Group Buy for KG's Boards (2nd)
Boards arrived here in Florida.
Thank you Tran. I am truly appreciative of your efforts.
  • Replies 290
  • Views 80.9k
  • LK, you shouldn't end up out of pocket for this GB!  If those shipping cost don't start working out to break even for you please let me know and I'll be happy to do what I can to assist with closing t
  • I kind of went overkill on it...   HV 420V 430mA x 2 17-0-17 1.2A   6.3vdc power supply 9v 30VA   6.3vac filaments Using 3 (2x 30VA; 1x50VA)   For the PS board I'm using 2222A instead of 3
Hello Tran
My boards arrived in Oz today.
Many thanks for your effort.
Mine made it through customs and arrived in Boston on Friday. Thanks!
I picked up my boards today from the post office.  Thanks!
My boards arrived today after going from Vietnam to New York and then back to California :)
Thanks a lot to Kevin, Birgir and Thuan!
Got the boards.  Thanks Tran.... Now the Adventure Begins.
Anyone have any quick tips for cleaning all the packing tape glue off the boards? With some work alcohol worked on small patches but some boards are covered, so looking for alternatives...
I was thinking about soaking the entire board in alcohol but I haven't found the time to work on it yet.
I picked my boards up from the post office yesterday.  Thanks Tran!
So i just got done cleaning one board.  I used a shallow tray that was large enough for the board and soaked it in alcohol for a bit.  It works pretty well.
99.9% isopropyl alcohol at Costco.May have to ask for it
Edited by eggil
I received the boards, thanks Tran!
glue, I use WD-40 (or some other type of light oil).  Glue comes right off of many surface types when oil is applied.  Then clean off the oil with alcohol.  I use denatured alcohol, though most people use "rubbing" alcohol.
Had heard of oil before (and WD-40 in particular) for packing tape glue, but was worried about thoroughly cleaning the through-holes after. So no problems on that front?
I have a couple jugs of acetone so will try that out - I mainly use it for cleaning my bike rims, never thought to try it for this.
Should not be a problem when you soak the entire PCB in solvent.  I use WD-40 to remove all sorts of glue-ish stuff, like stickers, residue, and decals.  It makes very short work of that stuff.  You can even use it to remove registration stickers on your license plate.  Glue residue doesn't like oil.
Here's a video I found on youtube just now.
The acetone should work too.
No board, no shipping number...... I hope to receive mine before 2014
Edited by charlo89
Did you try pm'ing Tran first - he is usually pretty good with this stuff.
