This stream auto-updates
  1. Past hour
  2. Hi Birgir Thank you for your interest in this topic. I just can't find a suitable slow-blow fuse =( Its dimensions should be 6x30 or 6.2x32 or something like that, it should be rated for 250v and 1.5a and be a slow blow.. So I thought I could use a higher-amperage fast-blow fuse for timing tests... Hi Kevin, thanks for your comment. Well in my 220-volt network, the voltage sometimes rises to 230... So I thought it would be a good idea to put jumpers on 2 and 5... instead of 3 and 5.... just to have some reserve... It seemed to me that it's better to have a reserve of -10 volts than +10.. As far as I understand, the power supply here is unregulated and exceeding the input voltage is a bad idea...
  3. Today
  4. you do not have the jumpers in the right position for the voltage you need. the voltage rating on the fuse is meaningless.
  5. Post Hipster, Home Cooked, AI Fish Curry
  6. AI Fish Curry, Cooked by a "Post Hipster Home Cook, apparently
  7. Yesterday
  8. If the fuses are blowing, then something is wrong somewhere. Never use fast blow fuses, let alone 30A. If the fuse manages to hold and something is shorted, do you want to dump 2.4kW into the amp? No...
  9. Hi Kevin Thank you for your interest in this topic. Yes, I set the jumpers to positions 2 and 5. When I bought it, it had a 220V 1.5A fast-blow fuse. But after a few months, it failed and blew. Today, I bought the same one, 1.5A, and even 2A – they both blew instantly. Since I can't find a slow-blow fuse, I bought several fast-blow fuses, 10-20-30A, and I'm thinking of trying them. But I'm afraid to do that because I'm not sure it's just the fuse.... By the way, I measured the transformer resistance on the 220V plug that plugs into the outlet—it's only 12.7 ohms. I'm not sure that's how it should be...
  10. are you sure of the jumpers for the voltage you are using. if jumpered on 100 or 120v and you put 220 in it, fuse will blow instantly. but you do need a slow blow fuse.
  11. Good day, dear gentlemens. my stax 717 blows the fuses at the input of the transformer 220v 1.5 fast blow. do i need test slow blow or fast blow 30A fuse? If I decide to install 30A, is there a safer way to do it, like connect it through an incandescent lamp or something like that? What is the normal resistance of the windings of this transformer in 717 should be at the input on the socket? When I bought it, it had a 220-volt, 1.5-amp fast-blow fuse installed. But according to the schematic, I need a 220-volt, 1.5-amp slow-blow fuse. But I can't find one anywhere yet. By the way, I measured the transformer resistance on the 220V plug that plugs into the outlet—it's only 12.7 ohms. I'm not sure that's how it should be... any advice is welcome
  12. Rest in Soft Rockin Peace "& Crofts" https://www.tmz.com/2026/03/26/dash-crofts-dead/#
  13. Watching 21-year-olds get their brains rearranged by amazing old songs is extremely rewarding. Actual quote: "Fucking hell that might be the best intro ever?" 🤷‍♂️
  14. After another week of testing I like the outcome of the latest CFA3smd something with the dual opamp bias servos. Thanks a lot Kevin. My version is a Zero Feedback version of CFA3. I’ve heard, read, that some people favor the Super Symmetrical version. So, here is a drawing drafting of a ZF/SS version of CFA3smd something with… … six small Omron latching relays. Five for ZF/SS switching and the sixth for LED identification of mode in progress. Two JST XH3 connectors for a momentary toggle switch and LEDs to control the ZF/SS modes.
  15. Last week
  16. That's excellent news as I liked the latest version I heard, V3.0 I believe. The amps are pretty poor though but better than the first version
  17. It was sold on goofish, goofish is the largest secondhand trading platform in China.
  18. I know the designers at Halo Acoustics, they are currently expanding into overseas markets and will soon be selling in Europe this year.
  19. They are a notorious chinese workshop specializing in the production and sale of counterfeit headphones. There are now many workshops in China specialize in producing counterfeit headphones, with zmf, abyss, beyer, and sennheiser being the most affected.
  20. Do you have a photo of the inside of the black ones? Are there King Sound drivers inside? i also saw this one
  21. Louis Rossman has several cats. Mr Clinton is 17 years old and has heath issues, but is as adorable as ever.
  22. LOL, hell no, I don't gamble. Insider info is worthless in this situation. Hegseth is Trump's bitch, and Trump is a loose cannon -- he's Daenerys from season 8. And don't get me even started on the Iran side...or the Israel side...or the NATO side...it's like...the opposite of a love triangle. A war irregular polygon. Hollywood couldn't write this shit.
  23. Katsu tofu with Japanese curry
  1. Load more activity
