  • Replies 2k
  • Views 376.6k
  • Finished the mini bedroom audio rack with Rubio Monocoat and glued it up. Now in place and making me happy. Also shown are the Bendy Head headphone stand from Peter @Iron_Dreamer and coasters from Nat
  • I had previously talked about the bookstore I'm working on. It's almost open for business and I thought I'd show a few of the projects. The shelves are all solid Cyprus. The boardwalk in the back is R
  • Change of Command is this week, which means I get my 4th boss in three years (FML) so I decided I'd fabricobble the command gift.  The outgoing skipper is a Navy diver who has a penchant for clapping
Would you really want Brent operating heavy machinery?
Well, maybe you would.
Spent way too much of my time today fixing broken blast gates and the shitty planer so ended up giving up on milling the workbench top and started on my science experiment. So cool.
On 2/26/2023 at 5:03 PM, Grahame said:
Would you really want Brent?
FTFY
Does it keep good time?
I was very much thinking of watch building as I put it together. Really like this guy’s product as he is super over the top detailed in his build and even provides special tools to put it together that appear to be custom made as well.
Since it is going to take me six months to build this bench due to lack of room and shitty mitre saw, I might end up buying some of his nerdy accessories and go all out with the vices for the bench.
I watch a lot of stuff that would be considered vice too!
Andrew Klein. He also made a cool app for confirming bandsaw blade tension by tone and a crazy invisible screw thingy.
Fucking piece of shit Bosch mitre saw is giving me some massively out of square end cuts on the legs. If I had the room I would go buy something else and build a mitre saw station instead of this bench. Between the loose lock downs and the worst designed stop block in the world, this thing is about five minutes from going in the lake.
Now going to try to further calibrate this thing as my delve square shows the blade is pretty square to the table and the fence.
Edited by VPI
Put up a French cleat wall to utilize some space behind my saw station. Testing using T-track and dowels for my red tools. Will build something proper soon.
Edited by naamanf
Pretty fancy. What is the conversion cable for on the power cord?
I am thinking the board will end up being about 1/4” after I get all of this twist out.
The Hilti has a 20a plug.
The Hilti has a 20a plug. Fixing that now actually.
Wiring the service for 20amp or just changing the outlet?
I am about beat and beaten down by milling maple that twists back as soon as you cut it to size after running all 87k lbs of it through the jointer and planer. Might take the rest to the lumber guy and pay him to run it through this big machines.
Just the outlet so it fits that plug without an adapter.
Might need to let the wood settle for a week after first surfacing. I had no issues with all the rough lumber I used for mine though.
Just massive tension in the boards. Maybe not dried properly. The board will actually twist mid cut and bind up everything.
Sounds like it wasn’t dried properly.
Today’s maple.
I had 4-5 55gallon bags when I did mine.
That's a lot to twisting. I think some head control is warranted
All the mortises are cut so beginning the tenon process tonight. Also got the back, ugly half, of the bench top glued up except for the Birds Eye maple that will be the visible side the bench top.
Tossed together a holder for the drills with some 3D printed mounts for extra batteries. Might spend the next month just making holders for stuff 😂
Edited by naamanf
My Milwaukee holder needs about 4 more slots now so I am going to have to rebuild.
The new Veritas shoulder plane is going to get some work as the SawStop dado blades did not give me fantastic shoulders on my tenons.
Plane is money for working the tenons.
Yep, just have to figure out how the son of a bitch works. Off to YouTube University.
Got 4 new power supplies for the iVac blast gates and instructions to ground the blast gates. All larger bricks and ac/ac unlike the originals I guess.
