November 28, 20205 yr comment_843978 Hi all, I was advised by some head-fi members to inquire about the technical aspects of this amplifier here. Do let me know if I'm failing to follow any rules; just trying to avoid any catastrophes! Here are the photos of my amp: https://imgur.com/a/sshHA7B The amp is an 8FQ7 SRM-007t rated for 100v 50/60hz outlets. I have a step down transformer (PowerBright) rated for 120v to 100v, and my outlets are, I believe, 120v at 60hz (American). The transformer works fine with my Japanese SRM-252S, but the fuse has blown 3 times now when turning on the 007t (always the 2nd time it turns on; the first time seems to be working). I've tried debugging this for a bit, hence the 3 blown fuses, but I'm not too sure why since the 007t is rated for 100v in and the transformer is rated for 100v out. Birgir kindly helped me debug this somewhat and believes that the most likely culprit is a short somewhere on the board, but I'm fairly inexperienced with more complex circuit boards and having investigated every individual trace on the board could not find anything that looked like a traditional short. If I'm being honest, the board looks relatively pristine if a bit dusty, which I'm trying to clean myself; could anyone help me figure this problem out? The fuses are 1 Amp / 250V 5x20mm, unbranded. I've since bought a handful of extras from a different brand but haven't yet tried them with the 007t. The tubes look to be vintage GE 8FQ7 / 8CG7 tubes, which are apparently the original tubes the amplifier came with, so I am fairly certain that they're not the problem, but I might have to rebias them as it's quite old. There are 3 red lights in the case and the power button is red; I'm not too sure if the lights indicate anything out of the ordinary. Thanks in advance! E: As far as I can tell, the wiring is for 100v; the fuses are in the 1,3,6 positions. I'm not entirely sure about the colored wires coming from the transformer inside the amplifier, though. Report
November 29, 20205 yr comment_844031 take a look at the transformer and see if the 120v windings are cut or not. if they are intact, rewire for 120v. and replace the power electrolytics. Report
November 29, 20205 yr comment_844033 1 hour ago, kevin gilmore said: and replace the power electrolytics. I was thinking this and one does look a little domed in some of the pictures. Report
November 29, 20205 yr comment_844037 you better take a real good picture of the voltage selector block. there are many different kinds. if blue and purple are jumpered together then its 120v if brown and green are wired together its 100v white should be wired to grey the correct fuse for 100v should be 1.5 amp Edited November 29, 20205 yr by kevin gilmore Report
November 29, 20205 yr Author comment_844048 thanks all for the help! 4 hours ago, n_maher said: I was thinking this and one does look a little domed in some of the pictures. which one? i'm afraid i've little experience with caps; the big brown ones seem like they're doming a little bit. 3 hours ago, kevin gilmore said: you better take a real good picture of the voltage selector block. there are many different kinds. if blue and purple are jumpered together then its 120v if brown and green are wired together its 100v white should be wired to grey the correct fuse for 100v should be 1.5 amp looks like they're all hooked up to the voltage selector, and the ones with fuses in them - 1 and 3 - are wired to brown and green, so i guess i just need to change the fuses? that'll be a good deal easier to work with 😅 are there any recommendations for cap replacements? i've done through hole soldering before but never done any sort of replacement for electronics like this; looks like i've got 400v/220uf big brown caps and a handful of small 35v 10uf. i can't quite make out the two middle caps, but i'll find out once i get them off the board i guess never mind, they're 35v 470uf Edited November 29, 20205 yr by chocolates Report
November 30, 20205 yr comment_844139 Here you go chocolate Regarding Voltage input to the 007t The power supply transformer has 7 tap on the input side: Yellow= common (winding 1) 1 White=same as yellow (winding 1) 2 Green=100v tap (winding 1) 3 Purple=120v tap (winding 1) 4 Black=common (winding 2) 5 Brown=100v (winding 2) 6 Blue=120v (winding 2) Six jumper bar for voltage change number 1 thru 6 1 thru 4 are to select:1=100v 2=120v 3=100v 4=120v 5=220/240 6=100v/120v So for 100v you install one bar each for 1,3,6. For 120v you install one bar each for 2,4,6. You will need to do this for your 120v For 220v/240v you install on bar each 3,5. Unscrew the two screw at the back They remove the sStax plate covering the transformer Carefully remove the board and change the desired voltage. Edited November 30, 20205 yr by Mach3 Report
December 23, 20205 yr comment_846193 Hello All, I too need help in rewiring STAX SRM 007Tii Japan 100v edition. I want to rewire it to 240v, if not then 230v would also do. Need the gurus to pitch in, sharing the images from jumper board and transformer. Thanks for the insight in advance! https://i.imgur.com/vkUq9yr.jpg https://imgur.com/z16gvK7 https://imgur.com/QJf6KPx Report
December 23, 20205 yr comment_846196 Remove both black jumpers, move the left hand white wire to the empty spot above the blue wire (so from brown to blue) and finally, put in a new jumper between gray and purple. Also, make sure the gray and blue wires actually go inside the transformer and aren't cut off. Either measure continuity between the next wires or remove the blue PCB on top of the transformer for a visual inspection. Report
December 23, 20205 yr comment_846197 4 minutes ago, spritzer said: Remove both black jumpers, move the left hand white wire to the empty spot above the blue wire (so from brown to blue) and finally, put in a new jumper between gray and purple. Also, make sure the gray and blue wires actually go inside the transformer and aren't cut off. Either measure continuity between the next wires or remove the blue PCB on top of the transformer for a visual inspection. Thank you so much Birgir for a fast response! The wiring changes suggested are for 230 or 240v? I have verified that both blue and gray wires go inside the transformer. Blue and Gray wires Report
December 23, 20205 yr comment_846216 I did the same to mine about 2 years ago to my SRM-600 I think. It had the cut wire to the 240v tap on the transformer, Spritzer help me with this. Then gave me the correct information to sort the jumper for the voltage selection . Should look like this. Edited December 23, 20205 yr by Mach3 Report
December 23, 20205 yr comment_846217 4 minutes ago, Mach3 said: It had the cut wire to the 240v tap on the transformer Thanks Mach3! So you too rewired a 100v to 240v?? I'm sorry I did not get the part "It had the cut wire to the 240v tap on the transformer". Please elaborate a bit. Thanks again. Report
December 23, 20205 yr comment_846221 This is the 240V setting. If you wouldn't move the white wire the transformer would be set to 220V which isn't a great idea these days. That picture of the wires doesn't tell us anything as the windings entering the transformer are not visible. Just pull off the PCB or use a volt meter to measure between blue and brown and then green and purple. Should be a few ohms but if you have nothing... then the windings have been cut. Report
December 24, 20205 yr comment_846260 7 hours ago, spritzer said: This is the 240V setting. If you wouldn't move the white wire the transformer would be set to 220V which isn't a great idea these days. That picture of the wires doesn't tell us anything as the windings entering the transformer are not visible. Just pull off the PCB or use a volt meter to measure between blue and brown and then green and purple. Should be a few ohms but if you have nothing... then the windings have been cut. This makes things pretty lucid for me. Thanks much@spritzer! I shall update here once I am done with the mod. Make take some time as my schedule is fully packed. Cheers and Happy Holidays everyone! Report
December 24, 20205 yr comment_846261 Yeah the picture I posted was for 240V setting. In some of the energizer Stax cut the wire for the 240V winding. I had to resolder the winding using off cut wires. Report
December 24, 20205 yr comment_846283 See that last post (blue binding) they cut the cable. Check if you're has the same issue. If not all good. Report
December 26, 20205 yr comment_846524 On 12/24/2020 at 3:38 PM, Mach3 said: See that last post (blue binding) they cut the cable. Check if you're has the same issue. If not all good. Hi, @Mach3 @spritzer. Exactly the same issue with me. Purple and Blue wires are not connected to transformer windings. What are the next steps? Please share them over pm. Is it even possible. Thanks again for the support this awesome forum is extending. Report
December 26, 20205 yr comment_846528 If there is enough copper there to solder a wire to, then it can be fixed but I've come across some units which were beyond hope. Report
December 27, 20205 yr comment_846578 19 hours ago, spritzer said: If there is enough copper there to solder a wire to, then it can be fixed but I've come across some units which were beyond hope. Mission accomplished!!! Pics for your viewing pleasure. Job may not be neat but serves the purpose really well. 🙂 Album - Rewiring to 240V step wise Many thanks to @spritzer and special mention to @Mach3!!! Report
November 9, 20214 yr comment_868740 Hello! Got a quick question. I have a Stax SRM007t (mk1). Older version with pin jumpers. It’s currently got the jumpers set for 100V (1,3 and 6). I think for 240V you use two jumpers on 3 and 5 only and don’t use a third pin but wanted to check in case that’s for 220v (As I really need 240V for sure as my electricity is near to 250V). Any advice would be much appreciated. Report
November 9, 20214 yr comment_868745 Here is the code: 1,3,6 is 100 volts 2,4,6 is 120 volts 3,5 is 220 volts 2,5 is 240 volts Report
November 9, 20214 yr comment_868760 2 hours ago, spritzer said: Here is the code: 1,3,6 is 100 volts 2,4,6 is 120 volts 3,5 is 220 volts 2,5 is 240 volts Thanks so much!. I had a feeling 3.5 was wrong! Report
April 8, 20224 yr comment_879877 Hello everyone. Found this extremely useful topic, while looking for a way to convert my SRM-007tA from 100V to 240V (220V). While all seems to be explained quite a handful of times, I just wanted to confirm it once more, because I'm pretty scared to not ruin the energizer completely. I do have some questions as well, but first - some photos of the inside of the unit: (not sure if the last photo is relevant at all) It seems like there's just enough copper to solder some jumpers in order to connect the blue and purple wires to the transformer, so I'll do that first. Next is the voltage selection change. Here are the questions: 1. I see couple of options being mentioned here from users, who did exactly what I'm willing to achieve. While both move the white wire from Brown to Blue and removed both black jumpers from their initial position, one of them left the purple wire at its place an put a jumper between Grey and Purple, while the other person moved the purple wire above the grey one (no jumpers used). Does that lead to the same result and which is the better option? 2. Do I need to apply any isolation to the jumpers that I wire to the transformer? 3. I see 220V and 240V being mentioned here - what is the difference and which one is preferred? I think the SRM-007tII is set to 230V, but I don't see that voltage being mentioned here at all. 4. Might be a silly question, but still - the bias on my unit has been adjusted due to tube upgrade. Does that affect the procedure above at all? 5. Another silly question - if all soldering and wiring is done correctly following the guides here, is there still any risk of something going completely wrong? Thanks a lot for your help! Report
April 8, 20224 yr comment_879881 Restore the cut windings, move the white wire from brown to blue on the voltage selector board, remove both black jumpers and replace them with a single one from gray to purple. That is the 240V setup, never use the 220V one. The amp has unregulated power supplies so the bias will drift with the input voltage. Report
April 8, 20224 yr comment_879902 3 hours ago, spritzer said: Restore the cut windings, move the white wire from brown to blue on the voltage selector board, remove both black jumpers and replace them with a single one from gray to purple. That is the 240V setup, never use the 220V one. The amp has unregulated power supplies so the bias will drift with the input voltage. Thanks a lot for the reply. Can you kindly elaborate a bit about the bias adjustment - if it drifts after the input voltage has been changed from 100V to 240V, will it have to be readjusted? And if it's left untouched, how will that affect the unit's performance? And last thing - do I need to apply any isolation to the the jumpers that I wire to the transformer, or I can leave them soldered only? Thanks again! Report
