Best currently available closed headphone?
I'm looking for a pair of closed headphone for myself and a friend, and we'll be using them for classical music, with decent amplification. Not looking for IEM's (I have Ety's).
I've heard various AT closed cans and they just don't work for my ears with this music, so I'm not considering them. I've also heard the Ultrasone ProLine 750, which also didn't work, but I haven't heard the other ultrasones.
That leaves things like the Senn. 280, Beyer 250, Beyer 770 (I suspect I will find it strident), AKG K271 (the graph seems to have basically no bass), AKG K81DJ, and the Ultrasones I haven't heard (HeadRoom rate the Hi-Fi 700 and ProLine 650's highly, and in general I've found my ears to be quite similar to theirs).
Anyone have any suggestions?
I've heard pretty much all the Ultrasones phones and honestly they are all pretty terrible. While I'm not a big fan of the W5000 they really probably are the best currently available closed phone, which just goes to show the sad state of full-sized headphones (especially closed phones).
I use the AKG K271S the most at school and I love them, although it's true that they are bass shy. I got a Zu Mobius cable and it significantly helped in the bass area.
The state of current-production full-sized headphones is indeed pretty pathetic compared to back in the day, and this is even more so for closed headphones. I would have to say that the W5000 is the best closed headphone still in production, even though I can hear certain problems with them.
Why is it so pathetic? Speaker manufacturers have managed to make excellent closed box loudspeakers. I suspect it's more a matter of the fact that with headphones, you can have an 'open baffle' without any negative consequences save isolation, so the manufacturers just can't really be bothered with a top shelf closed headphone. I wonder what that Ultrasone Edition 9 sounds like. The price is now only somewhat ridiculous, unlike the edition 7 which was completely ridiculous. The specs aren't like any of their other cans, so the driver and design is clearly different.
Who has actually heard a 4070?
Well master of all things Stax, Carl, on the other site, HAD one (managed to destroy it somehow, I didn't quite follow it all). He though it sounded a lot better than the W5000.
I'd be surprised if the Edition 9 sounded much different from the rest of their cans, but I guess you never know. I thought I heard it was using the same titanium drivers as the Proline 750/2500 though.
It uses titanium coated mylar, but the impedance, sensitivity and frequency response specs are completely different.
Senn 280 - if you love a nasel midrange and fugly looks, this is the can for you
Beyer 250-80 - reasonably flat frequency response that lacks in highs and have a small closed in soundstage
Beyer 770 - horrible boomy base that overlaps the midrange
AKG K271 - I only heard them with a replacement cable but they were decent because non of the frequencies really stuck out and the sound was a little less closed in then the beyers
You could always take a chance on some closed woodies often found in the forsale forum if your feeling adventurous. :P
Biggie.
Any evidence the 250-250 sounds any better/different to the 250-80?
I'm guessing the guy dismantled it to see how they managed to work with a closed stat, as STAX are extremely sensitive to rear reflections and putting your hands parallel to the backs, even a few feet away from them causes the sound to go a bit weird.
Not sure if any dismantling was even involved. I think he turned them up too loud then found a hole burnt in the diaphram.
It's very difficult to get STAX to arc. He must have been trying to use them as speakers!
The 4070 has a fail safe shut off after a certain volume level, so I have no idea what happened.
I've never heard them before. Audio&Me told me the 250-250 doesn't roll off the high end as much.
Biggie.
Try some Sennheiser HD25-1, one of the best closed headphone still in production.
They actually look good in the specs, though the graph would point to them being very bass heavy. Do they sound that way in real life?
No, i don't think so. They go deep, but i don't think there's too much bass. If you like HD650's tonal accuracy, they are in the same vein but a little less refined. Only problem is the narrowed soundstage but i guess you know the limitation closed supraaural design have.
The hd25 senns that were recommended up are worth a try. Also if you can get your hands on woodified CD3000, they are also worth consideration. The regular CD3000s were too bright for my taste but, maybe a laid back amp may work.
For reference, I have not heard any beyer cans, (the ones Dusty mentioned, I need to get together with him to to this someday) or the koss either.
cheers.
cheers.
Woodied CD3000s with PS1 drivers are spectacular, as well...
the woodied headphile 770s when paired with the right amp sound better than they have any right to.
What are some examples of a good amp to pair with the headphones? :)
Cheers,
Nanoha
So it looks like HD25-1's or 250-250's at this point. It really needs to be something that if any good I can buy two of, so the CD3k idea isn't really much use at this point, even if it is one of the best around.
