The Ultimate DIY Part 2 ? The KGITSOJC
Thanks, I thought it might have been already mentioned in some form.
I didnt think about it until I saw the word "vendetta".
  • Replies 350
  • Views 135.7k
  • kevin gilmore
    kevin gilmore
    Sure there is a schematic. Its in my head somewhere. There will be an official schematic at some point. There is a bunch of different ways to build it including single ended only, and balanced/sin
  • Has there been any work on this lately?  I really want to do this one.
  • Input JFETs just came in the mail. Most of them look real, there are a couple 2sk170s that have funky looking printing on them that I'm not sure about. Will measure IDSS later.    Finally the projec
Oops my mistake, thought you meant the two huge Blowtorch threads.
Only way to get the noise down
is with discrete parts.
I agree if were talking about the MC input stage.. But I'm not convinced the Klyne is 100% discrete and would love to get a closer look at one. Looks like the same gain modules are used in the line pre section.
I'm not sure I'd bother with the Vendetta. It has to be hand-built unit by unit and to do this you really need some decent test equipment. I tried to breadboard one and it was very unstable and drifted all over the place.
I'm almost positive the glued devices are violet grade. I can give you some part numbers for very nice SOT JFETs that have lower noise than any of the Toshiba parts, but you probably aleady are looking at those.
Kevin what is your experience matching the 2SC3421 or 2SA1358? Just curious to get a rough idea how many to order of these to get suitable values...
I have slightly different values for things like R30-31 (100K) but that doesn't matter.
Brown Black Black Yellow Brown Red ==== 1 Meg 1% 50ppm ??
You might consider putting a resistor in parallel with C3 in case someone wants to run it with a MM input. Also, a trimmer on the input is lame. Switched resistors (and capacitors) is better. Is Q16 flipped (drain and source flipped that is)? Same with Q14? Is C11 hooked up right? D1, D2 are 15V.
i'm sure c11 and c14 are correct. Q16 and Q14 may be in backwards, will look at that soon.
D3 and D4 are 1n4746 which are 18v zeners
D1 and D2 are 1n4737 which are 7.5v zeners
This version has to run as a moving coil unit. Reason, the .1uf 1% cap and 750 ohm resistor at the output of the first part are
one of the 3 riaa filters. Another version has the input resistor and pot replaced with a 47k resistor, and then the
gain of the input stage reduced by 20db or so by changing around a bunch of resistors.
a couple of other things fixed too.
So here is a little historical fun.
Back in 1975 and 1976 while in college i was building and selling
world class phono sections and preamps. (sound familiar...)
Virtually all of which are still in use today.
So while some things like good circuit design seem to be timeless,
other things like double sided circuit boards with heavy ground coverage
are new.
These days i would add a servo to the thing to make sure there was no DC on the
output, something that really did not matter back then, as there were no fully DC coupled
power amplifiers.
I don't actually remember which of the riaa sections i ended up with, there were at least 3,
so i showed the one from Robert Linsey Hood
The original fets were ct134, which i replaced with 2sk170 in this schematic.
http://gilmore.chem.northwestern.edu/kgphono.pdf
this was one of the first boards without a solder mask.
http://gilmore.chem.northwestern.edu/opampfront.jpg
http://gilmore.chem.northwestern.edu/opampback.jpg
Primitive elegance...
Some things never change (like the dual FET front end).
Love the KG logo too!
there seems to be a growing interest in the phono section...
http://gilmore.chem.northwestern.edu/kgphonoservo.pdf
not counting the power supply, this is no more than $50 in parts if you
use the lsk389, a lot less if you use 2sk170's... With the servo, matching
is virtually unnecessary.
I'm trying to find the moving coil schematic i did way back when...
This phono section would be quite interesting, there are very few discrete diy options out there. Maybe we should start a new thread about it?
  • 3 months later...
Its time to get back to work on this, now that the other 2 major projects
are completed.
I've been told to stay away from OLED's because power supply failures can
cause burned up lines. So unless someone has a better idea, i'm going to
go with this one.
http://www.4dsystems.com.au/prod.php?id=114
I want a touch screen, and i want the embedded proc to be able to do
i2s to drive the switching etc.
Edit: screw it, i ordered both the oled and lcd versions.
Also ordered enough stuff to make the thing programmable from
wifi. You could do a version with no touchpanel or knobs at all.
Would this be using the linuxworks/AMB attenuator and an infrared sensor?
The digital attenuator part is similar to, but drives different from AMB's thing.
Its still an 8 bit relay thing, with latching relays. I used AMB's calculator
for the resistor values. My version drives twice as fast as linuxworks thing.
I originally was going to use AMB/Linuxworks thing as is, and give credit but
linuxworks turned into such a jerk... And they still have not actually released the
thing.
Mine may be out before theirs :D
The version with no front panel, i was thinking an ipad app. wifi...
infrared? that is SO last century...
Well you clearly know there's an app for that :D
So i've been working on stuffing the house with lutron RA2.
And there is in fact an ipad app for it. But its too combersome.
So i wrote my own. Runs native on a HP slate 500, or any
windows box. And even on an ipad inside firefox with my
local web server box with ASP.
http://gilmore.chem.northwestern.edu/lutronapp.jpg
Next week i'm going to automate the 3 bathrooms :D
Full up macro capabilities...
Then integrate in the TV's, dvd players, music server...
This could go on forever.
The preamp app will be just as easy.
Source code for this thing (all of my new things) will be
available, and for the usual and customary price.
thing.
:lol: yes a bit embarrased by the IR remark. ipad functionality with no screen/knobs seems cool to me.
I'm in for whatever volume control you feel is the most transparent. I intend to use this preamp in a high end speaker setup.
Would the digital attenuator be a separate module (which means I can use it with other builds) or 'fixed' into the KGITSOJC?
It would be nice to have a board that would would fit into the standard balanced POTs used for the T2, etc using some sort of pins and would mount above the amp board. A simple plug in. The board would also have a ribbon cable for the I2C control stuff. Not sure if the size would workout, but it would be nice.
This is possible, but need to find the absolutely smallest latching DPDT
relay that run on 5 or 12 volts.
With the current relays, the board would be 7.4 x 2.6 inches and
you would need 2 of them.
