October 8, 200719 yr comment_55672 I know that Audio Aero Prima SE and Opus 21 have it, but are there any others? Few others I've seen has been well over my budget. I can spend up to $3000, though less is always preferred. Report
October 8, 200719 yr comment_55673 The Cambridge Audio 840c has two digital inputs and is well within your budget at $1500 msrp Report
October 8, 200719 yr comment_55675 Most of the 800 series Wadia players had digital inputs as an option so if you're considering used that could be an option. Report
October 8, 200719 yr Author comment_55758 Yeah, used is perfectly fine. I'm hoping to find something with preamp function and remote so that I can use that (preamp function & remote) with speaker setup - I'm too lazy to get up to change the volume. Report
October 8, 200719 yr Author comment_55767 dude, just get the Prima SE DAC If the damn thing would show up again within my budget, I would. I'm just impatient. Report
October 8, 200719 yr Author comment_55770 Damnit, there's MkII on A'Gon right now. Reks - any idea what "optional input" the seller is talking about? (it doesn't have it). Report
October 24, 200719 yr comment_59605 Quad CDP-2 has 6 digital inputs and a pre-amp function and is very well within your spending range. Report
October 24, 200719 yr comment_59635 Quad CDP-2 has 6 digital inputs and a pre-amp function and is very well within your spending range. welcome to head-case Duggeh! indeed! Report
November 8, 200719 yr comment_62905 You might want to check one of the used Cary 306/200 players. You can also find them with volume control. I've owned both it and the AA Prima SE DAC. I slightly prefer the AA. But could (and have) live with either. The Cary will save you a grand or more. Report
November 8, 200719 yr comment_62906 VPI > SINGLEPOWER > KRELL > THIEL just wanted to point out this looks badass. Report
November 8, 200719 yr comment_62911 nice. They make me smile and giggle on a daily basis. I'm sure you can relate. Report
November 9, 200718 yr comment_62983 Have you tried comparing crazy powerful tube monoblocks to your Krells Tom? Report
November 9, 200718 yr comment_62987 Have you tried comparing crazy powerful tube monoblocks to your Krells Tom? I have heard the 2.4s and the 3.7s with the big VTL amps. They sound good, but not better. The owner of the amps was using the 450s and has now sold them because of constant fuse blowing. He is now using the Ayre V-1xe amp with his 3.7s. I have had the following amps in my system with my Thiels. All were nice but the Krell/Thiel combo is something special. Parasound JC-1 monoblocks (owned) Pass 350.5 (audition from dealer) Ayre V-1xe (owned) Krell FPB 650M monoblocks(own now) If, and when, I upgrade amps I would like to audition the Mcintosh 1201 monoblocks and the Krell 750MCX monoblocks, and the new evolution Krells. The big Mac amps are really nice. I have heard them with several systems and other Thiels. But i am pretty happy where I am I now. I have really been on a preamp quest for the last couple years.(six different ones) I am hoping the Singlepower that is being built will be the end of that. I heard the SDS-XLR in my system and it was VERY NICE. So I am having Mikhail build me a souped up Maestro-XLR with a new tubed power supply. Should be here by turkey-day. Report
November 9, 200718 yr comment_62988 just wanted to point out this looks badass. Thanks, it makes wonderful music. My wife and I have been lucky to have a patient local dealer who doesnt mind lots of auditions. the finishing touches have been the Audioquest cables. (Sky ICs and Mont Blanc speaker cable) I cant wait for the SP preamp to get here. If sounds as nice as the one I already heard here I am in luck. Mikhail says it should be even nicer because of the better power supply! Report
November 9, 200718 yr comment_62995 I am hoping the Singlepower that is being built will be the end of that. I heard the SDS-XLR in my system and it was VERY NICE. So I am having Mikhail build me a souped up Maestro-XLR with a new tubed power supply. Should be here by turkey-day.Nice! Can't wait to see the beast. Report
November 9, 200718 yr comment_62996 I have really been on a preamp quest for the last couple years.(six different ones) I am hoping the Singlepower that is being built will be the end of that. I heard the SDS-XLR in my system and it was VERY NICE. So I am having Mikhail build me a souped up Maestro-XLR with a new tubed power supply. Should be here by turkey-day. WHICH turkey day? Report
November 9, 200718 yr comment_63007 WHICH turkey day? Be nice. I have no problem with wait times from Mikhail. My first SDS was 6-7 months. The SDS-XLR was 14 months. This amp should end up taking about 7 months. If longer.....no problem. I have been so happy with the final products, the wait is a non-issue for me. Report
November 9, 200718 yr comment_63019 I have no problem with wait times from Mikhail. My first SDS was 6-7 months. The SDS-XLR was 14 months. This amp should end up taking about 7 months. If longer.....no problem. I have been so happy with the final products, the wait is a non-issue for me.I'm the same way. At least you know that your final product will be in perfect working order and built to your specifications... not all manufacturers are so reliable that way. Report
November 11, 200718 yr comment_63314 VPI > SINGLEPOWER > KRELL > THIELVPI turntable, I presume, into Singlepower as a pre -- what are you using as a phono pre? Report
November 12, 200718 yr comment_63623 I have been using the Ayre K-1XE preamp and have been comparing the Ayre P-5XE and Sim Audio LP5.3 phonostages . I liked the Sim better than the Ayre and sold the Ayre. I will add the upgraded power supply to the Sim when it comes out. This is a great phonostage in my system and I was happy to find one cheaper than the Ayre and one that I also felt was quieter and sonics are better. I got a chance to use the SDS-XLR as a preamp in my system and liked it better than the Ayre K-1Xe so I sold it and have been using a Musical Fidelity until the SP gets here. Its as decked out Maestro XLR with Mikhails new tubed power supply and I am very excited to get this in the system. The system will be as follows when the preamp arrives. ;D VPI SuperScoutmaster w/signature arm Dynavector XX-2 MKII cartridge VPI SDS Sim Audio LP5.3 phonostage Singlepower Maestro-XLR preamp Krell FPB 650M monoblocks Thiel CS7.2 speakers NAD M5 SACD player Audioquest Sky cables everywhere(just got four pr. of these and they are very, very, very, good cables in my system) Audioquest Mont Blanc speaker cables(soon to be Volcanos) Power cords are LAT International AC-2 Audio Magic power purifiers for the digital and the phonstage Billy Bags rack I just got through finishing treating the room and all outlets are dedicated 20 and 30 amp lines in a dedicated room (15X20). Two years of work and changes to get here and this is it for a long time. I am very happy with what I have put together. Mikhail says the Maestro with the new PS is a better preamp than the SDS-XLR. I will post pics and thoughts when everything is together and has a few hours on it. Report
