October 2, 200817 yr I know navships has some single conductor shielded such as these. This is the type of stuff used in alot of '80s and '90s gear, such as my Counterpoint preamp. Might be worth a shot for the input wiring. The shield is usually silver plated copper, so its good, though fine strands. The teflon tape outer wrap can be fun to deal with as well.
October 2, 200817 yr Belden also has shielded wire that is suitable for input/internal use. Hand Made Audio used to carry it although I don't know if they still do.
October 2, 200817 yr Author Belden also has shielded wire that is suitable for input/internal use. Hand Made Audio used to carry it although I don't know if they still do. yup, I have some of that on hand I think this is what AMB uses for his internal wiring, but I could be wrong.
October 6, 200817 yr Author I have a lot of things to post, but first things first.. I have mailed out all the JFETs. The numbers on the tape indicate the Idss that I measured for that device. Perhaps somewhat counter-intuitive, you may want to match the higher Idss value with the higher resistance values.. for example, measure the 4 22 ohm resistors and pair the highest value with the highest value written on the piece of tape for a given group of four. Reason being that forward transfer admittance (Yfs) varies directly with Idss. The inverse of Yfs is the apparent resistance of the JFET and we want to match the drain currents across the four JFETs. To to this, we want to ensure that 1/Yf_i + R_i is close the the same value, for all pairs i.
October 8, 200817 yr Author quiet as a church mouse... notice the creative location of the 2 MOSFETs...
October 8, 200817 yr Author cannot post pics I get: "Your submission could not be processed because a security token was missing. If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error." So, they are here: Picasa Web Albums - M - Pearl edit: notice the stray shielding... haven't figured out what to do with it yet Probably tie it to the earth post and connect that to chassis with a thermistor, Papa-style..
October 8, 200817 yr Wow Marc, that's very cool! Was it as big a PITA working in that small space as it looks like it would be? It's definitely a full case. Houston is going to be a fun meet for yours truly indeed! Oh, and I'll post 'em for ya...
October 8, 200817 yr Author yeah, so this definitely doesn't have enough gain for a 0.24mV cartridge. Whatever Postjack's Bugle is set to would be as low as I would go. I was listening to this with my PPAv2 turned all the way up and the volume was moderate. Unfortunately, I feel like the verdict is still out on whether or not the toroids will cause trouble. I couldn't hear anything last night, but just didn't have enough gain the chain to know 100%. Also, it's really not that bad of a build. Since the boards are mounted to the top and bottom panel and they just slide out, and you can simply remove either one of the side panels and get access to either side...
October 8, 200817 yr If the toroids prove to be a problem let me know. I have some Mu metal from LessEMF and could send you some to see if it would help.
October 8, 200817 yr Author If the toroids prove to be a problem let me know. I have some Mu metal from LessEMF and could send you some to see if it would help. do you think I could take a square of it and just stick it to the toroid mounting dish?
October 8, 200817 yr Don't see why not. You could also call Avel and ask if they would be willing to send you some core banding (they've done this for me in the past) - just be sure to tell them which trafos you're using so they can send the right width band. I've found both radial and longitudinal fields to be problematic, depending on the application.
October 8, 200817 yr Author Don't see why not. You could also call Avel and ask if they would be willing to send you some core banding (they've done this for me in the past) - just be sure to tell them which trafos you're using so they can send the right width band. I've found both radial and longitudinal fields to be problematic, depending on the application. cool, just talked with Avel and they are sending a small roll out. Also, they recommended orienting where the primaries and secondaries exit away from the sensitive circuity, as there is a gap there that can leak. Thanks for the suggestion!
October 27, 200817 yr Just listened to mine Saturday at the Houston meet. Dead quiet, no issues w/the toroids whatsoever. Beautiful build Marc!
October 27, 200817 yr Author Steve: One thing to realize is that you will have to alter the loading once you put the step-up in line. The Consonance seems to have 20dB and 17dB taps, which refer to the amount of gain you can get. Assuming you want to stick to around 100 ohms loading and want to use the 20dB (i.e. the higher gain) taps, then by my calculations you will need a pair of 12.7k resistors. I'll order them this week for you. If you want 150 ohm loading, then you'll need a pair of 22k resistors, ironically the exact same value I purchased for your other cartridge, so I'll have these on hand as well for you.
October 28, 200817 yr Steve: One thing to realize is that you will have to alter the loading once you put the step-up in line. The Consonance seems to have 20dB and 17dB taps, which refer to the amount of gain you can get. Assuming you want to stick to around 100 ohms loading and want to use the 20dB (i.e. the higher gain) taps, then by my calculations you will need a pair of 12.7k resistors. I'll order them this week for you. If you want 150 ohm loading, then you'll need a pair of 22k resistors, ironically the exact same value I purchased for your other cartridge, so I'll have these on hand as well for you. Cool, 100 Ohms loading will be great. This is something I can most likely do, once you map out the right location for me?
October 28, 200817 yr Author Cool, 100 Ohms loading will be great. This is something I can most likely do, once you map out the right location for me? yes, of course... it shouldn't be too hard at all. Also, the banding for the toroids came in today as well. Once I get the mu metal and the new resistors from Canada, I'll send you a package.
October 28, 200817 yr That sounds great. I'll need better instructions on tweaking the speed controller with the piece you gave me as well. My strobe and strobe disc came in yesterday, and both 33 & 45 RPM are a little past the the settings we have now. They're not far off though. I've inquired about a custom dust cover too. We'll see what they have to say. I actually missed the fidgetyness (is that a word?) of a vinyl rig. It suits my personality.
October 28, 200817 yr Author That sounds great. I'll need better instructions on tweaking the speed controller with the piece you gave me as well. My strobe and strobe disc came in yesterday, and both 33 & 45 RPM are a little past the the settings we have now. They're not far off though. I've inquired about a custom dust cover too. We'll see what they have to say. I actually missed the fidgetyness (is that a word?) of a vinyl rig. It suits my personality. sure. I need you to do 2 measurements for me. First, put your meter in DC volts mode. If you get one of those cheap Centex red ones from Harbor Freight, like this: Harbor Freight Tools - Quality Tools at the Lowest Prices then place the knob in the position that points to "20 DCV" and the black probe in the "Common" location and the red probe in the VOmA location in the lower right hand corner. Then place the probes across the motor terminals inside the case. Just follow the wires going from the socket to the PC board and measure at the terminal block. I believe it's marked X3. It doesn't really matter which probe goes where, as we just need an absolute reading. Be careful not to slip and short things out, in other words, don't let the probes touch each other when you're measuring. This measurement needs to be done with the table running for a minute or two so the speed is able to stabilize. Repeat the same measurement for the 45rpm setting. Just to give you an idea, mine measured around 7.5V for 45rpm and 6.0V for 33rpm.
October 28, 200817 yr Anyone have a suggestion for a power supply case for the Pearl, steel would be preferred
October 28, 200817 yr Anyone have a suggestion for a power supply case for the Pearl, steel would be preferred Careful working with steel, it doesn't drill nearly as nicely as that aluminium stuff.
October 28, 200817 yr Careful working with steel, it doesn't drill nearly as nicely as that aluminium stuff. But it does offer better EMI shielding...
October 28, 200817 yr But it does offer better EMI shielding... True, just be prepared for the additional hassle.
