Now for something different...
That worked, thanks for the tip  :laugh:
In other news, I fixed the offset-issue. Didn't have to do anything except realize that the servo op-amp is a dual-OP and not the usual OP27  ::) Note to self, read the schematic properly FFS! :mikey2:
//UFN
  • 3 months later...
  • Replies 426
  • Views 150.5k
  • kevin gilmore
    kevin gilmore
    So here is how this went down. Someone over there really pissed off Birgir. Its not nice to piss off the head of the stax mafia. I mean its REALLY NOT NICE to piss off the don of the stax mafia.
  • I like to build pretty much anything so why not this? I've built 3 Egmonts (and I'm working on a fourth) when I could just as well build a ESX. Why am I working on old Stax amps when I could just as
  • I understand pursuing it for your own knowledge and benefit but it's the production of boards that doesn't make sense to me. I'd argue that none of those people are going to change their minds r
what value of input pot should be used on squarewave klone? read 10K somewhere before but I can't find it
or maybe should use higer value like 50K/100K since it's fet input? thanks
Edited by ang728
Thanks !
well I do 10k, just because I don't want too many different versions in stock.
but 50k or 100k works fine for this
  • 3 months later...
finally finished the build with some sp style wiring ;)
I like that one a lot!!  :)  I have a pile of these that I need to finish at some point as it is a really good amp.
Any troubles with that feedback switch?
Thanks!
besides not as "hi gain" as I thought , actually they work well .Love that sound with switch on
btw,I am curious about how does this feedback design work in the circuit , any paper or keywords that I can learn from ? :)
Edited by ang728
  • 5 months later...
What would the current draw be for a balanced version? Inside or outside GRLV range ( think I saw 1,5 amps somewhere)?
I put them on lab bench psu before,can't remember what's exact number of current draw,but I'm sure under 1.5A
then built a slimmer case version a while ago using orginal GR and works pretty well
Edited by ang728
  • 4 months later...
On 2 december 2014 at 10:03 PM, kevin gilmore said:
about 120ma, measure across the 10 ohm resistors
Just double checking: 120ma, not mv? Can't get near the ma version, so thought I'd ask before pulling things apart...
YES,it's 120mA,you should have 1.2V reading across 10R
but 100mA-110mA sounds best IMO
Great, thanks! Can't get more than halfway there, so I've screwed up somewhere... Makes for a nice evening of troubleshooting :)
Ok, not so long evening, a bad solder joint it was. Nice and steady at 120 ma now. Guess I have to go watch a movie instead. Boring :)
Many thanks for both of your very quick responses!!!
Edited by MLA
  • 2 years later...
Sorry for refloating this thread.
I'm listening to my "SquareWave KG latest version" in SE configuration. (Thanks Dr. Gilmore)
It works great and is very simple to assemble. I have regulated the BIAS @ 120mA without problems and could even raise it much more.
I have used a 100K resistor to make the servo act as fast as possible and from the beginning the offset is 0 Vdc so I don't need wait for listening music. I matched all the transistors as best as possible but with the MJE200 and MJE201 it was impossible to find an identical pair. ?
The next step is to install it in a box but I'm hesitating, Is it worth making a balanced version? Is there much difference between the SE vs. Balanced version?
I have enough material and pcb´s to do this without problems but if this does not make sense, I'll leave it in SE configuration.
Edited by jose
Thanks Dr. Gilmore.
Yesterday I was listening to the Square Wave with different headphones (hd800, W5000 ....) and I was wondering if the output impedance changes when changing the gain (Low to High)?
I understand that if he does it, I do not know exactly how much or if the change is very radical.
  • 3 months later...
Just warmed this up, sounds terrific. Think I'll populate the other two boards for a balanced Squarewave.
I'm glad to see another Squarewave alive.
The Squarewave does not sound bad but IMHO dynalo is superior: More balanced, more musical ...
Thanks. Thought the Squarewave would be a nice complement to the Dynalo.
