oogabooga Posted March 21, 2013 Report Share Posted March 21, 2013 I'm looking for some help with what I think is a building electrical issue.Just picked up a pair of SR-002s from Justin. I've noticed an annoying hum in the right channel whenever I listen at my desk, but not when I listen in the bedroom (i.e. it's not the headphones). The hum is loudest when the SR-002 is connected to my gamma2 -> Mac (doesn't matter if the Mac is plugged in or not), but it doesn't go away when I disconnect the SR-002 amp from the gamma2, or even when I disconnect the SR-002 headphone cable from the amp. As in, I can hear a fricking hum even when I'm wearing headphones plugged into nothing at all. I've never heard this hum with my other Stax but I guess the SR-002s are uber-sensitive to this problem.Two things make the hum go away: if I touch the metal surface of my dac/amp/computer, or if I unplug every electrical object near my desk. My building is from the 1950s and although I have a three-prong outlet it is not grounded.Would it be correct to assume that somehow the SR-002 cable is picking up a stray electrical field, to further assume that this field is emanating from my dac/amp/computer, and that by touching these objects I somehow 'correct' whatever electrical failure causes this field? I am no electrical engineer, so these are just guesses. More importantly, is there some magic doo-dad that I can buy to fix this issue?Merci,Sameer Quote Link to comment Share on other sites More sharing options...
eggil Posted March 21, 2013 Report Share Posted March 21, 2013 I have a gamma2 I have used with my SRS-002 (USB powered, have not tried optical with it) and have had no problems with humming. Try USB without external power. Quote Link to comment Share on other sites More sharing options...
Dusty Chalk Posted March 21, 2013 Report Share Posted March 21, 2013 [dusty]Maybe it doesn't know the words.[/dusty] No, seriously, it sounds like a ground loop (look up ground loop -- it's a common problem with common solutions). Well, to start with, buy one of these, and see if it's a simple miswired power outlet: Available at most hardware stores and larger department stores (Lowe's Home Depot Target etc.) Quote Link to comment Share on other sites More sharing options...
Pars Posted March 21, 2013 Report Share Posted March 21, 2013 You can hear hum with the headphones on your head, but them not being plugged into anything? And this hum is coming thru the headphones? I'm looking for some help with what I think is a building electrical issue. Just picked up a pair of SR-002s from Justin. I've noticed an annoying hum in the right channel whenever I listen at my desk, but not when I listen in the bedroom (i.e. it's not the headphones). The hum is loudest when the SR-002 is connected to my gamma2 -> Mac (doesn't matter if the Mac is plugged in or not), but it doesn't go away when I disconnect the SR-002 amp from the gamma2, or even when I disconnect the SR-002 headphone cable from the amp. As in, I can hear a fricking hum even when I'm wearing headphones plugged into nothing at all. I've never heard this hum with my other Stax but I guess the SR-002s are uber-sensitive to this problem. Two things make the hum go away: if I touch the metal surface of my dac/amp/computer, or if I unplug every electrical object near my desk. My building is from the 1950s and although I have a three-prong outlet it is not grounded. Would it be correct to assume that somehow the SR-002 cable is picking up a stray electrical field, to further assume that this field is emanating from my dac/amp/computer, and that by touching these objects I somehow 'correct' whatever electrical failure causes this field? I am no electrical engineer, so these are just guesses. More importantly, is there some magic doo-dad that I can buy to fix this issue? Merci, Sameer Quote Link to comment Share on other sites More sharing options...
spritzer Posted March 21, 2013 Report Share Posted March 21, 2013 It's certainly a grounding issue or something is radiating an awful amount so the headphones are picking it up. If you have something earthed then run wires to that and see if it fixes the issue. Quote Link to comment Share on other sites More sharing options...
oogabooga Posted March 21, 2013 Author Report Share Posted March 21, 2013 (edited) You can hear hum with the headphones on your head, but them not being plugged into anything? And this hum is coming thru the headphones?Yea and yea. I turn my head, the hum turns with me. I take the SR-002s out of my ear, I don't hear a hum. All with the cable not being plugged into anything. It's certainly a grounding issue or something is radiating an awful amount so the headphones are picking it up. If you have something earthed then run wires to that and see if it fixes the issue.I checked my wall receptacle with a DMM - as far as I can tell the ground pin on the jack is not connected to anything at all.I think something is radiating - I do have three 120V-100V stepdowns (one of which is switching) that might be causing the problem. Sadly the nearest earth is two rooms away, although I may have to bite the bullet and run a long extension cord throughout the house. Edited March 21, 2013 by oogabooga Quote Link to comment Share on other sites More sharing options...
grawk Posted March 21, 2013 Report Share Posted March 21, 2013 perhaps your head is vibrating? 1 Quote Link to comment Share on other sites More sharing options...
Dusty Chalk Posted March 22, 2013 Report Share Posted March 22, 2013 At least try it in the other room with the earthed/grounded plug first, to see if that even fixes the problem. You don't necessarily need to run all the wires all the way, just the ground. And if you can find something else grounded that's closer (like plumbing in the walls), you can run the ground wire from that. Quote Link to comment Share on other sites More sharing options...
oogabooga Posted March 22, 2013 Author Report Share Posted March 22, 2013 Good idea Peter - I ran a long extension cable from a grounded outlet in the kitchen to my desk/audio gears. No hum at all. There's no plumbing anywhere near my desk, so I'll have to get creative!<br /> Quote Link to comment Share on other sites More sharing options...
oogabooga Posted March 25, 2013 Author Report Share Posted March 25, 2013 Managed to run a ground wire, and everything sounds great Thanks to all for the help! Quote Link to comment Share on other sites More sharing options...
barbarous Posted June 21, 2013 Report Share Posted June 21, 2013 I have an older house, built in 1948. I upgraded the outlets after an electrician friend pointed out most of cable runs were actually already grounded, to the outlet box, not to the outlet; ie the cable was in a metal housing, and that was secured to the outlet box. All I had to do to ground the outlet was run a short wire from the ground screw on the outlet (usually a green screw, on the ones I bought at Home Depot) to the screw that held the outlet in. Which extended the ground from the outlet box to the outlet. Of course you need access to the circuit breakers, and to map out your circuits first, for which that tool Dusty Chalk pictured is really useful. I don't know if the metal housed-cabling was common practice or not. There's a word for it I don't remember. I've never had an issue with a grounding hum, but I did have some random noise coming through my desktop amp and out some speakers; that I think had something to do with the computer power supply though, because grounding experiments didn't affect it, but running the amp off a battery fixed it. Quote Link to comment Share on other sites More sharing options...
corepowertech Posted June 23, 2016 Report Share Posted June 23, 2016 (edited) Edited out... Edited June 23, 2016 by corepowertech Not wishing to offend Quote Link to comment Share on other sites More sharing options...
Voltron Posted June 23, 2016 Report Share Posted June 23, 2016 May I suggest that you fuck off out of here? Pumping your shitty goods in response to 3-10 year old posts is idiotic and should be your last acts here. Cunt. 3 Quote Link to comment Share on other sites More sharing options...
