November 1, 200817 yr my GF and I want to build a ferrofluid sculpture. We'll need a pretty damn powerful electromagnet to make it work. The problem is where the hell do we get a powerful but inexpensive electromagnet. I'm hoping that we can build one. Is this something that a total amature can pull off?
November 1, 200817 yr Someplace like this American Science & Surplus : Search Results for "electromagnet"
November 1, 200817 yr Author it's going to have to be way more powerful than one you'd make with a couple of batteries and some magnetic wire. I'll probably have to find a decent volt dc power converter. I might be able to find an old laptop power supply somewhere. I'd like for somebody to tell me what to do so I don't kill myself by making a mistake.
November 3, 200817 yr my GF and I want to build a ferrofluid sculpture. We'll need a pretty damn powerful electromagnet to make it work. The problem is where the hell do we get a powerful but inexpensive electromagnet. I'm hoping that we can build one. Is this something that a total amature can pull off? How inexpensive? Electromagnets on A.P.W. Company
November 3, 200817 yr Author the four inch one is 160 dollars which is way out of what I'm willing to spend. I can build one for for under 25 dollars magnetic wire and all. Thanks for taking the time to reply to my questions though JB.
November 3, 200817 yr the four inch one is 160 dollars which is way out of what I'm willing to spend. I can build one for for under 25 dollars magnetic wire and all. Thanks for taking the time to reply to my questions though JB. Do you need a magnet that will pull 400+ pounds? I saw some that will pull 50lbs that were about $40. I have no idea how much power you need.
November 3, 200817 yr Author [ame=http://www.youtube.com/watch?v=zpBxCnHU8Ao&feature=related]YouTube - Ferrofluid[/ame] 400lb at the contact point just won't be enough I don't believe. magnetic fields dissipate at a rather short distance dramatically. I'll need an an extremely powerful field to be able to lift that much ferrofluid. I just got some money from my school today to experiment with this stuff so I have a little more money than I anticipated. I may be able to buy a serious magnet now. We'll see.
November 3, 200817 yr just a thought, have you considered visiting your local scrap yards and see what magnets they may have on the cheap ? Is there a specific reason you are wanting to use an electromagnet rather than a permanent one ? Looking at "http://scitation.aip.org/phf/gallery/2003-lorenz.jsp" you may be looking for magnets capable of exerting 100G for the ferrofluid to perform. Spoiler warning: the following link shows lab procedure and results (on page 7) found by exposing ferrofluid to different strengths of magnetic fields. http://www.nsec.ohio-state.edu/teacher_workshop/Measuring_Magnetic_Fields.pdf It looks like a fun subject for a project
November 4, 200817 yr what you want is half of the electromagnet pictured here to do the tricks you want. http://gilmore.chem.northwestern.edu/electromagnet.jpg A couple of little details. 4 Tesla inside the gap. Weight of magnet 4300 lbs. Runs on a DC amplifier that is up to 60 volts at 25 amperes. WATER COOLED... I have an old 3000 lb magnet from a VG sector instrument. You can have it for free. You pay for shipping, or your pick it up. Weighs about 2500 lbs. Also needs water cooling.
November 4, 200817 yr Author just a thought, have you considered visiting your local scrap yards and see what magnets they may have on the cheap ? Is there a specific reason you are wanting to use an electromagnet rather than a permanent one ? Looking at "http://scitation.aip.org/phf/gallery/2003-lorenz.jsp" you may be looking for magnets capable of exerting 100G for the ferrofluid to perform. Spoiler warning: the following link shows lab procedure and results (on page 7) found by exposing ferrofluid to different strengths of magnetic fields. http://www.nsec.ohio-state.edu/teacher_workshop/Measuring_Magnetic_Fields.pdf It looks like a fun subject for a project I would lik an electromagnet because you can adjust the field strength with out moving the magnet. I did buy a bunch of the largest neodymium magnets I could find on the web just in case my dreams of an electromagnet don't come true. what you want is half of the electromagnet pictured here to do the tricks you want. http://gilmore.chem.northwestern.edu/electromagnet.jpg A couple of little details. 4 Tesla inside the gap. Weight of magnet 4300 lbs. Runs on a DC amplifier that is up to 60 volts at 25 amperes. WATER COOLED... I have an old 3000 lb magnet from a VG sector instrument. You can have it for free. You pay for shipping, or your pick it up. Weighs about 2500 lbs. Also needs water cooling. That is a generous offer kevin but I just can't afford to even pick it up let alone the massive DC power supply that it must take.
November 4, 200817 yr Author Kevin, you seem like a guy who's seen a lot of tools in your day. Can you identify the type of drill or boring bit that is used in this video--or if it even a bit at all? [ame=http://www.youtube.com/watch?v=me5Zzm2TXh4&feature=related]YouTube - Sachiko Kodama, Yasushi Miyajima "Morpho Towers -- Two Stand[/ame]
November 4, 200817 yr Author damn, that means that she machined them. Fucking engineers! I thought that it may be some type of step drill bit or reamer.
November 4, 200817 yr That may or may not be a custom machined piece. It is certainly not a step drill bit, that would be concentric circles. There is a reamer bit for 1.5 inch or so iron pipe that looks a lot like that. maybe the tip of something like this http://burlington.craigslist.org/tls/902589360.html
November 4, 200817 yr Author fuck yes! thanks again kevin. I found a rusty on with a 2 1/8 inch base for 25 bucks after shipping. I think I can clean it up, take out the bit and wrap some magnet wire around the post and turn the thing into an electromagnet.
November 4, 200817 yr Author don't worry, I drink a can of wd-40 whenever i start a project like this.
November 6, 200817 yr Author plan on an entire can of wd-40 to get that thing clean. Fortunately the picture made it look way rustier than it actually is. A wire brush and lubricant took care of it in only an hour's work. I'm glad somebody is taking an interest in this project besides my girlfriend and I. I'll be sure to keep this thread going as the project moves ahead. I think i'm just going to spend the money on a dc power supply. I really don't have any experience with them and really don't know what to buy. What kind will power an electromagnet?
November 7, 200817 yr Author I bought a mastech 30 volt 50 amp dc power supply. I'm hoping it will be enough to power the magnet. I really couldn't afford anything higher.
November 7, 200817 yr I bought a mastech 30 volt 50 amp dc power supply. I'm hoping it will be enough to power the magnet. I really couldn't afford anything higher. Magnetic art, AND a room heater. That's just smart shopping!
November 7, 200817 yr Author You should really like this video then. [ame=http://www.youtube.com/watch?v=zpBxCnHU8Ao&feature=related]YouTube - Ferrofluid[/ame]
