May 25, 200818 yr Where to buy a stax 5 pin female plug? Allied has stopped carrying them so your best bet is to find a SRD-4 and remove connector. Some of the Stax distributors might still sell them in small quantities...
May 25, 200818 yr I bought my 5 pin female connector from [AK]Zip, I haven't had a chance to violate it with Omega 2's male plug yet
May 25, 200818 yr or I will take one from my SRM-727II You wouldn't be the first to go down that road. You could even add a HE90 connector in stead of the missing Stax plug. I bought my 5 pin female connector from [AK]Zip, I haven't had a chance to violate it with Omega 2's male plug yet Ehhhhhh.... now I feel violated....
May 25, 200818 yr Ehhhhhh.... now I feel violated.... Because the Stax connector is better than an OEM? I'm not sure what brand the one I bought was.
May 25, 200818 yr Because the Stax connector is better than an OEM? I'm not sure what brand the one I bought was. I was only violated by your words... The Stax connector is pretty crappy and breaks far too easily but I like it more then the WPI unit you have if only for the fact that no builder bothers to plug the 6th opening for Pro sockets which could end pretty badly...
May 25, 200818 yr I was only violated by your words... The Stax connector is pretty crappy and breaks far too easily but I like it more then the WPI unit you have if only for the fact that no builder bothers to plug the 6th opening for Pro sockets which could end pretty badly... I could see bad things happening... [me=deepak]takes BH to meet, unsuspecting newbie plugs in regular bias Stax [/me]
May 25, 200818 yr Where to buy a stax 5 pin female plug? Hmm i've had this question multiple times lately. You can still get the WPI connector from Arrow
May 25, 200818 yr I could see bad things happening... [me=deepak]takes BH to meet, unsuspecting newbie plugs in regular bias Stax [/me] All you have to do is either fill the center pin with solder, or remove it from the front and put in a black screw and nut.
May 25, 200818 yr All you have to do is either fill the center pin with solder, or remove it from the front and put in a black screw and nut. A screw would be a good idea as the WPI sockets have exposed contacts so the middle should be elevated a bit. I've used plastic bits that I found around the house which are supposed to be used to cover up holes in cupboards for movable shelfs with good effect. Too bad they are white... \
May 26, 200818 yr yes, but they use white ink. How that hell would we otherwise keep the glaciers looking so good?
May 26, 200818 yr heh... would there be interest in a clone of the socket used on the Illusion? Cost would be pretty expensive, probably around $100 US. I would use the same type of pins and a teflon body. I don't have a good (cheap) source for the pins, so I'd have to buy another component that uses them and then repurpose the pin sockets, and this would be one reason the cost would go up. The other is a small number would be built, i.e. limited production. The teflon rod isn't as much as I figured it would be, but it still adds up. I'm thinking about going down that path myself regardless of interest, and perhaps once a prototype is done we can talk about it some more.
May 26, 200818 yr heh... would there be interest in a clone of the socket used on the Illusion? Cost would be pretty expensive, probably around $100 US. I would use the same type of pins and a teflon body. I don't have a good (cheap) source for the pins, so I'd have to buy another component that uses them and then repurpose the pin sockets, and this would be one reason the cost would go up. The other is a small number would be built, i.e. limited production. The teflon rod isn't as much as I figured it would be, but it still adds up. I'm thinking about going down that path myself regardless of interest, and perhaps once a prototype is done we can talk about it some more. You know I'm always interested in your crazy ideas...
July 26, 200818 yr Author Hmm i've had this question multiple times lately. You can still get the WPI connector from Arrow What is the part number?
July 26, 200818 yr 78-S6S is the socket 86-71-6S is the plug These are the WPI P/N's so they should work everywhere.
August 9, 200916 yr Author 78-S6S is the socket 86-71-6S is the plug These are the WPI P/N's so they should work everywhere. hmm... they both are female plugs. Which is the correct one? And can we find the PN of the male plug?
August 9, 200916 yr 86-71-6S is actually the male plug but the picture on the Allied site shows the back of it. You stick the wires through the plug to solder them.
August 11, 200916 yr Author I've found some sockets from Amphenol: New-Old-Stock Miscellaneous Brand Tube Sockets They are the 6-th position from the N-O-S list. Are they the same as the WPI's?
August 11, 200916 yr They sure look the same, and to my understanding, WPI just bought Amphenol's old tooling.
April 28, 201115 yr Happiliy diggin up a corpse here, but I am currently in need of a Stax Plug (6P) in Europe. Cooper 86-71-6S or 91-MPM6S should do (which apperently are from the old WPI old Amphenol molds); however I could only find them at Allied who only cater US & Canada. Does anybody know of a source for these that ships to Europe/Germany?? Background on this: I recently bought a NOS Beyer ET1000 but I want to get rid of the ugly transformer box that came with it and use my Stax amp with them..
