August 27, 201214 yr comment_532141 Hello all!! This is my first post here and was hoping that you DIY'ers can help out a noobie. This will be my first attempt at making a headphone cable and would like to know if this is the way to go about it... Unbalanced cable using a 1/4" TRS plug and 2 mini 4-pin XLR's for the headphone end, left and right. Is this the correct way for wire hookup? See diagram below.... Report
August 27, 201214 yr comment_532182 Am I the only one who thinks the "balanced" wiring diagram, specifically the amp end of the cable looks a bit off? Report
August 27, 201214 yr comment_532183 Am I the only one who thinks the "balanced" wiring diagram, specifically the amp end of the cable looks a bit off? QFT Report
August 27, 201214 yr comment_532185 Why would they tie the neg connection to ground for a balanced setup? Report
August 27, 201214 yr comment_532195 Isn't the "balanced" setup the same as "unbalanced"? Can't find any other wiring schemes.... so... are all the "better" after market wired the same way and advertised as balanced? wait a second.... Edited August 27, 201214 yr by jwzhan Report
August 27, 201214 yr comment_532210 so... are all the "better" after market wired the same way and advertised as balanced? wait a second.... Please. Pretty please. With a fucking cherry on top. dont post like this. This is how truly inane rumors get started. The drawing above is wrong. I don't know whats right as you could do it several ways, but I know that this is wrong. Edited August 27, 201214 yr by nikongod Report
August 27, 201214 yr comment_532221 Would it really matter if they were wired like that? No need for ground with balanced and I doubt any manufacturer will have accomodated for shield at pin 1. Report
August 27, 201214 yr comment_532224 Would it really matter if they were wired like that? No need for ground with balanced and I doubt any manufacturer will have accomodated for shield at pin 1. But why take the risk? A wise man once said, "Assumption is the mother of all fuckups." Report
August 27, 201214 yr comment_532233 True dat which brings up the 4-pin XLR issue once again. Even Sennheiser have adopted it now... Report
August 27, 201214 yr comment_532235 Original source... http://wiki.faust3d.com/wiki/index.php?title=Audeze_LCD-2 Report
August 27, 201214 yr comment_532244 I think this comes down to the fact that the manufacturers can wire up their headphones any way they like , and with any connector they desire. Edited August 27, 201214 yr by wink Report
August 28, 201214 yr Author comment_532329 That is the correct wiring. Ok thanks a bunch Although, a couple of other people think differently...or... are they only referring to the balanced wiring scheme Report
August 28, 201214 yr comment_532335 the headphones cannot possibly know whether they are hooked up to a balanced or unbalanced amplifier. Maybe if you want to get fancy and add some extra weight you can use wire with a shield on it and wire the shield to either xlr ground (4 pin) or the 5th wire (5 pin) Report
August 28, 201214 yr comment_532337 The first diagram is correct for unbalanced with a TRS plug. Report
August 28, 201214 yr Author comment_532391 The first diagram is correct for unbalanced with a TRS plug. Report
August 28, 201214 yr comment_532401 Um, you can't be the monkey - there can only be one monkey in these parts. Report
August 28, 201214 yr Author comment_532406 Um, you can't be the monkey - there can only be one monkey in these parts. Kinda looks like Yoda at first glance Report
August 29, 201214 yr comment_532418 Kinda looks like Yoda at first glance The Monkey will chime in soon enough... Report
