On 3/4/2022 at 2:13 AM, EdipisReks1 said:
Pic is after dosing with the Weber Blind shaker. I used my knock off OCD, but I could have gone straight to tamp.
That is a very HC image - almost two of everything... B)
  • Replies 1.6k
  • Views 354.3k
  • This could be trouble. First results were very promising, if not entirely drinkable.  I'll toy with grind just a big more to get a full extraction but tomorrow morning should be fun and int
  • ^^ enjoy I was lucky that Sonja brought a Breville to the relationship.. (larger style with grinder, etc.) After several months of Costco coffee living out of the airbnb - we unpacked the ro
  • The Niche Zero arrived last week and I've gotten to use it.  So did the Chemex.  I chose the 6 cup which worked out well for my situation.  I'm the only coffee drinker in the house, but if I have a gu
Almost?! I have like five of some!
Normcore portafilter fixes my issue with the stock portafilter being too light.
Edited by EdipisReks1
Made that steamed iced americano thing. It’s super good! The texture really is like a nitro coffee, but it doesn’t taste bad because it’s not cold brew crap.
I think I’d go a little shorter on the water/espresso ratio next time. But it’s super good!
Normcore portafilter is great. It feels wonderful in the hand, and is super well machined, so it locks into the group easily but also solid as a rock. Also also it’s a big ol’ chunk of metal: who wouldn’t like that?
The basket it came with is not, however. It’s a perfectly fine precision basket, but the shape doesn’t let dosing funnels sit securely if they aren’t magnetic funnels. I have a magnetic funnel, and it’s fine, but I prefer to use the Weber blind shaker, which is not (at least not in that way: the magnetic bit is in the base of whatever you call the thingie that you remove to dose the coffee; it sticks to the neodymium magnet I put in the base of the Niche, but doesn’t stick to a basket).
So I bought an IMS baristapro 18g. Of course the Normcore basket was part of how I convinced myself to get the portafilter, but I didn’t buy that this week so it’s okay: new week new shit!
Single best pull I’ve ever done, I think, and this is what I do with it.
It is admittedly very good.
Too bad I wasted this on a cafe mocha. It was, admittedly, a very good mocha (I make a vegan/sugar free cocoa syrup).
On 3/11/2022 at 8:12 AM, grawk said:
That should really have an analog gauge for that price.
It is a good looking machine and I’m sure it pulls good espresso, but you can’t profile without a general idea of the pressure, which defeats the point of a lever.
I also think a straight lever on a 58 is… a decision. You lose a lot of mechanical advantage. Straight lever works great on a smaller portafilter; taller column changes the pressure distribution. You can pull a shot on the Flair 58 with your chin.* Less mechanical advantage is going to mean less precision.
This is assuming the full manual has the same arm geometry as the spring version.
*the Flair is hardly perfect, but the curved lever is not one of its many flaws.
