Apple Tablet
I could pass on the mathematica but not being able to tex on it is a bit of hold-off for me.
Apparently there is a team working on porting a compiler across to the iphone so there may be some good news in the future considering they are the same os and all.
That would be pretty interesting.
Can't you use the MBP as a server not just for your music, but for all your software, with the iPad used as a VNC? That's what I hope to do with my laptop PC, using Morphsci's recommended Jaadu. But this is all new to me, so maybe I'm missing something?
If something like this worked flawlessly, that would be nice.
  • Replies 3.4k
  • Views 519.4k
  • The Monkey
    The Monkey
    Gang, the iPad Mini was a complete success.  He was so happy.  Thanks for the guidance!
  • Hopstretch
    Hopstretch
    Hurry up with the new improved retina Mini, please Apple. I want to buy a couple before Al sues you out of existence!
  • I will make Colin start camping out at the Apple Store tomorrow to get mine for me.
You should try it out if you have an iPhone/touch. Works well once you get all the desktop servers working. That was not a problem and now I have access to all data and programs and it is essentially platform independent. The upside is I get more done and have had more time to goof off.
Sent from the cloud with TapaTalk
Unfortunately, no iphone/touch. Just got a Mac mini. Now I just need an ipad to control my MBP, Mac mini and Mac Pro in the office. :palm:
Can the server be mobile, as long as it is in range of a network? Can I bring my laptop, which will function as the server, to either my home (wifi) or office (ethernet), and can I still access it by using the client iPad/iTouch/iPhone? And also have access to multiple servers?
Yes.
I was just asking about the touch/iphone as you could then see how Jaadu VNC worked for you. It should work fine with what you say you are running.
Yep, as long as they are running some VNC server software it should work fine.
Where are the damn MBPs?
Sorry Dinny, they've decided to stop making things altogether and just live off their patent portfolio. :)
Yep, getting 3G. Since it can be done monthly that will work out for the times I may need it.
*If* I get one, it will be not be a 3G for the same reason as Dan... can use the Pre as a router or use wifi at home.
