digital attenuator
On the original boards you set one relay at a time and cycle through them. All 16 take less than a quarter second.
Given that, the current on the 12v line shouldn't go much above the 17mA per relay. You should spec for higher by about 4x just for fun. Since they are latching there is only a small quiescent current when they are not switching.
I went back to look at some of the old posts and got nostalgic :)
  • Replies 415
  • Views 136.5k
  • I've got my controller boards working pretty well now with the digital attenuators.  I like the larger one because it has a really nice feel as you turn the volume knob (...yes I see it ). I went
  • Here's the code.  Just rename the PDF to Zip and expand it into a folder under your .../Documents/Arduino directory. The code works well now, though there are a few things I'd like to keep workin
  • Just wanted to offer a quick update on this...... I couldn't get the "all in one" code from @Kerry to work perfectly with my setup; it always opened up the relays to full volume on power-up, and I cou
The files are posted on Kevin's boards site.
I've checked the boards, but wanted to test them so I just had s small run made.
These would be great candidates for assembly as well. It's surprisingly inexpensive.
I'm not sure if I would be up to running the group buy. It was quite a bit of effort. I would happily work with someone though.
Edited by Kerry
A question: since the relays seems to be the largest expense if building a few of these, would it make sense to go for a slightly larger but cheaper relay? For example:
http://se.mouser.com/ProductDetail/KEMET-NEC-TOKIN/EE2-45TNU/?qs=sGAEpiMZZMs3UE%252bXNiFaVLHF5q190qntaE86wsYZ%2ffA%3d
I'm not fully sure this part would work, so apologies if I don't have the spec right. If it does, it would make the board roughly 15 mm longer (bad) but save 25-30 euro on the relay cost (good)...
Right, my mistake! Looked at wrong spec after all.
Kemet single coils (http://se.mouser.com/ProductDetail/KEMET-NEC-TOKIN/UD2-5SNU/?qs=sGAEpiMZZMs3UE%252bXNiFaVF%2fhK9L3NJJAV11VD4%2fXV0g%3d)
were wrong voltage and 3,42 euro a piece compared to Omrons 4,00 euro (and even less difference at volume), so no point really. My apologies, thought I had it right.
Those look like they would work for the V1 PCB (in the proper 12V coil voltage), and are considerably cheaper ($2.31 10 or more, vs. $4.05 25 or more for the Omrons). Contacts are silver alloy with gold alloy overlay. Dimensionally they look very close and should work.
Not sure if the Omrons have any advantages to warrant the price difference? Are Omron more reliable? I know they have been in the relay game for a long time.
I just got these back and will try to build one this weekend :)
I've been using a hot air gun and solder paste. I'm really loving it.
Nice.
Are the attenuator resistors 1206 or 0805, is there a reason for the larger mounting holes at the corners ?
Edited by b0bb
the holes are .125 inch, good for a #6 screw.
I can certainly make the holes smaller for production boards.
the 50 ohm resistors are the bigger ones, those attenuator
resistors are the smaller ones.
remember that the board is 2 x 3 inches, on my screen it shows up at about 2x
other than the 3 caps, there are exactly the same number of components on the back
of the board
Thanks for the clarification, at 2x3inches, it is just slightly larger than the footprint of the RK50, I am thinking of using this attenuator instead of the RK50 on my T2 build.
Quite an achievement cramming 16relays on the board but leaving enough space for hand assembly, the work is much appreciated.
The hole can either be made smaller or moved closer from the edge to allow the standoff the seating space to prevent it from wobbling.
Edited by b0bb
Looks great Kerry!
If there is a GB for this, I like to state my interest for an assembled board option like the last one Kerry ran.
I tested the board out and it works perfectly :D
I needed some time to figure out just how to program it, but I got it working now.
Edited by Kerry
Text didn't show up
the production board will be 2.0 inches wide, reduced from 2.05 inches wide
so that the input/output jacks line up perfectly.
i can also change the hole size to #4 if people want.
I like #4 for this board better, but either would work for me.
#4 works for me. Thanks.
  • 3 months later...
19 hours ago, kevin gilmore said:
those are designed for cs3310 and not for anything else that i'm aware of
Dear kevin,
Thank you!
I'm not electrical guy, just imagine if something can make controller part more simply.
Pal
