Balanced to unbalanced board
Guys, Dr. Gilmore has done a review of the Buffer's design.
Includes several improvements like two servos (one for the input and one for the output) resistance for the input impedance, trimpot for bias ...
diffinput5b - CADCAM.ZIP
diffinput5b.PDF
All in the same size as the previous board.
These improvements help solve the two problems that I have encountered:
A) Oscillation by impedance in the input
B.) Offset due to Fets
Thanks Dr. Gilmore  B)
Edited by jose
  • Replies 260
  • Views 88.5k
  • Messing with this tonight. Its playing into balanced ortho's. the gain is stock at 2 and its just enough, not real loud but sounds just great! yes this is meant for Pre duty, this is on
  • mypasswordis
    mypasswordis
    So I did end up using a female header socket and air wiring the ground. The part number for the 4 pin right angle header is 68016-404hlf. The leds I used are extremely bright orange-red, glad once i c
  • Transformers
Can't access the attachments...
The page you are trying to access is not available for your account.
Error code: 2C171/1
1 hour ago, kevin gilmore said:
Original downloads work for me?
yes but you =SuperStar
first links no=go
second work, Thanks
  • 4 weeks later...
Buffer 2.0 is here:
Thanks Dr. Gilmore.
It really is not that expensive either (an extra Opa and some more resistances). If it is as versatile as we want, what does it matter if something more expensive comes out?
In addition, the unbal/bal works perfectly so it would be normal to have the buffer at the same level.
  • 2 months later...
digging up this thread ...
has anyone build smd version of ubal and buffer?
I built mine ,when firing it up , leds did lit up and  smoked instantly
picture as attached .not quiet sure whats going on yet.
I use diffinput3smtd and  dbuf3 gerber files to make curcuit boards
I only know one person so far that did the SMD version.
He says it gets pretty toasty and needs heatsinks. He also did a few mods. On my Dynalo Mini I mounted the LEDs backwards initially and it drove the temp really high.
Read his posts because he also changed a few things that you should probably implement. I plan on building it too but have some other projects in my queue I need to finish.
first thing i would ask is does it work without the buffers?
Edited by cspirou
yes I read this before so I thought this board should work, was thinking maybe I need to use other smd resistors which has higher wattage rating?
Is there any problems with using BC546C form On Semi and BC556C from Diotec?  I can't find BC556C from ON Semi
If you don´t find C grade, I used BTA and I hadn't problems with un/bal boards (I used sand with 500Hfe).
Edit: I mean CFA and C
Edited by jose
I have enough B grade but thought it might not be high enough.  So it looks like I'll be ok if I have to use that
No, sorry I mean CFA and C grade
ok, it looks like I can get 546C from On Semi and 556C from Diotec.  Did you use same brand?
No, I was lucky I was able to find BC546CFA (Mouser) and BC556C (musical equipment and electronic store of my city) from "On Semi" but remember that I could only matched NPN with NPN and PNP with PNP.
If you are not sure, you can buy some and measure them. Maybe you're lucky.
The BC856C variants are the SMD equivalent of the BC556C... you'd have to get or make adapters to use them though. They don't handle as much power also (320mW vs. 500 for the BC556C).
But the problem of using adapters here is the space they occupy.  :mellow:
This afternoon I will post a picture of how my preamp one is going.
My preamp. I'm still working on it.
Thanks guys.
My idea is to have three normal inputs (1 XLR +2 SE) plus a MM preamp (in my case a VSPS) AND three different types of outputs (and a mute):
1º Un/bal + pot. (It´s like a "direct" output)
2º Un/bal + pot + KG Diamond buffer MKII
3º Un/bal + pot + KG Diamond buffer MKII + dc Caps.
So you can have three "different" types of sound.
The appearance is not as good as I would like ? but it works (which is the important thing) although I still have some things to finish.
Edit: Did I say that I like blue LEDs? ?☺️?
Edited by jose
That's looking good Jose!
I was able to find Diotec BC546CTA
https://www.tme.eu/en/details/bc546c-dio/npn-tht-transistors/diotec-semiconductor/bc546c/
And Diotec BC556CTA
https://www.tme.eu/en/details/bc556c-dio/pnp-tht-transistors/diotec-semiconductor/bc556c/
They have them in stock for a decent price and sell to individuals like us.  I ordered yesterday and got a DHL tracking number early this morning.  It says I'll have them tomorrow.  They charged like $9.00 for overnight from Poland to the US!
I bought them and everything was perfect.
I think it was about BC141-16 ?
