Now for something different...
  • Replies 426
  • Views 153.6k
  • kevin gilmore
    kevin gilmore
    So here is how this went down. Someone over there really pissed off Birgir. Its not nice to piss off the head of the stax mafia. I mean its REALLY NOT NICE to piss off the don of the stax mafia.
  • I like to build pretty much anything so why not this? I've built 3 Egmonts (and I'm working on a fourth) when I could just as well build a ESX. Why am I working on old Stax amps when I could just as
  • I understand pursuing it for your own knowledge and benefit but it's the production of boards that doesn't make sense to me. I'd argue that none of those people are going to change their minds r
I LOVE it! Bet it would go completely over the A10-lovers' heads though...
So the LL boards are pretty much ready for production and I've ordered boxes for my version of the A-10. How about "Pyrite" for a name... grin.gif
So there is absolutely NO way we are going to do an A10 board due to all the issues we know about.
But it would be nice to do something simple that anyone can build. So i'm looking for tubes
that can handle at least 500 volts, anything there is bunches of that does not have stupid pricetags
attached. And its not going to be SRPP either, because done right, you need at least 5 seperate
filament supplies. 6s4's don't seem to be in plentiful supply any more. Otherwise its a circuit
board that is bigger than it should be with multiple 6ca7's...
Any ideas?
EL-34 as a triode strapped pentode? Or would that be too noisy?
EDIT: Doh! Just checked - 6CA7 = EL34.
Edited by livewire
6P14P-EV. Tough as a boot Russian version of a 7189. Guitar guys push the voltage ratings all the time. If you were interested in octals, lots of TV vert. amp types still around. My favorite is the 6AH4.
The 6P14P-EV is also dirt cheap, plentiful and ultra quiet. -EB is the same tube, in cyrllic. (6 Pi 14 Pi EB more or less) But why am I preaching to the choir? Typing practice, I guess. For NOS fans, they are all NOS.
Edited by Clarkmc2
From my day playing guitar I love the sound of the 6V6 tube as in an old Ampeg amp. Also the 7591 but those have gotten quite expensive.
I'm definitely liking the 6bl7 as it is a dual triode. So we could do an amp
that is 3 octals per channel. Slightly bigger than i want, but ok
if the tubes are cheap. Looking into 6p14 now.
You can do it Kevin! :)
As 'bad' as the Exstata is seen around here, it was very compact. I would love to see another compact alternative.
Yeah, it was compact. And yes it blew up. Evidently quite often.
i'm thinking 3 x 6bl7 per channel, +/-400 power supplies, gilmore
triode amp style with cathode bias and DC coupled output.
Local feedback on the input, and local feedback on the output.
unbalanced input only. (i'm thinking about this last bit)
10 amps of filament current.
For a small amp then we could do ECC83 input and 6CM7/6CS7 for the second and third stages. Can be made quite small indeed.
I know Kevin doesn't like them much, but the differential amp (aka. Egmont) is bloody tiny, fully balanced too.
Nice, I would be interested in something small like this. Need an amp for my SR-Lambdas at work.
how about 12ax7,12ax7,6cm7. won't be much bigger than that.
The power supply however is going to be at least that size or
bigger.
I built an Egmont with 6BL7 output. Worked quite well. Maybe it was just my luck, but out of 20+ tubes no two had anywhere close to matching sections and no two samples matched each other in thier differences. I was quite surprized actually. Same with the 6BX7. One the other hand, I had no problem coming up with a pretty good quad of 6P14P out of a dozen samples on hand.
I would love to see a professionally updated small/cheap all tube electrostatic amp along the lines of a "hot-rodded" Egmont.
Glad I looked at those PCB's since I can't understand what I was thinking with the psu caps... facepalm.png
bigger.
That would work. 6CM7's appear to be in plentiful supply too. We could always do a CRC psu... :)
anyone going to be upset if i insist on the teflon sockets?
6 tubes runs it at ~$120 for just the sockets? But so long as nothing else in the amp is too exotic, it would seem pretty reasonable to me.
Teflon works for me, noval teflon sockets are cheap on Ebay... like $11 shipped each
The ceramic units are only about 2$ each and the quality isn't that bad.
"Something simple everybody can do" is a great idea... but does it have to be cheap or tube-based? This would be a great time to use pa89's
Edited by El_Doug
Silly people people who don't want to fork out for 300+$ opamps...
