AKG K1000 Headband Re-tension
So I received my K1000's. Unfortunately the headband is a bit saggy. Does anyone here know how to re-tension this headband?
I can either increase the tension on the headband or surgically lower my ears. I think I would prefer the first.
Renato
it's just bendy metal in the bands so as long as you're careful, a little adjustment at the four corners should do the trick.
Oops I guess I should of been clearer. :mikey2:
Not clamping tension but the tension of the so called "self adjusting headband", the leather part. It does not have enough tension to keep the drivers higher and inline with my ears.
You probably need a new headband. The tension is created via a rubber band of sorts attached to the leather headband. To access this you need to take the driver housings off the headband.
If you swing the drivers out, you'll notice two screws holding the driver housing to the headband assembly. You need to unscrew those and then take the drive housing off. This will allow you to take the temple pad assembly off. That will give you access to the headband.
I don't recommend this though. Once you remove that driver assembly and fiddle with the temple pad assembly you risk losing a spring and little ball bearings that are a part of that whole assembly... there are a lot of little easily lost parts in that assembly unfortunately.
Plus you'd either need to rig up some new rubber band thingy with greater tension or replace the band with a new one.... good luck getting in touch with AKG for spare parts. They can be tough to get a hold of.
Renato - sorry about the headband. :-[
I'm guessing I didn't realize it since I have a pretty huge head. Let me know if there's anything I can do.
No problem. I guess my head is too small or my ears are too high on my head.
I guess over time the rubber tensioner has stretched and the weight of the headphones overcomes the headband tension.
R
Thanks for the instructions, they were very helpful and kept me from losing the springs and balls. I took it apart and the rubbers are very stretched. And they are integral to the inner headband. If I'm able to get a replacement can anyone provide additional guidance in separating the outer and inner headband?
R
Welcome to the K1000 club. What are you driving those K1Ks with Renato? ;D
We want listening impressions. It's always fun hearing what people think of the Big K
Thanks.
Onkyo high-current receiver, speaker taps... for now (wallet is empty).
R
It's a little early for that. Lets just say that so far I'm happy with my investment.
R
Congrats on the earspeakers, Renato. They've got a very unique sound.
Glad they arrived fine, sorry to hear about the tension issue. :)
It would be no problem for you and your big head. :sadcat:
or me and my big head. send 'em thisaway. :prettyprincess:
Well, the obvious solution is just to give them to me. I've yet to receive any 'happy divorce' presents... :D
Well, I don't have sound on the computer currently as Renato has been holding my transit hostage, but I think I got the gist. :D
It may be a while before you get it back then, because we're currently holding Renato hostage in a Ford Transit.
