December 9, 20178 yr comment_780445 Thanks @luvdunhill! I'm using the buffer with the ubal/bal board which have a 1.3kohm resistor to ground on the output so i don't think an additional resistor is necessary. Plus I already have the PCBs and the pins match. I am interested in buffers for another project though. Ill let you know. Report
December 10, 20178 yr comment_780457 cspirou: I would add an input resistor to ground as well. You can match Q1 to Q3 and Q5 to Q7, but I don’t think matching is all that useful here. If you want to try another small SMD buffer, let me know. I have just ordered some boards now that I have verified their performance versus sims. I can include matched Toshiba JFETs and the other dual package BJTs are available at Mouser. Those look pretty sweet Marc!Sent from my iPhone using Tapatalk Report
December 10, 20178 yr comment_780503 what transistors are you using?I am using 2SJ106/2SK208, BCM61/BCM62, PHPT610030-series.The 2SJ106 is the SMT version of the 2SJ103. The 2SK208 is the SMT version of 2SK246. Report
January 5, 20188 yr Author comment_782279 On 1/20/2017 at 9:59 AM, kevin gilmore said: it had better look like this the output impedance is about 1k, working on the diamond buffer output now I'm going to order the transistors for this and the buffers. 1. I know that I have to match for hfe and Vbe but do I match all the N together and the P together or do I match N to P? 2. The highest hfe is the BC546\556 C, this only comes with formed leads. Will I need to straighten them out, and if so I'm guessing there's no issue with that? Report
January 5, 20188 yr Author comment_782284 good question, it may say on the silkscreen. I'll look at the board Nope, I was hoping. We'd have to ask kevin Report
January 5, 20188 yr comment_782291 Thanks Pars. On our boards we haven´t any reference. I guess that we can use the OP27 on the buffer too. Report
January 5, 20188 yr Author comment_782293 So should we match P to P and N to N? Or that plus P to N? Report
January 5, 20188 yr comment_782296 If nothing says otherwise, I will try to match as closed as possible P to P and N to N. Report
January 23, 20188 yr Author comment_783568 I ordered BC546B\556B I couldn't find the C for both. Anybody see a problem with the B? Report
January 24, 20188 yr comment_783577 2 hours ago, sbelyo said: I ordered BC546B\556B I couldn't find the C for both. Anybody see a problem with the B? C has the highest hFe. B might be okay if you measure a bunch and take the highest measuring ones. It seems to be in stock here: https://www.tme.eu/en/details/bc556c-dio/pnp-tht-transistors/diotec-semiconductor/bc556c/?utm_source=octopart.com&utm_medium=cpc&utm_campaign=compare-2018-01https://www.rocelec.com/part/FAIFSCBC556CBU I haven't ordered from either place so I don't know what they are like. Report
January 24, 20188 yr Author comment_783578 That first place had them both... Darn, guess I didn't search hard enough. I ordered 250 each of the B from arrow and a transistor tester off ebay. We'll see what kind of numbers I get. Report
January 30, 20188 yr Author comment_783974 the transistor tester measures hFE and Vf. What's are acceptable values for this circuit? How closely should I match the devices? Report
January 30, 20188 yr comment_783989 I’d match for hFE, but also try to get Vf (also known as Vbe) as close as possible as well. I’d shoot for 5% if possible. Matching the N and P is often nigh impossible depending on device type. You just have to do the best you can.Sent from my iPhone using Tapatalk Report
January 30, 20188 yr Author comment_783990 Got it... Is an hFE of 300 good enough for this circuit? Report
February 3, 20188 yr Author comment_784219 The majority of what I'm seeing is 315 hFE after measuring 34 devices. Is 315 good enough? Report
February 3, 20188 yr comment_784222 I would think so. That is in the upper half at least of the range for B devices. Report
February 3, 20188 yr Author comment_784223 cool... I should be able to get them all tightly matched then. Report
March 5, 20188 yr comment_785969 BTA is the newer B designation. Just wondering if MPSA06/56 could be used in place of these? Pinout is backwards (EBC vs. CBE for BCs). Report
