Now i'm downright hostile. No amp bottoms... Will ship out 4 more bottoms and 4 more heatsinks today.
Inu and Birgir parts will ship today.
  • Replies 5.4k
  • Views 1.5m
Just like all UPS fuck ups, you'll write them off only to have it all turn up 2 months later with out so much as a sorry note.
Rage ensues :mad:
I would be more than interested!
Found the four heatsinks in someone elses delivery...
Can't find the 4 amp bottoms yet, so 4 more will be at
the anodizer later today...
You would think it would be simple enough to keep order A
seperate from order B...
Especially when they were different colors...
And yes, all of my stuff is the same color.
Rage ensues :mad:
Don't start me on a carrier rant - they are all as bad as each other. The Tekscopes mailing list is a regular litany of test gear bought off eBay that arrives looking like it has been thrown out the back of a moving truck (maybe it has). Or two identically labelled identical parcels I shipped to the La Palma observatory. One arrived OK, and the other was returned - somehow separated and the sender's address had been interpreted as the "to" address by some blithering idiot. Or the piece of gear coming from Ca to the UK. Never arrived. 8 weeks later it got back to the sender - our idiot parcels service Parcel Force (or Parcel Farce as it is known) failed to deliver the correctly labelled package, failed to leave a note three times (they are required to make three attempts, and leave a card if there is no answer), and then returned to sender using the cheapest and slowest method (pony :horsey:).
And that is just for starters....:rant:
I would like to compensate you for your trouble if the parts are not found or whatever.
I would be interested in the heatsinks, not the T2 chassis though.
I have a receipt from the anodizer for accepting 16 heatsinks and 16 tops/bottoms and 16 fronts/backs
So he will be paying for the missing stuff. Or he has to find the stuff. I really don't care.
justin might have some more of the heatsink. Otherwise i have just enough heatsinks to match
the fronts and backs.
If justin does another batch of heatsink there will be plenty more. This time i will order extra.
If people want me to ship what i have now, i can do that, the amp works fine without its bottom.
That way you can start assembling now. All you need to do assembly is the fronts/backs,heatsinks
and power supply bottom.
Anodisers never fail to amaze me. I use MetroPlating in Uxbridge
Metro Plating - Sulphuric - Chromic & Hard Anodising - Alochrom - Aluminium Finishing
Absolutely first rate, but I always drop off and collect, and check each piece. Good they are, very good, - but it is absolute chaos in there, a real bloody mess. This seems to be the standard way of working - I've visited several over the years. I'm lucky that I'm only about an hour's drive from Metro; god knows what would happen if they shipped.
The only thing that would worry me about that is the delta cost of sending the final bits across the pond. How long will the replacements for the lost bits take?
Kevin:
I'm curious, why do you have to use a separate vendor for polishing? Is this prep work not something the anodizer can usually take care of?
Jesus. Good luck and hopefully sorting that isn't too painful for you :/ Yeah I'm down to do whatever is easier for you as well Kevin! Yay chassis!
For whatever reason the really good polishers don't do anodizing, and vice versa.
This all has to be local, and both of these companies are real good at what they do.
Very different machining and processes. Really don't want to go into the anodizing
company ever again. Boiling vats of boric acid. Lots of chemicals that just can't
possibly be good for you. The fihisher for the flat parts has this absolutely huge
sanding/buffing thing. Really neat, and something else i would rather not mess with.
The heatsinks are polished by hand.
Hopefully another 10 days or less to anodize the bottom panels.
I think people should wait until its done, and ship in one box.
But for me personally i would take it in two shipments just to get
working on it that much quicker.
Then soon, like next week i will ship the next batch for polishing and finishing.
Since I'm still waiting for mains transformers, I'll hang on until it is complete. Give my regards to your anodisers ;D
Jeez what a PITA. Having spent virtually all day on the phone to my insurance company (my wife backed into a rock, thanks honey!) I can certainly empathize regarding companies that needlessly raise your blood pressure.
I'll hang on too. I am anyways still waiting for my RK50, 3381s backordered at Dalbani and the relay backordered at Mouser.
i have 3381's listed at fleabay. they are BL, not GR, does this matter?
I think Inu had some initial problems getting the 740V batteries to lock, even after screening his BL's for low beta (at the high end of the GR range). Could be misremembering - so check back in the thread.
Those were the 2SK246s. Don't know if the 3381s are equally critical. Anyone?
I would also be interested in the heatsinks alone :)
Thanks for straightening that out! I dunno about the 3381's. But they all seems to be used as simple current mirrors, so probably not critical.
I am using 3381-BL :D
Replacement parts delivered to anodizer.
Going to have some high power liquid refreshment and then
measure my BP.
Well done sir!
measure my BP.
Bet that was what Tony Hayward said
Wow you moved quick on that.
I hope the high powered refreshment did it's job =)
I never noticed this before, but there is a REF102C part that is even more improved over the B version. Perhaps a new part, I'm not sure.
.1% on the power supply is more than sufficient, but hey go for the better part.
In other news the anodizer found the 4 missing panels. That he never anodized...
who wants mismatched purple and black sets??
