CanJam NYC 2023: February 25-26
15 hours ago, AudioGD said:
What do you think of Grand Cayman?
it was great!
  • Replies 136
  • Views 38.3k
11 hours ago, spritzer said:
I only spent a few minutes with it using the new DCA and Shangri-la SR with an unfamiliar source so I can't really comment on it.  No issues I could hear but I'd need to spend some more time with it.  It's an impressive beast though.  :)
I forgot to mention I also tried the Warwick Audio Bravura... what a piece of shit that is.  Now the amp was broken so no high gain mode available so I couldn't push the volume far enough.  Still it is the blandest sound imaginable, it does nothing well and you can clearly hear the DSP doing its best to try and fix the sound of the single ended transducers.  I suspect this will be far worse when the volume is pushed to normal levels.
I actually have a couple of the Sonoma M1 headphones (dirt cheap now) and was planning on designing an amp for them (the Bravura uses the same amp) but I might not bother.  They clearly can't work with a direct signal so my plan is to just reuse the housings and design proper electrostatic drivers that fit in there.
What do you think of GC versus T2?
The only way to answer this question is probably to listen to both. I recommend buying both.
20 minutes ago, Voltron said:
Didn't you get your answer already?
I was asking my engineer idol Spitzer:)
If you were really listening, then you wouldn't have anything to do with AudioGD, let alone name yourself after them.
I actually don't mind AudioGD stuff, have a couple of their cheaper items in the past.  But every time I see their name I can't help but picture this in my head
I don't really know or care about AudioGD but back in the day there were many douchey fans so it still has that connotation in my mind.
