The Orthodynamic Thread
You're definitely spot on about that. I just thought it was a little weird that it sounds like the stock T50RP has tighter or as tight bass than the heavily modded YH3.
I am just not feeling all this T50RP love .... yet. Earl sent me his set to tinker with and I have to say that they don't stand a chance against any and all of my ortho's (including my SFI) . They actually sound a little like the very first SFI I made - overpronounced mids, nice high end , bass representation of lower frequencies but little or no impact. The tonal balance is also way off to my ears, if I had picked these up stock as a test, instead of F2D, I would have most likely not recommended them at all. These are "burnt" in so this is not a factor here. Perhaps my ears are just expecting too much after using the YH1K as my goto headphone for the past month, ( yes I did dress her up and added some underwear - couldn't let her go around indecent for such a long time ). Time & tinker will tell if I can get them to shine ..dB
  • Replies 929
  • Views 202k
  • mypasswordis
    mypasswordis
    So apparently monoprice cloned the Audeze LCD-2 and is selling them for $300 Left is LCD-2 and right is M1060 Released last week and monoprice website says it's out of stock until mid-April
  • kevin gilmore
    kevin gilmore
    got them, the connectors are pieces of crap, one side is intermittent if you shake your head hard, but sound wise pretty comparable to my lcd2 may actually be built a bit better
  • mypasswordis
    mypasswordis
    Yo leeperry, I see you screenshotting my above HC post in your HF FS ad, so I'ma screenshot on HC your screenshot on HF of my above post on HC:
Well if you look up my first post about these you will see that it was not a gloving review ;)
I like them but I still think they about at the level of YH-1 or T20, a bit better in many ways.
So far non of the orthos I heard reach to the level of any Lambda variants. I would love to hear YH-1000 to see if it's close to O2. I bet the bass impact is very nice as with all the orthos. But how is the soundstage?
I was thinking... As you might now I am a soundsatge freak. I can't image YH-1000 having soundstage beyond normal type headphones. The drivers are not angled and non of the headstage shaping technics are in place, does YH1K have good soundstage, what caparisons can you provide?
Well, I thought the stock sound was dominated by the bloated low mids because of the resonances from the cups. As I keep saying, once I added some damping to the cups and a layer of felt on top of that to absorb backwave, the bass punch/impact I get is huge. Easily the most of any of my headphones. Everything becomes more right and you can begin to start tinkering like you would normally do with the other orthos. Well, minus the front fabric; I'm still not sure whether I should cut a hole in it. I think the lightning fast and huge punch is partially provided by the decoupling of the drivers to the cups using the little rubber things, which doesn't really work until the cups can handle it.
Faust, you have to hear my T40. Sure, it's not going to beat out your Sigma or even your Lambdas in size of soundstage, but it's nearly at the level of the Lambdas, which is better than most orthos, and I think the soundstage is slightly better defined as well.
Heh, well as we all know everyone has preferences. Unmodded I still like the T50RP, modded I lied them a lot, extreme modded I love them. That doesn't mean anyone else will, I generally prefer the various Fostexes to the various Yammys so a lot just comes down to the type of sound sig you prefere.
I spent the last two days listening to the T30 and now T50v2 and they all sound wonderful to me.
Smeggy, any tips to make those T30 a bit more comfortable? I received mine a couple of days ago and I'm liking what I'm hearing, but the damn things give sore ears pretty quickly. And I'm not specially finicky about that, I can wear the Grados for hours.
Also some comments about how similar/different are the TR50RP and T30 would help to make my mind up about getting a pair of TR50. Thanks.
I spent half a day today with my "basement setup", the T20 and my small Yaha, and I was surprised at how good they sound after having ignored them for a while. Fostexes have a lot going for them, once they are properly damped.
First, congrats on getting a T30. The two headphones couldn't be more different internally. The T30 has an open back and a huge (~60mm) driver, and the T50RPv2 (which is not the same as a T50v2) has a little driver with about the same surface area as the little SFI driver (38mm) and a closed back with a little vent. The T30 is bassy and the T50RPv2 is midrangey.
Neither is perfect, both need work, but the T50RPv2 will need less work to get it sounding good and is easier to work on. A real orthonut should have both.
I still don't qualify as orthonut, but I might hehehe. I've been reading posts at HF and here about the T30, but seems they're not as popular as other models, and didn't find much information about tweaks to improve the sound.
I've been doing my little experiments and I've noticed that placing the driver a bit further from the ear but keeping good seal (I used a set of CD3000 pads over the phone "as is") makes the bass more balanced to the rest of the spectrum and gives a huge amount of air and more natural decay to the treble. However the midrange suffers and gets a slight honky coloration, losing body and the right timbre they have IMHO. I suppose I'd need to make the current pads a bit thicker and also more comfy by using a material more skin friendly than the plastic it uses. Have you performed any pads mod or replacement on the T30?
I also think that some benefits could be obtained by damping a bit the enclosure internals to get rid of a small resonance at about 50Hz, but I fear that overdamping could make the bass too fast to sound natural. Also some reflective material on the driver's back might increase the treble output, but I wouldn't do that until I had changed the pads, since using thicker ones already brings the treble out.
Any suggestions will be very welcome. I'm not a DIYer to make my own enclosures, which I feel would be the optimal solution, and also making a less clamping headband which allowed drivers twisting to fit the ears skew to the frontal plane. Have you "transplanted" the drivers into another enclosure like Beyer's or any other with success?
Sadly I can't offer much help on the T30 sound or comfort as the first thing I did after a quick preview was to remove the drivers and put the rest in the parts bin. Nothing about my T30 is original but the driver. It has a more open back woody, felt, different headband/pads and homemade swivels.
LOL, make a clone of that and send it to me hehehehe. Pics?
Poor Pro30s :)
Ah, but that's the thing. My mod doesn't affect the Pro 30. The two cups are interchangeable. I can remove the T30 cups with the thumbscrews and snap the Pro 30 in place. I made sure I didn't mess up the locking clip for the Realistic . :D
Still waiting for the damn post to deliver the smeggyfied YH-1. Damn...
Italian post postino1.jpg seems like your local postie got distracted!
That's great! I didn't know you'd done that.
What did you use for the back grille? Is that "bin screen" again?
Heh, yes. Bin grille courtesy of Staples :)
The pro 30 band, all I did was file off the end pieces to make the bottom flat, push the lock button in and drill through the top. The cups would stay on without the nuts as the clamps grip the thread. Worked out pretty well.
I recieved my T50RP today and spent some quality time listening to them. I have some great contact cleaner, but I'm confused about the locking cord. I can twist to unlock the cord, but I thought it would be easily detachable once unlocked so that I could clean the contact there. Mine isn't so.
EDIT: I took some pliers to it and got it. I know, if you have to force it, your probably not doing it right, but it had it coming.
The locking connector should be able to come straight out. Mine was a bit hard to get out the first time and I had to wiggle it a bit before it came loose but now it comes out easily.
No innuendo.
Edit: Nice job on the innuendo, manaox.
No, mine didn't want to come out either. I resorted to pliers in the end.
Oh, and congrats :D
