November 16, 200916 yr comment_296773 I see that Panavises are highly recommended by a number of you. What base/head combination would you suggest as an initial purchase? The circuit board holder looks great, but there doesn't seem to be much expandability. I was thinking the model 350 (tray base, wide jaws) might be a better option because it can take a wire holder. Do the wide jaws work well for PCBs? Is the soldering station useful? Thanks for suggestions! Report
November 16, 200916 yr comment_296815 what are you planning to use it for first ? and how do you want it to stay in place The 380 base with 376 head has been very helpful (unmoving, firm and easy to adjust) for soldering of xlr connectors and modding of my K340 headphones Report
November 17, 200916 yr Author comment_296961 what are you planning to use it for first ? and how do you want it to stay in place Mostly using it for soldering PCBs (usually small to medium size). However, I'm also looking at non-PCB heads for a secondary use to hold plastic case parts while I Dremel them. I'm hoping that the base will stay put without bolting it to the table (not an option). Report
April 16, 201016 yr comment_344591 Bumping this because I need a Panavise. My use will be primarily for cables, with circuit boards and other random stuff next. I won't be bolting it to anything. Suggestions appreciated. Report
April 16, 201016 yr comment_344593 The model 301 has served me well for many years now. PanaVise Products, Inc. One thing that might be worth adding would be the 312 base, which adds a lot of stability and a place to stash a few parts while you're working. PanaVise Products, Inc. And you might find both cheaper with a little searching, I can't remember where I ordered my stuff from in '04. Report
April 16, 201016 yr comment_344596 I have the 324 work center, minus the solder iron holder, which I bought off of ebay. I never have bought any other heads for it; still use a helping hands for cable shit (or my bench vise). I dislike the helping hands more everytime I use them The Panavise Jr. looks nice, if you can live with its limitations. Report
April 16, 201016 yr comment_344603 Chris, do you think the 324 would work for cables? Not really, no. I have one has well and its functionality is pretty much limited to PCBs with those big jaws although as Chris said you can buy other heads for it. Report
April 16, 201016 yr comment_344608 If you are not going to permanently mount it you might want to go with the 381 or if you do not like that head the 380. Report
April 16, 201016 yr comment_344609 I like the 301, just trying to figure out how it would do with cables. I find that the extra hands are pretty necessary, but I can't stand most "helping hands." Report
April 16, 201016 yr comment_344630 Nice! Just setting up my purchase from Stanley Supply. Thanks for the info! Report
