Recommendations for low power SET amps for Avantgarde Duos
Doesn't it need to be 4-channel for balanced operation?
His amp is not balanced... yet ;)
  • Replies 94
  • Views 18.4k
I'm sure the beta could be reconfigured to use both remote volume and source control. That'd be the route I'd go before adding another preamp to the chain.
I'd definitely like to see how the beta is as a preamp. From what I've read an active preamp will work best with the SET power amps.
It ain't bad. It' ain't bad. ;)
That's freakin' tight (I'm sad I paid for the RK27 :( ), how reliable are they?
Not going balanced with the amp because I don't want to recable my babies.
From what I can read, It will use your RK27 as the volume control.
jb-sauce-mad-scientist after a long day of pondering I think I might go with the 100 stepper, just need to do more research. Because that's how I roll.
Curse you RK27 POT.
And thus the story of how a simple headphone amp becomes an integrated amp followed by its preamp transformation.
I'll throw some Blackgates in this bitch if it becomes my permanent pre.
Curse you RK27 POT.
Why? I hope you didn't pay more than $15 for it? Unless it's the 4-channel version...
You can't fight evolution. :kitty:
Curse you RK27 POT.
You know, I really don't see the curse part here. We may have saved you hundreds if not thousands. The beta should prove to be a GREAT pre, and to add a couple hundred to the final cost will make for a kick ass addition to your speaker setup. You should be thanking us by giving us money and beer. ;)
I think it was $17.
30 rack of PBR en route to you ;)
I will have to pretty up the front panel if it's going to sit in the big boys rack. Good thing I got the ARC imitation case I really like :P
PBR? I am insulted you even mentioned it in the same sentence as 'en route'.
You guys play Ruit with PBR :P
Right?
Right?
Yes, but if it on your tab.. we play with Dead Guy.
Also, its pong. ;)
Damn, reading this thread makes me wish I had gone with something like the remote 100 stepper for my B22. Of course, I didn't even know about it when I placed my order.
I'm going right off on a tangent, but have you considered modding a sonic impact?
They have their limitations, but you'll have your super 300B a lot quicker.
A couple of years back I mucked around with better caps, alps pot, decent case and connectors and a 12v lead sealed battery.
The results were quite astounding for the $$$.
Never
Never
Too cheap for DP. *nods* >:D
Funny how his new name shortens to "DP", which in the porno world stands for "double penetration".
One has to wonder if there's a hidden meaning behind the name change... :P
Staying on topic, another possibility which I just remembered
http://tubelab.com/TubelabSE.htm
Well, it is his real name. :P
I talked to George a few months ago about his amp. Practical stuff. :)
Or the Tubelab Simple SE (ie. not DHT). Also not sure the Tubelab SE board is available which would mean PTP.
Renato
I saw down the bottom of that page they say they used it with some 45s as a driver stage for some 845s or 211s. Sounds like a nice idea.
Hmmmmm.... ;D
Unfortunately he says that the power supply still might not be good enough; I believe he has already made several revisions on it.
Just a small update I will be using the Beta22 as an integrated amp (temporarily). But per Kevin Gilmore's advice, amps like the Beta22, Dynahi etc will make very poor preamps. Too much voltage swing and high noise floor.
Kevin has given me some excellent suggestions for preamp ideas, but I'm still open to more ideas. I might just create a separate thread.
