balanced headphone protector
This has been needed for a while.
For those with problematic DAC's that put out a bit of DC, and balanced headphone
amplifiers happy to amplify said DC and produce differential DC on the output...
http://gilmore.chem.northwestern.edu/protector.jpg
This is the one case where ti kan's protection board does not work, unless
you want to use 2 of them.
  • Replies 140
  • Views 51.3k
  • I made a SMD version of the Protector PCB for the CFA3, and after testing it this weekend I came up with some ideas for changes #1 - add blocking diodes in series with the power supply inputs. fi
  • Tested the 4.4mm short protection today. The relay disengages if the plug is even .5mm from fully inserted, so i think it will work IMG_3731.mov
  • Headphone protector installed and working. Delay time is 15 seconds, and it disconnects when offset is more than approximately +/-70 mV.
Nice one!
I've been looking around for an external solution, with the thought powering from a wall wart.
Good to use with unfamiliar equipment and of course not having to chuck one of these in every amp would be a bonus.
Do you have a schematic view you could post? I like the approach, comparators instead of Ti's summing amp. I see you used the same 1.6 Hz lowpass filter - I found this a little too sensitive on the epsilon12 and was getting a lot of false cutouts so I ended up lowering the cutoff to about .7 Hz and the gain on the summing amplifier from 10 to 5, which should make it cutout when it sees about 140 mV of DC offset. I'm not sure which did the trick as I did them at the same time.
don't you mean Balanced Headphone "Protector"
oops, so i can't spell. I'll fix it later. Its not like its already etched
We can adjust the comparator window as necessary, as well as the filter.
Ceramic caps up to 4.7uf in that lead spacing i believe.
Putting the thing in a small box with a female and male 4 pin xlr's on tails
plus a cheap wall brick should take care of those pesky massively overpowered
things from my friend in skokie that seems unable to comprehend DC servo's.
so you could have two products....RSA The Protector and The RSA Protector
Might be more symmetrical as RSA The Protector and The Protector from the RSA...
A schematic would be nice also :)
I can't find the schematic. Seriously. I must have left it at home.
Will draw it up again and post soon.
here is a fresh version
http://gilmore.chem....u/protector.pdf
For DC, it triggers on anything over +.5VDC and -.5 VDC
Detect time is 75 milliseconds.
For AC, at 20hz, it triggers on 5 VRMS.
I have a name in mind for this one. Going with the protection theme, how about the 'Gilmore Looking Over Valuable Equipment' or G.L.O.V.E. ?
is there some way to make this uncompatible with Ultrasones?
No, but he could make it incompatible. :P
  • 3 years later...
Old thread, sorry: Kevin, do you have a schematic for the current version of this board?
//UFN
EDIT: Oh, and some BoM-questions:
1) I assume the diodes are just standard 1N4148/1N914?
2) Is the 47uF cap supposed to be ceramic or similar since it hasn't got the same footprint as the electrolytics?
Edited by UFN
high powered DC amplifier. More than capable of frying headphones if you
put dc in the input. Protection circuits always a good idea
Should be plenty of room in the case, I'll need to get one of these built up. :). Might try and squeeze one in my dynalo build too.
Thanks.
Dr. Gilmore. Can I use this on my Balanced Dynahi (last versión)? I suppose that I can used this on the output or it's not necessary?
Edited by jose
See posts 14 and 15. I presume this is used like Amb's in that you put it between the amp output and the phones?
OK, you are right, but if you have a servo on the output ( I don't know if on other Dynahi versión has servo) when you add this board, you are duplicating the protection. Not?
Really, Is it necessary two protecction on the output?
Edited by jose
servo has a limited range and is slow
Thanks Dr. Gilmore.
For broken the servo protection, really you need a offset very high or a very deep signal. Not?
I've got a bunch of BC546B left over from the Dynahi PSU, would that be suitable in this circuit?
