August 2, 200719 yr They are for the ground channel in singel ended operation. Or for hooking up to yo brain. Damn you and your quicker reply!
August 2, 200719 yr From what I understand, the 6-channel B22 is to enable two single-ended headphones to run in a 3-channel configuration simultaneously, otherwise when a balanced headphone is connected the other 2 channels are not used. I am not entirely sure this is correct, but this is what I got. You are right, but you forgot the direct head-plugging of fool brains.
August 2, 200719 yr Too bad the balanced kit shows out of stock... Sorry about that, I bought the last two. I'm pretty sure they're ordering more though. And yes, the 6 channels are to allow the amp to run as two single-ended, active ground amps at the same time.
August 2, 200719 yr Author I find conventional steppers to lack enough adjustability without a gain switch and on the beta there's no real option for switching the gain simply. So is it not possible to install a gain switch on a beta? The high-low gain switch is something I really like about my Dynahi. Provides enough flexibility with the volume knob for all of my headphones. Oh who am I kidding, I always got the volume at MAXXX no matter what headphones are hooked up. loud as all hell. beat bumpin, cranium shakin, damn.
August 2, 200719 yr jack, I'll hook your motherf ass up wit tha beat dropping, booty knockin beta from hell. I charge extra for gain switches.
August 2, 200719 yr Author CAN YOU HEAR ME, POSTJACK? YOU LISTEN TO YOUR MUSIC TOO LOUD. just so everyone knows I really don't listen to my music with the volume turned up all the way. its just an image I perpetuate to look cool.
August 2, 200719 yr So is it not possible to install a gain switch on a beta? Essentially that's correct. There are ways to do it but none that really should be implemented on an amp of this caliber. Depending on the gain setting the beta uses different compensation caps so not only would you have to be switching resistors but also caps. The amount of wiring that this would take would surly degrade the signal and invite noise (the bad kind).
August 2, 200719 yr Author Essentially that's correct. There are ways to do it but none that really should be implemented on an amp of this caliber. Depending on the gain setting the beta uses different compensation caps so not only would you have to be switching resistors but also caps. The amount of wiring that this would take would surly degrade the signal and invite noise (the bad kind). Interesting! Thank you for explaining that to me. So knowing this, is the beta22 still an appropriate amp for someone like me, whose favorite headphones' impedances are all over the map?
August 2, 200719 yr Sorry about that, I bought the last two. I'm pretty sure they're ordering more though. And yes, the 6 channels are to allow the amp to run as two single-ended, active ground amps at the same time. Ok, but it's a bit misleading for people to say that particularly a 6 channel b22 was one of the best amps they've heard when its 6 channel-ness had nothing to do with it. They were either listening to 3 or 4 of the channels, unless they strapped two pairs of SE headphones to their head to get all 6 channels .
August 2, 200719 yr Ok, but it's a bit misleading for people to say that particularly a 6 channel b22 was one of the best amps they've heard when its 6 channel-ness had nothing to do with it. They were either listening to 3 or 4 of the channels, unless they strapped two pairs of SE headphones to their head to get all 6 channels . Nothing misleading about it at all. It was the 6 channel amp that sounded good. It wasn't a 4 or 3 channel amp. So shut your cake hole. Whiner.
August 2, 200719 yr So knowing this, is the beta22 still an appropriate amp for someone like me, whose favorite headphones' impedances are all over the map? I think for the most part it would be fine with the one notable exception being that K340s have been known to give low gain amps fits. If I had to build a single-ended version again I would drop the gain from the 8 that I used the first time. I think that my balanced amp is going to run 3/6 (3 single ended, 6 balanced) but I'm not 100% sure on that just yet. I'll certainly be doing some testing while I'm building my amp.
August 3, 200719 yr Essentially that's correct. There are ways to do it but none that really should be implemented on an amp of this caliber. Depending on the gain setting the beta uses different compensation caps so not only would you have to be switching resistors but also caps. The amount of wiring that this would take would surly degrade the signal and invite noise (the bad kind). What about pin-sockets for the resistors and (dont know if they make sockets that small) for the caps? I think its just the tiny caps that would prevent this. If there were ones that small, changing gain would take 5 minutes, swapping parts, and the leads could be clipped to like 1 cm and it would still be fine..
August 3, 200718 yr What about pin-sockets for the resistors and (dont know if they make sockets that small) for the caps? I think its just the tiny caps that would prevent this. If there were ones that small, changing gain would take 5 minutes, swapping parts, and the leads could be clipped to like 1 cm and it would still be fine.. But that is not nearly as elegant as a switch, especially for those who wouldn't know enough.
August 3, 200718 yr Author But that is not nearly as elegant as a switch, especially for those who wouldn't know enough. And not really practical for the average non-DIY enthusiast headphone audiophile like me. On any given evening I start with the HP2, move to the HD650, and end with the W5000.
August 3, 200718 yr You could make a 12-channel Beta with 6 in one gain configuration and 6 in the oher, with just a switch to choose which group of boards is connected to the headphone jack. Sounds like a simple and elegant solution to me, and I'd expect nothing less from this group!
August 3, 200718 yr You could make a 12-channel Beta with 6 in one gain configuration and 6 in the oher, with just a switch to choose which group of boards is connected to the headphone jack. Sounds like a simple and elegant solution to me, and I'd expect nothing less from this group! That would be impressive!
August 3, 200718 yr Pssh, the dynahi dissipates something like 70W of heat. Excessive is all relative
August 3, 200718 yr You could make a 12-channel Beta with 6 in one gain configuration and 6 in the oher, with just a switch to choose which group of boards is connected to the headphone jack. Sounds like a simple and elegant solution to me, and I'd expect nothing less from this group! A 12-channel beta...hmmmm,
August 3, 200718 yr Author So let me get a little clarification. Lets say I wanted a balanced beta22. Lets say I have some balanced headphones, but I still want to be able to listen to headphones with regular 1/4in jacks. All I really need is a 4 channel, right? The only point of a 6 channel is so that two people can listen at the same time with unbalanced phones?
August 3, 200718 yr So let me get a little clarification. Lets say I wanted a balanced beta22. Lets say I have some balanced headphones, but I still want to be able to listen to headphones with regular 1/4in jacks. All I really need is a 4 channel, right? The only point of a 6 channel is so that two people can listen at the same time with unbalanced phones? Yeah, you don't need more than 4 channels for what you are doing. However, if you want to run your single-ended headphones in an active ground configuration, you would still need the 6-channels. It's up to you though: some say that the 3-channel configuration for single-ended usage brings it closer to true-balanced.
