digital attenuator
you have to touch together 2 bare wires to make a change in volume
You totally beat me to this one. I think it should also require morse code be used.
  • Replies 415
  • Views 138.5k
  • I've got my controller boards working pretty well now with the digital attenuators.  I like the larger one because it has a really nice feel as you turn the volume knob (...yes I see it ). I went
  • Here's the code.  Just rename the PDF to Zip and expand it into a folder under your .../Documents/Arduino directory. The code works well now, though there are a few things I'd like to keep workin
  • Just wanted to offer a quick update on this...... I couldn't get the "all in one" code from @Kerry to work perfectly with my setup; it always opened up the relays to full volume on power-up, and I cou
I would rather rig up a set of switches to look like Hello Kitty.
... with rotary optical encoder being worked on soon. 4dsystems thing being worked on also.
Excellent! :ian:
max williams should be joining us soon.
His entire thing was 3 pages of code.
And one entire page of the code is to control the
preamp inputs (of which there aren't any in the
volume control only version) and to flip the
MSB and LSB because he got the bits upside down.
How someone else can turn this into 10k+ lines of
code, i just cannot fathom :D
Now as to morse code, we can certainly do that
as long as you have 2 keys. One for clock and the
other for data.
And here I am!
My code is here:
http://nospecifictop...eamp-relay.html
Feel free to use it! I don't claim to be good at coding though, I just learn enough to get what I need done.
Interesting project!
I'm curious why you chose that resistor package? Isn't it hard to get all the values right from the same range and make? I used 1206 sized which also fits MMA0204 (both pretty common) and it was still tough to get the right values all within one range/make! I settled for +/-2.5% of the correct value using 1% metal film resistors:
Also someone mentioned using thick film resistors, wouldn't metal film be a better choice?
Please sign me up for 4 bare boards.
I may or may not be interested in a parts group buy......
Glad you're here Max!
I'm currently looking at thin film resistors in a 1206 package (similar to GoldPoint). The boards will support both 2512 and 1206 sizes. I'm not against metal film either.
I'm actually on vacation now, but will sneak in some geek time and see if I can find the required values :)
I know this is opening up a can of worms, but it might be possible to have a 10K version and one other like a 50K or 100K. Could possibly impact price a bit, but I just wanted to float this out there to get some feedback.
Well, it's just swapping the resistor set for another one. It shouldn't be too hard if we include some preset values on the BOM for people with blank boards. OTOH, for people with assembled boards maybe we should have a single version to keep the price down? What do people think?
PLEASE SEE POST FOR THE LATEST COUNTS.
Another updated list:
Name - Assembled - Bare Boards
grawk - 4 - 0
Driftwood - 4 - 2
luvdunhill - 0 - 2
ujamerstand - 4 - 0
deepak - 2 - 0
cetoole - 0 - 10
manaox2 - 2 - 0
el_doug - 2 - 0
DouglasQuaid - 2 - 2
jgazal - 2 - 0
Lil Knight - 4 - 0
nattonrice - 0 - 4
kevin gilmore - 4 - 0
looser101 - 4 - 0
chinsettawong - 2 - 0
Kerry - 2 - 4
Fing - 4 - 0
blubliss - 4 - 0
n3rdling - 4 - 0
guzziguy - 2 - 0
Pars - 0 - 2
Nebby - 4 - 0
Flyingsparks - 0 - 4
morphsci - 4 - 0
dwhat - 4 - 0
minivan - 2 - 0
Craig Sawyers - 2 - 4
MASantos - 2 - 0
Vortex - 0 - 10
Beefy - 0 - 4
Samuel - 2 - 0
deadlylover - 0 - 6
TOTAL - 72 - 54
Again, if anyone is interested please PM me and I'll add you to the list.
Edited by Kerry
I am ok with what the majority want for assembled boards. Guessing 10k?
Hi everyone,
this is my first post here, though I have been reading Head-Case for quite some time.
Would you consider shipping to France? If yes, I am definitely in for 2 boards assembled, plus relays.
regards,
sam
you could possibly alter the overall impedance with the programming, even make it user selectable.
Make sure you're looking at the latest version from post.
The resistor values were removed from the silk and replaced by references.
Hi everyone,
regards,
sam
I don't want to speak for Kerry, but I would assume that won't be a problem as I'm in Europe as well.
So you will have pads for both? Nice!
That will depend on what people are using for sources and whether they are happing driving 10K. Folks could always use an input buffer though, or buy their own resistors! This calculator is handy for calculating values:
http://www.amb.org/a.../delta1/r2r.cgi
I don't think there will be an issue shipping outside the US.
2050/38.3k (silk has 38.8k)
3650/16.9k (silk has 3050)
This http://www.charcroft.com/site/pdf/data/Charcroft.SCAR.04.09.Is2.pdf could be an interesting resistor option - the SM form of the Vishay/Charcroft Z-foil resistors. Not sure about availability though. Unless anyone knows of an easy source already, I'll make enquiries.
This http://www.charcroft...R.04.09.Is2.pdf could be an interesting resistor option - the SM form of the Vishay/Charcroft Z-foil resistors. Not sure about availability though. Unless anyone knows of an easy source already, I'll make enquiries.
They look amazing but foil resistors are usually really expensive, for example:
http://uk.farnell.com/vishay-foil-resistors-vpg/s102c-20k000-0-01/resistor-metal-foil-0-6w-20k/dp/1692579?Ntt=1692579
ok, 2 final versions.
4 layer version with 99.9% controlled impedances
http://gilmore.chem....nuatorsmt10.pdf
and 6 layer version with 100.0% matched impedances
(2 ground planes added)
http://gilmore.chem....nuatorsmt11.pdf
:D
Perhaps the process of exporting to PDF messes with the clearances? It looks like some clearances are inconsistent, example attached!
post-3041-0-50394900-1303056778_thumb.pn
Well, yes - the Z-foil resistors with leads from (eg) Parts Connexion are $16 to $17 each. So the SM versions are likely to be about that too. But if this attenuator is to match up to the KG Blowtorch, it's gonna need some pretty fancy resistors.
I'll get a quote and see how nuts this option is likely to be.
Conversion to PDF is filled with accuracy errors.
Don't know any other way to show 4 or 6 layers.
If you have a gerber viewer i can supply the real files.
I will check to see what the price difference is for 6 sided boards :D
I'm guessing it won't be more than a couple of bucks if that.
Edited by Kerry
I might have missed it but, does the kgitsojc still have the attenuator onboard or is it now moved off using this one?
