FOTM: 5-pin Headphone Jack
heh, but seriously.
If you only have room for a single jack, and want to support balanced (4-channel bridged) and single ended cans, what do you do?
Two options as I see it.
Use 4-pin jack and tie ground to the shell and/or case or use a 5-pin jack and have a dedicated pin for ground. If the first case, I'm not sure if there are 4-pin female jacks where the where the "shell connection" can be isolated from the case. If this isn't possible, then is 5-pin the only real option?
I cannot believe this hasn't come up before. Thoughts?
I think there is some standard, IEC or something, which specifies a 5 pin xlr for balanced headphones. It does make a good deal of sense.
It would make sense if anyone else did it. Go 4 pin or go home :)
meh. I'd like a way to convert to single ended and only have a single jack...
sorry, no way no how can you convert 4-pin to single ended.
what if your amp design allowed the 2 minus outputs to be shorted
heh, you're quick. I cannot see why that wouldn't work, but then again, I could imagine designing for that condition..
Edited by luvdunhill
right. otherwise, there isn't a way to connect a single ended headphone to a 4-pin jack.
I'd be worried about noise in that case. If the shell cannot be isolated from the outer connector, it could be a source of ground loops and other nasties. Why not go through the trouble of supporting single ended headphones?
So make room in the case for a single ended jack? :)
I only have room for one jack :)
Oh, it's L+/L-/R+/R-/GND so that you can tie in just L+/R+/GND for single ended and not cross grounds.
You mean, three-connector, right? Because all dynamic headphones are two single-ended drivers. It's just a matter of how easy it is to access that point where the 3 wires become 4, right?
I agree with "provide a separate jack" for those.
wait, I thought about this... even if you can do this (which by the way, I thought of a case where you could do this, a concertina output 'cause I did this in my preamp, but not much good at driving much of anything), how would this work with a single 4-pin jack? just because you can short the minus to ground, doesn't mean you can short them to each other and get a usable reference
and, Dusty I just mean use a single jack. You need a ground reference for the single ended headphone option. Adapters are fair game.
All this to say, I think finding an isolated four pin jack with a separate shell connection is the way to go...
Alright, so the two hots go to L/R +; ground gets split and sent to L/R - of the drivers. Right so far?
On the amp side of the same sitch, where does L/R - go? Unterminated? Loaded? Switched-in-loads? Switch out those half of the amps (so that they don't present some weird load, and yet are green and don't consume power at the same time)?
The case I am discussing is the unreterminated single-ended headphones discussed earlier.
Not sure about that shell connection.
Dusty:
Yeah, that's right. So far. So, you're asking the same question on the amp side. The L/R- is unterminated. I definitely don't want a switch there.
So, in summary the problem is with a 4-pin jack, or even two 3-pin jacks, that are used on the output of a four channel design, you cannot "convert" this using any combination of adapters, custom or otherwise, for use by a single ended terminated headphone. You need a ground reference.
