When willl the TooleAudio Prototype balanced max come out
When willl the TooleAudio Prototype balanced max come out? 1 member has voted
  1. 1. When willl the TooleAudio Prototype balanced max come out?
    • Next Week
      0%
      0
    • Next Month
      0%
      0
    • Next Year
      8%
    • WTF is TooleAudio
      58%
    • Next Ice Age
      30%
    • It will melt
      2%
Please sign in or register to vote in this poll.
Oh my, I have to say that faceplate was done nicely. To bad that casing problem was a disaster.
Hopefully it all turns out well! Yays and congrats. :)
2 RCA transformer balanced inputs
2 XLR inputs
2 pairs of binding posts for speaker outs
pair of 3 pin combo jacks for XLR/single ended outputs, 1 single ended output is +/ground, the other is -/ground
1 4pin male output
1 4 position input selector
1 4 position gain selector (1, 2, 3, 4)
1 24 step attenuator, 4 channel dact.
Par Metal case (the cause of 90% of my headaches, their diagram doesn't match the case)
Front Panel Express front panel
Two years, that's simply madness. I assume that's when the M3 was announced?
madness?! this is SPA... well, you get the idea.
Ugh that is exactly where my brain went as well.
Congrats man, I'm glad it finally all worked out. And even with the beta22 out the M3 is no slouch. Technically speaking it has superior specifications in several categories and is way overkill for headphones. Certainly nothing to be scoffed at.
Congrats grawk. :)
How many Watts can it push to the speakers?
I think 7, but I'm not sure. Effectively doubled because it's balanced drive tho
Depends on what you're running for opamps and your power supply. 7 or 8W sounds about right though unless you really tweaked it for speaker use.
So I just spent the last few hours listening to my hhf1s on this amp. Some Diana Krall live followed by Stan Getz - Jazz Samba. Chain was airport express->Luxman D112 integrated amp acting as a dac->rca tape loop out to the balanced m3 (transformer balanced inputs)->hhf1. There was no delay, everything got out of the way, and I was just absorbed by the music. This is such a spectactular combination. I will have to pair it up with the apogee at some point, but wow. Now I just need a comfortable way to sleep with the grados on :)
