June 4, 201115 yr comment_450650 Any recommendations for cheap HDMI to optical converters? Something like this is what I'm looking for, but less than $170 http://www.octavainc.com/HDMI%201x1%20Audio%20Converter.html Basically looking to convert all my single layer SACDs to 24/88 PCM and this box aids in that with the appropriate Oppo player. Report
June 4, 201115 yr comment_450662 I got nothing, but do please report on your results, I would most definitely follow suit. Report
June 4, 201115 yr comment_450671 I was always under the belief that spdif was just one of the things carried by the hdmi cable, and that you could just open up a cable and break it out. Maybe the issue is telling the source that there is something connected at all? This one is a little cheaper: http://www.amazon.com/SPDIF-Component-Ypbpr-Converter-v1-3b/dp/B002SFT3ZI Edited June 4, 201115 yr by dsavitsk Report
June 4, 201115 yr Author comment_450672 I was always under the belief that spdif was just one of the things carried by the hdmi cable, and that you could just open up a cable and break it out. Maybe the issue is telling the source that there is something connected at all? This one is a little cheaper: http://www.amazon.co...b/dp/B002SFT3ZI Thanks! That is considerably cheaper. I'm not sure if it is possible to use a modified HDMI cable off the Oppo. The way these are ripped the digital is never converted to analog. If I do end up doing this, I'll make it a free service for any Casers. Report
June 5, 201115 yr comment_450712 There's this one as well: http://www.dealextreme.com/p/1080p-4-port-hdmi-input-to-hdmi-optical-coaxial-audio-output-converter-100-240v-ac-16553 A few bucks more, but free shipping, and it does optical and coax out. Report
June 5, 201115 yr comment_450765 Did a little looking and SPDIF isn't carried by the HDMI cable. The video and the audio share the same data lines so you need to have some active components to split up the two streams. The amazon one looks to be the least expensive and I think its funny that right in the details it says "Does not support AppleTV" and then there's one reviewer who is complaining that it doesn't work with his AppleTV... Report
June 5, 201115 yr comment_450766 I have a HDFury2 to do this task but I never got it to work with my oppo other than to set the Oppo to 16/44.1 as my GEQ doesn't support anything more than a 24/96. Report
January 28, 201214 yr comment_494065 Resurrecting as I have a similar need, but in reverse. Anyone know of a spdif (toslink or coax) to HDMI converter/adapter? Report
January 28, 201214 yr comment_494074 http://compare.ebay....mTypes&var=sbar http://www.amazon.com/Audio-SPDIF-Toslink-Converter-Adapter/dp/B0015YYOQQ Edited January 28, 201214 yr by swt61 Report
