October 25, 20179 yr comment_777121 Added benefit is you can sous vide some eggs while you're listening Report
November 7, 20179 yr comment_777879 I assembled dynalo mini and that340 chips on my board is very hot. Is it normal? Thanks! Report
November 7, 20179 yr comment_777882 I assembled dynalo mini and that340 chips on my board is very hot. Is it normal? Thanks!I don't think so. Double check all components, check for solder bridges, etc. And this is both THAT340 chips are getting hot? How hot? Sent from my iPhone using Tapatalk Report
November 7, 20179 yr comment_777884 40 minutes ago, Pars said: I don't think so. Double check all components, check for solder bridges, etc. And this is both THAT340 chips are getting hot? How hot? Sent from my iPhone using Tapatalk Thanks! 65-70°C on that340, both. But works fine. Now I checked all the components of the strapping - it's all right. But hot. Report
November 7, 20179 yr comment_777885 that is hotter than I expect, what voltage rails and what voltages on the led's Report
November 7, 20179 yr comment_777886 16 minutes ago, kevin gilmore said: that is hotter than I expect, what voltage rails and what voltages on the led's 20v psu , 1.60v on the led's Report
November 7, 20179 yr comment_777889 It might be transistors are heating THAT340 thru copper layers. Are they soldered directy to board, or plugged in sockets? Report
November 7, 20179 yr comment_777891 7 minutes ago, Helium said: It might be transistors are heating THAT340 thru copper layers. Are they soldered directy to board, or plugged in sockets? In sockets Report
November 7, 20179 yr comment_777892 I was thinking the other board. Yes that board gets that hot due to the transistors you can add heatsinks Report
November 7, 20179 yr comment_777900 47 minutes ago, ruslanch said: In sockets Nice!, what heatsink is that on the outputs? I'm so far behind...I still need to build mine. I never found the pot either, is there a source? Report
November 8, 20179 yr comment_777904 I got lucky and was able to make a small order. Minimum order is 1000 pieces. If there was a group buy with a minimum of 20 each we might be able to reach that. A lot of people bought multiple pots so maybe someone is kind enough to sell one to you. otherwise it’s probably better to do the version with the TKD pot, which you can order direct. Or air wire an ALPS pot like someone else here did. Edited November 8, 20179 yr by cspirou Report
November 8, 20179 yr comment_777909 1 hour ago, cspirou said: I got lucky and was able to make a small order. Minimum order is 1000 pieces. If there was a group buy with a minimum of 20 each we might be able to reach that. A lot of people bought multiple pots so maybe someone is kind enough to sell one to you. otherwise it’s probably better to do the version with the TKD pot, which you can order direct. Or air wire an ALPS pot like someone else here did. I'll keep my eye out for an "extra" I already have a pair of the boards. In the mean time, I may just adapt an ALPS like you mention. Report
November 8, 20179 yr comment_777918 8 hours ago, kevin gilmore said: I was thinking the other board. Yes that board gets that hot due to the transistors you can add heatsinks Thank you! I hope that this is indeed so, not my mistake. 8 hours ago, GrindingThud said: Nice!, what heatsink is that on the outputs? I'm so far behind...I still need to build mine. I never found the pot either, is there a source? Thanks a lot! Heatsinks from the nearest radio parts store, noname ). I bought a pot on ebay. I found a seller with a similar product and asked him to order from the manufacturer for me. It took 3 months but I got what I ordered. Report
November 10, 20178 yr comment_778129 Kevin retired. Look in the stax mafia threadSent from my iPhone using Tapatalk Report
November 13, 20178 yr comment_778287 I have a doubt with the LEDs. In the BOM there is one of Vf 2v (Ref. 351-5001). it is right? Report
November 13, 20178 yr comment_778306 Which Dynalo are you talking about Jose? For the regular Dynalo Mk2, in my BOM I show 859-LTL-307ELC for D1, D2 (this is from the thru-hole BOM) For Kerry's Dynalo Mini, I show LTST-C170CKT (4, Red D1, D2) and VLHW4100 (1, White D4) Edited November 13, 20178 yr by Pars Report
November 13, 20178 yr comment_778320 Thanks Pars, I´m doing a regular Dynalo MKII. I guess that I have the last pcb´s (Rev 1.2, blue pcb with through hole resistors and SMD sand). I supposed that I could use the LTL-307 (It´s the "standard" ) but in the BOM that I found there behind pointed to the ref. 351-5001. I don´t know why. So if I can use the LTL-307ELC, better. I have a ton of these leds. Report
November 13, 20178 yr comment_778321 Yeah, I just use whatever I have around for 1.7V red LEDs... FLV110, others through the years. Report
November 16, 20178 yr comment_778469 Guys, I´m working on my Dynalo SS and I finded this: Pad of 24.9K is on the border of track.Yes, I know that is OK and work but there is enough space to move the track and center it with the pad so for future PCB´s I guess that is better change the gerber file ¿no? I have rev 1.2 PCB´s Report
November 25, 20178 yr comment_779254 Hello, everyone. Sharing some phots of my recently built Dynalo mini. I have to thank Kevin, Kerry, and johnwmclean in the first place. My machine is pretty hot compared with others on the forum. The transistor heat sink temperature is 88c with 20mA bias(R14/R29 237ohm), 84C with 17mA bias(R14/R29 220 ohm) The IRM 15-24 power module is 16~18C cooler than the fin. The derating of it starts from 50C and shut down at 70C (ambient temp) This already makes me feel the amp working on the shutdown margin, though the sound is still fine. The forward voltage of D1/D2 LED is 1.794V and the R1/R3(increased to 453 ohm) cross voltage is 1.307V after warmed up which means the constant current 2.8mA. I remember the default constant current is 2.5mA, the Max bias current is 20mA and the normal bias is 15mA? Correct me if I'm wrong. Having no ideas about why my dynalo is hotter than other nearly 25C. Could it just cause by the higher hfe of the PZTA/MMBTA transistors? There are only minimum hfe value shown in the data sheet and no maximum is shown. I'll try 200 ohm and 180 ohm in the next week to see if I can lower the temp to 6xC. Report
November 25, 20178 yr comment_779256 That looks pretty nice, @astro. I don't have an answer for your question, but I have another question for the wider audience: shouldn't the Mean Well PSUs use fuses on input for this circuit? I know these IRM units have some protection built in, but I don't understand how robust it might be. Report
November 25, 20178 yr comment_779259 There's a fuse near the switch. Nice work @astro! Where did you do your casing? Are those temperatures inside the enclosure? Are there holes underneath? Edited November 25, 20178 yr by cspirou Report
November 25, 20178 yr comment_779262 38 minutes ago, cspirou said: There's a fuse near the switch. Nice work @astro! Where did you do your casing? Are those temperatures inside the enclosure? Are there holes underneath? Ye, very nice job! I'm also interested in that case. Report
