September 5, 201115 yr comment_468168 Tapatalk "new topics" has never worked for me since the upgrade. Report
September 5, 201115 yr comment_468173 still have to manually enter tags in mobile safari when posting... Report
September 7, 201115 yr comment_468442 Does anyone else have a problem going to the last post in a thread when using the mobile theme? Report
September 7, 201115 yr comment_468448 Yes, it appears that clicking a thread link in the view new content brings you to the first post instead of bringing you to the post that you read last. Same behavior in the mobile theme. Report
September 7, 201115 yr comment_468457 You click the star on the left and that takes you to last unread, I believe. Report
September 7, 201115 yr comment_468478 I miss Simple Machine Forum... Oh, also, in chat, a few of us are having problems not being able to do IMs. Sometimes it works, sometimes it doesn't. Happens to me in Chrome on my Chromebook, but I've seen it with at least PC users as well. **BRENT** Report
September 7, 201115 yr comment_468490 You click the star on the left and that takes you to last unread, I believe. Yeah it does most of the time.... but sometimes you're SOL as best I can tell. Report
September 7, 201115 yr comment_468491 You click the star on the left and that takes you to last unread, I believe. Thanks for that. I usually had to tap on the subforum tab to bring me to the list of threads, then tap the actual thread title, this always brings me to the last unread. Report
September 7, 201115 yr comment_468504 Thanks, Al, that helps. It doesn't always take me to the last post--it seems like maybe last post I read(?). But it's better than the beginning of the thread. Report
September 7, 201115 yr comment_468513 The star at least gets you close to the end. Does anyone else still use Tapatalk? I cannot seem to get the "latest" page to show unread posts, and I have tried logging out, deleting, resetting, etc. Tapatalk also cannot read various stats or user info, although I am not sure it could before the upgrade. Edited September 7, 201115 yr by Voltron Report
September 7, 201115 yr comment_468520 The star or circle, it seems, should take you one past the last post you read, not the last post. Edit: I think the Star shows up when you have a post in the topic, a circle if you don't. **BRENT** Edited September 7, 201115 yr by MexicanDragon Report
October 17, 201115 yr comment_475031 I am still seeing read threads in view new content, is it broken again? (Not on a mobile browser, on FF7) Report
October 17, 201115 yr comment_475091 Which sorting option are you using? On a separate note, I noticed that the author field in the search results for a thread all refers to the same person. Can we fix this? Report
October 17, 201115 yr comment_475098 edit: I think I fixed it. Was some weird cookie issue in my browser Report
October 23, 201115 yr comment_476111 On a separate note, I noticed that the author field in the search results for a thread all refers to the same person. Can we fix this? Looks like it's fixed. Thanks! Report
