November 3, 201510 yr comment_708849 Hello,I'm new to audiophile headphones and I mean completely. I bought based upon recommendations on various websites an Aune X1S. I play Spotify with my iPhone 6 and sometimes my Mac. I understand that I can use an RCA cord to do analog. I want to know how I can connect it digitally? I read that I need an Apple lightning camera connector. Is this the one? Here is the back of the Aune X1S: Thanks for any help that you can give Edited November 3, 201510 yr by hausera Report
November 3, 201510 yr comment_708852 The plug goes in your Aunes. Twist it around a few times for the best fit. Edited November 3, 201510 yr by swt61 Report
November 4, 201510 yr comment_708878 they definitely matter less now that there's bluetooth, but most bluetooth audio isn't good Report
November 4, 201510 yr comment_708992 I don't think the lightning to SD adapter will do what you want it to do. It's possible the lightning to usb camera connection cable will, however, and you should definitely try it. Report
November 5, 201510 yr comment_709129 To connect digitally, use your fingers....... or, if very desperate, you can try your toes..... Report
November 5, 201510 yr comment_709162 A real response? AppleTV.I use one at work where I can't connect to a Wi-Fi network. The beauty of the AppleTV is that it uses Bluetooth to proximity-locate the iPhone and then does a kind of local Wi-Fi connection between the two to allow for lossless AirPlay streaming. You would then connect the optical out of the AppleTV to the optical input. I picked up a refurb for $50, have it connected via the optical out to my DAC and then to my Quad 9L Active speakers. Lossless digital connection and wireless, too.Just in case someone is looking down the road. Report
