 470uf caps mounted horizontally, so I'm sure its ok.
a singles version of the 900v supply would be 5.95 x 4.5 inches
http://gilmore.chem.northwestern.edu/circlotronhvpowersingle.jpg
so each side of the heatsink with everything mounted vertically from the front would be
driver board
output board
900v power supply
900v power supply
hv power supply
so minimum height of the heatsink needs to be 5.95 inches
and the boards stick out a maximum of 4.5 inches
definitely fits in the 5U box ??
transformers on the back panel??
2 inch spacing between the driver and output board
then 3 inch spacing on the power supply boards (or whatever the cap height is)
  • Replies 256
  • Views 91.7k
  • Finally received Front/Back plate for the 5U Dissipante - almost took forever. Decided to have a groove dividing the front plate into an upper 2U and a lower 3U, to have it look less bulky; it's sti
  • When I originally fired it up, the voltages seemed to automatically compensate for any adjustment I made. I would guess I because both halves are connected since I'm using a center tap setup.
  • I never had troubles with the HV900's, and haven't had any that blew, so the following is based on what I've found useful troubleshooting/checking the regular Golden Reference HV. Often it can be he
How about mounting the driver/output boards vertically & the PSU boards horizontally? Should put less stress on the caps & leave enough space for toroids on the bottom plate (this is assuming 500mm depth). I can include a rudimentary sketch if needed.
Good to see this one moving forward........
RE: Cases and enclosures? Who needs em, have em built Don Garber style, open frame and easy to touch.  >:D
Edited by DefQon
This is an amp you'd really want a 6' stick just to turn it on....  ;D
that was also part of my reasoning for using a preamp... something with a remote so I can listen comfortably behind the blast shield
its really no different than the kgsshv, its the same +/-450v output swing.
and the 900v supplies are the same as the original supply, they just float.
no big deal, nothing to see here, move along.
made the single power supply a bit smaller.
5.95 x 4.35 inches
by the way, the pdf of the kemet capacitors specifically says they
can be mounted in any position.
impossible to keep up with your progress, not that that's a bad thing
When's the DHT amplifier coming out? Will there be a kickstarter?
"350V/us", does that mean you plan to bump the current in the output stage to 42mA (assuming 120pF load)?
Would it be safe to use the original PSU board for the floating supplies if one lowers the voltage from 900V to 700V  then the original 450V caps can be used I assume
should you actually find music that will drive the amp at the speeds necessary, the
output stage will drop out of class A and go into AB.
kevin gilmore said:
"this is the new power supply schematic. i like it much better than the previous version."
And I assume if you ground the input side and the output side at the junction of the two 470 uf caps you can use this PS for the KGST, KGSS, KGSSHV Carbon, BH, etc - with appropriate adjustment for the output voltage?  BTW, shouldn't R8 be 890k nominal?  Will need to find a 1 kV rated resistor for that one, or else three 350v resistors in series.
yeah, there is about 5 volts of offset, no biggie
board posted there are 3 resistors in series for the feedback
and its 890k total on the board.
no, you definitely should not try to use this as a dual voltage supply
because only one side is regulated.
like this
http://gilmore.chem.northwestern.edu/circlotronhvpowersinglenew.jpg
apart from a lower voltage swing I assume the circlotron can be doneusing battries at 700V rather than 900V?
Thnx, can you share the part number for the 1kV terminals you are using? (cannot seem to find any at Mouser)
Oh, what a great project! So It will be 8 boards+ 3 transformers to build the circlotron?
For some reason thoughts of flies and sledgehammers comes to mind. >:D
Edited by JimL
i also don't know where to get sheets of that silicone shown above
Bergquist do SIL PAD which Farnell/Element 14  have and also similar transistor retaining springs
http://uk.farnell.com/fischer-elektronik/thfu-3/clip/dp/1892352?ost=transistor+spring+retainers
Good luck with this project!
Edited by headinclouds
