  • Replies 5.4k
  • Views 1.5m
Yes the 9pin ones I got fit the board ok. I was just wondering if
they were that much inferior.
Les
It really depends on the contacts and their quality.  I suspect they are the same as the teflon units so you should be fine.  That's assuming you are referring to something like this:
http://www.ebay.com/itm/1pc-9pin-Ceramic-Tube-Socket-Machine-Made-Gold-Pin-for-12AX7-EL84-6922-New-/130674502828?pt=Vintage_Electronics_R2&hash=item1e6cceacac
Thanks Guys,
Getting closer to build start.
Les
After looking at quotes for individual boards, I'm beginning to understand the concept of a group buy.  Any chance anyone has a spare amp board or power board they'd be willing to sell?  Pm me if you're willing to sell.
I will be ordering amp boards soon but I'll need to make a new version first.  It needs some changes...
Perhaps add a bit more rail capacitance and holes next to the power supply pads for probe points. I would also space the test point locations out a bit. Yeah there are probably lots of little things here and there.
@spritzer
Have you decided which materials/stats you'll be using for this go-around (FR-4 vs CLTE, .062" vs .125", ENIG vs ENEPIG vs whatever,  2 oz vs 4 oz, # of layers, etc.), or is it that thinking too far in advance?
FR4 and 4oz like the original test boards.  Only two layers on all of our amps...
That's the general idea, fix those small issues such as a proper way to do the test pads, redo the input a bit to suit my particular needs (hello loopouts) and the like.
Had anyone received the chassis from Lil Knight yet?  Can you share a pic or 2?
I guess not?
Guess not.  It will be nice to get an update from Tran.
Just in case.
http://www.tempoelectric.com/azl_sale.htm
this guy has some interesting things (mostly audio related) for sale at fairly low price... definitely worth checking out.
Audio Sale of Items From the Estate of Dr. Arthur Loesch (Part 2)
All prices + shipping from Troy, NY 12180
Updated April 17, 2014 (...)
TEST & OTHER EQUIPMENT:
382
(2) Acopian Regulated Power Supplies
Model B35GT50. Output: 35V @ 50mA
50.00
Each
383
Acopian Dual Output Power Supply
Model 150GT10D-150GT10D. Output 150 VDC x 2 sections @ 0.1A
95.00
384
Altec Lansing Model 536A Power Supply
Output: 20VDC @ 400mA
20.00
385
Cenco DC Amp Meter
0-5 Amp Range
10.00
386
Eico 379 Sine/Square Wave Generator
25.00
387
Eico 1078 Variable AC Supply
With Volt/Amp Meter
55.00
388
(2) GenRad 1201-C Regulated Power Supplies
Includes Manual. 240V-340V Regulated mono power supplies, perfect for building an Arthur Loesch-style phono preamp.
75.00
Each
389
(2) GenRad 1206-B Amplifiers
Includes schematics
20.00
Each
391
GenRad 1217-C Pulse Generator
Includes 1203-A Power Supply and Manual for the 1217-C
40.00
392
GenRad Model 1900 Wave Analyzer
VG+. Presumed to be in good working condition.
60 lbs.
Net Weight,
Pick-up preferred
75.00
393
GenRad Variac
Variable AC Transformer; 0-130V AC Range
75.00
395
Heathkit IM-38 VTVM Vacuum Tube Voltmeter
Includes a Decibel Meter scale
25.00
397
HP 450A Amplifier
45.00
399
Radio Shack 42-3019 Sound Level Meter
Includes soft case and original manual.
10.00
400
Rex 423 4-Range Rheostat
35.00
401
Simpson 2785 Impedance Bridge
Manual included.
35.00
402
Simpson 1699 Milliohm Meter
40.00
403
Simpson Model 885 Sound Level Meter
Includes the calibratiion tool, case, and original manuals.
75.00
404
Staco High Voltage DC Power Supply
40.00
406
Tektronix 575 Transistor Curve Tracer
70 lbs.
Net Weight,
Pick-up preferred
75.00
Edited by jgazal
if you look at the insides of the original, the 22k resistor was
mounted on the backside about .5 inch from the board so that
you could put clipleads on it to adjust.
Kevin/Birgir: do you have a pic to confirm this? Sure it's not the 62K resistor? I suppose either could work, just curious.
Also any chance you know the voltage across R73 in the original? It's the 6.2K resistor at the base of the Darlington in the servo...
We might have measured it at some time but this was 5 years ago.
A few people have asked about the angle brackets.
But I don't have any more.
But the don needs some.
So I will make some more. If anyone is interested let me know.
Probably going to be about $140 for the set of 4 given what the
price was, and what the new hourly rate for the machine is.
Plus shipping.
Will get an exact price on Monday.
These will be for the original boards, not the shrunk one I did for lil-knight.
this is just the angle brackets, and for the boards that are 16 inches long.
lil-knight has a board layout that is 15.65 inches long that fits his chassis.
so the brackets I will be making are for the 16 inch board.
will see about the other version later.
so far 4 sets are spoken for.
I understood the distinction, I was just thinking that if we spun our own T2 boards (the older version) this would allow some flexibility in heatsink/case choices
The current board just about fits a Modushop Pesante Dissipante chassis...
If it's not tied to the original case, I would try to get more of the device case on the flange. IMHO the old design there is a 1/8" or so of the case off the edge.
