An all DHT amp for Grados
MachMat VCCS filament supply
Gary Pimm CCS
Design by HF member Roam, traced out by me while I was over at his place to pick up transformers for my own project. Yes I have his permission to post it. I spent about 20-30 minutes listening to it out of his Capitole CDP and my RS1, this amp is good, stupid good, but also stupid expensive thanks to the transformers and Emission Labs AD1 tubes. He says he has what should be a slightly purer version in the works using WE 205E's on the front end, but it may sacrifice a bit of bandwidth. No PSU schematic yet as he's still waiting for some parts to come in so it's running off an adjustable benchtop PSU.
Can also be built with Lundahls, using the LL1676, LL1635, and LL1620, with something like the Prometheus TVC as the volume control. Still not cheap, and it'll still weigh a ton.
Interesting. Could you please ask Roam to join HC? He's one of a handful of people on HF that seems to actually know what he is talking about when it comes to amplifier design. Not that I'd know, I'm not in the handful. He would fit in well here.
Please tell Roam to design a DHT amp for stats :prettyprincess:
How much is expensive? Just curious.
Very expensive. If you found someone to build one of these for you
and did up the power supplies to the level of the rest of it, its going to
be $10k. At least 2k in parts (i'm probably way low) if you build it yourself.
DHT amp for electrostats is easy. Going to need a fork lift for the
required power supply. First person to show they are serious by
putting $15k in a bank account and i'll publish the schematics.
:kitty:
He said it would be around $3k to $3.5k in parts alone for the Lundahl version, the tubes by themselves come out to something like $1.6k. Way beyond my budget unless I win the lottery or something, and doing a good parts layout is likely beyond my skills as well.
I'm volunteering ojnihs :laugh:
haha. not for another 7 years or so :D
That is a very nice and expensive amp you've got there. :kitty:
There is at least one published DHT amp design for electrostatics. It was in the second edition of the Morgan Jones "Valve Amplifiers" book and aptly called "The Beast". The whole chapter is a great read as he talks about how scary it was to test it and how none of his equipment was meant for 1kV+... ;D
The cost is a major obstacle so I went with a new BH instead as 15k$ for a headphone amp is insane. A properly designed DHT amp will drive the Quad ESL57, KLH Model Nine and Stax F81 directly with ease so it might be justified for a hardcore ESL nut... ::)
So out of college, my second speaker system was tripple stacked quad esl 56's with decca ribbon tweeters.
Owned a pair of KLH model 9's for a few years till the tweeters blew up.
Had a pair of accoustats for quite a while too.
My first surround system was 4 x quad esl 63's.
Hardcore ESL nut ????? You Betcha
Sounds like that amp wold be a pain in the ass to haul to meets ;D
Yup, you do more then qualify. ;D A triple stacked ESL must have been something else as I was mightily impressed by a double stack.
Who needs meets when you have the best... ;)
  • 4 years later...
Time for a 5 year necro bump :)
Posted on diyaudio, no pot/resistive volume control, uses the secondaries off the Tribute OPT to step down voltage
pietertributehp.pdf
I've been following this thread myself. There's some interesting discussion going on, mostly about transformer design in relation to headphones. The design being discussed above is only going to work for something very sensitive, like a Grado. I imagine that each of those OPT are going to cost more than an RS-1. I wouldn't mind having a pair if the price were right. The Russian 4P1l and it's big brother the 6p21S are both excellent sounding tubes that are plentiful and dirt cheap.
Hi Frank, the 4p1l push pull amp by Pieter should be ok for Sennheisers as well which are highly sensitive. Not sure about the sensitivities of other companies, I am in the Senn/Stax camp :)
I'm working on a few Stax DHT amps but nothing as insane as Kevin's 12 tube monster.  Not going to start any new projects anytime soon though, it's time to clear some of this half finished stuff.  :)
I'm working on a few Stax DHT amps ....
I would like to know more about it :) Would you be so kind and tell us details?
Nothing concrete really but one will have only two DHT's in it, rest will be transformers.  Not meant to sound nice though, it's just supposed to be bonkers.  :laugh:   Well that and very, very expensive.
From time to time I think of building a "poor man's" all DHT electrostatic amp. One idea is building an "Egmont" type circuit using Eimac 3C24's. The 3C24 is sort of like a DHT 6SN7 on steroids. Usually available on Ebay for about $25. The big problem, besides the exposed plate and grid connections, is the filament supply complexity. With a little creativity, you could probably do it with 2 6A supplies per channel. At the very least, it would be an interesting novelty, and might possibly be considerably more.
The filaments are indeed the big headache.  Using AC and a balance pot is possible but I'd rather use something nicer.
40 kHz oscillator driving chip amp driving small transformer.
same way craig does it.  Easy, cheap and makes biasing
much easier.
