February 5, 20215 yr comment_849907 No help with the miter, but I did have some successful ping ponging. First time carving this in real wood. Report
February 5, 20215 yr comment_849908 https://www.woodsmith.com/newsletter/2020/03/26/small-parts-miter-trimmer/?utm_medium=email&_hsmi=85308893&_hsenc=p2ANqtz--f2vX8EEFzKJ-O-xErsfjOUZhmLdpI8Qf6dd7aop7X3K50ld-9oWiQIs3B1OSARYPtjsa9&utm_content=85308893&utm_source=hs_email Small parts miter trimmer jig. Report
February 5, 20215 yr comment_849909 Uhm... Wow! Just now, Voltron said: https://www.woodsmith.com/newsletter/2020/03/26/small-parts-miter-trimmer/?utm_medium=email&_hsmi=85308893&_hsenc=p2ANqtz--f2vX8EEFzKJ-O-xErsfjOUZhmLdpI8Qf6dd7aop7X3K50ld-9oWiQIs3B1OSARYPtjsa9&utm_content=85308893&utm_source=hs_email Small parts miter trimmer jig. I thought the same at first, but think he's talking about a miter along the length of a 1/2" thick piece? Report
February 5, 20215 yr comment_849910 I'm guessing that Steve's reaction wasn't to my link. That is impressive wood smashing Naaman! Report
February 5, 20215 yr comment_849912 I think Doug has the right idea with the sacrificial piece. It will be several vertical mortise joints for 4x4 boxes that are 5” high so several 4” mitre cuts. Report
February 6, 20215 yr comment_849975 Tested the BT hearing protection options, 3M Worktunes, IsoTunes Link, IsoTunes Free and because I wanted to throw them in AirPod Pros. Winner in every category, AirPod Pros. Better sound canceling, comfort and dramatically better sound quality. I guess I should have tried them before buying all these. Report
February 6, 20215 yr comment_849976 6 minutes ago, VPI said: Tested the BT hearing protection options, 3M Worktunes, IsoTunes Link, IsoTunes Free and because I wanted to throw them in AirPod Pros. Winner in every category, AirPod Pros. Better sound canceling, comfort and dramatically better sound quality. I guess I should have tried them before buying all these. Well that saves me some time, thank you! Report
February 6, 20215 yr comment_849980 Can't you do a YouTube video and right off the wrong ones? Report
February 6, 20215 yr comment_849994 “At the direction of my legal counsel, I wrote off all purchased-for-review materials” I like it. Going to try the murder machine again this morning with the sacrificial long board taped on to make some waterfall Cherry, Zebra wood and Walnut desk accessories. Report
February 6, 20215 yr comment_850006 Very nice. I gave up on my project as I cannot get anything remotely uniform with the Mast-R-Fence. Even with the longer board attached still hitting the outfeed fence way too often with the Clear Cut stock guides in place. Report
February 6, 20215 yr comment_850011 Nice Naaman, tis a nice display - senior aviator... I like it with the Calvary crossed swords. Report
February 6, 20215 yr comment_850012 1 hour ago, VPI said: Very nice. I gave up on my project as I cannot get anything remotely uniform with the Mast-R-Fence. Even with the longer board attached still hitting the outfeed fence way too often with the Clear Cut stock guides in place. Have you tried it on the table saw yet? Report
February 6, 20215 yr comment_850017 Do not have one. The worm drive one had some serious wobbles that made it want to walk so I returned it. Report
February 6, 20215 yr comment_850018 6 minutes ago, VPI said: Do not have one. The worm drive one had some serious wobbles that made it want to walk so I returned it. Oh that would explain the desire to smash with the router. Could put the bevels on first then cut the parts down to size on the miter, or use the miter and clamp them in place. Report
February 7, 20215 yr comment_850020 3 hours ago, VPI said: Very nice. I gave up on my project as I cannot get anything remotely uniform with the Mast-R-Fence. Even with the longer board attached still hitting the outfeed fence way too often with the Clear Cut stock guides in place. If you are not spending 95% of your time in the shop getting your tools set up and calibrated, they are not set up and calibrated. Report
February 7, 20215 yr comment_850021 2 minutes ago, dsavitsk said: If you are not spending 95% of your time in the shop getting your tools set up and calibrated, they are not set up and calibrated. I’ve decided to only buy tools that have a factory rep come out and verify setup and calibration. That Felder AS951 is calling to me. Report
February 7, 20215 yr comment_850023 My Hammer A3 is the only tool that I have ever gotten that didn't need calibration. Well, other than the fence. I contemplated taking it partly apart in order to get it into the basement, and the people at Felder said that a) I would probably not be able to get it back together, and b) the cost for them to send someone out to do it for me would approach $2500. If it ever goes out of square, it is going to suck. Edited February 7, 20215 yr by dsavitsk Report
February 7, 20215 yr comment_850025 I think mine is less of a calibration issue and more of a wrong tool for the job. Tried to be cheap and buy one huge 2 1/4” chamfer bit and just use the fence and lift to get the cuts I need. This however leaves a very wide gap between the fence parts and not having the expertise to apply pressure in the right places let it wobble on the bit periodically, causing shit to happen. Report
February 7, 20215 yr comment_850026 Jeff, I think you'd be well served to pick up a jobsite table saw. https://www.toolnut.com/sawstop-jss-120a60-jobsite-pro-table-saw-with-cart-fence.html?gclid=Cj0KCQiAmfmABhCHARIsACwPRABqolUNDMc0HoBLymRZAWMU6BUumCgZwQis_RXQxp2RB5Vm-7ee55IaAqYvEALw_wcB For the type of projects you're building it's really not a tool to do without. 34 minutes ago, dsavitsk said: My Hammer A3 is the only tool that I have ever gotten that didn't need calibration. Well, other than the fence. I contemplated taking it partly apart in order to get it into the basement, and the people at Felder said that a) I would probably not be able to get it back together, and b) the cost for them to send someone out to do it for me would approach $2500. If it ever goes out of square, it is going to suck. How are you liking it Doug? Edited February 7, 20215 yr by swt61 Report
February 7, 20215 yr comment_850029 So far so good. I've only verified that it's working, so I'll need to get back to you after I actually use it. Report
February 7, 20215 yr comment_850030 I’m with Steve, right tool for the job. The ping pong table can do everything a table saw can, but is no replacement for one. Report
February 7, 20215 yr comment_850041 If I was going to get a SawStop it would be one of the bigger ones. I played with the little one and it seemed to be a dramatic drop down from the big ones for not too dramatic a difference in deployed size or cost. Report
February 7, 20215 yr comment_850042 2 hours ago, naamanf said: I’ve decided to only buy tools that have a factory rep come out and verify setup and calibration. That Felder AS951 is calling to me. You're not really going that big, are you? Report
