July 2, 200719 yr comment_36147 I know these are both DIY amps and they all have different sounds depending on how theyre built, but I'm looking for a warmish SS amp with a good amount of bass for my 225s that delivers enough current to open the phones up. I'm trying to spend as little as possible (under $300 but hopefully around $200) and usually DIY beats commercial amps in terms of bang per buck. So which amp should I get? Report
July 2, 200719 yr comment_36148 Of those two, I'd recommend the M3. But I'd never really consider a PPA, but I'm getting an M3. Report
July 2, 200719 yr comment_36149 I would second the M3 as well....although both have their strangths. I think for what you are looking for, the M3 would be the better bet. Report
July 2, 200719 yr comment_36150 M^3 with the opa637 sounded great with my HF-1 and HD580. I like a slightly warmer (fuller) sound too. Report
July 2, 200719 yr comment_36154 I feel like I have to put this out there, if you're going to buy a DIY amp that you didn't build yourself be careful who you buy from. Make sure they have at least some established record of building gear (not necessarily for sale) so that you get something that's going to last. Both amps in question are relatively complicated (although the M? is a bit easier) so be sure to know what you're getting before you agree to buy. Last comment, at $200 you're going to have a tough time finding what you're looking for, especially a good M? which is slightly more expensive to build than a PPA. Feel free to post examples of what you're looking at, between a few of us around here we should be able to offer a fairly complete critique. [edit]Mods/Admin - any idea why the superscript text (the 3) doesn't show up here? It shows up when I type the post but turns into a '?' when I submit the post. Report
July 2, 200719 yr comment_36156 [edit]Mods/Admin - any idea why the superscript text (the 3) doesn't show up here? It shows up when I type the post but turns into a '?' when I submit the post. I've noticed this happening with a lot of different characters. Report
July 2, 200719 yr comment_36158 [edit]Mods/Admin - any idea why the superscript text (the 3) doesn't show up here? It shows up when I type the post but turns into a '?' when I submit the post. I am neither, but I'll answer -- probably because it's not an ASCII character. The database interface probably isn't set to store non-ASCII characters. Just a guess from a nosy bystander. Report
July 2, 200719 yr comment_36160 I am neither, but I'll answer -- probably because it's not an ASCII character. The database interface probably isn't set to store non-ASCII characters. Just a guess from a nosy bystander. This is truly the worst forum on the internet web. Not setup for non-ascii characters? Puh-leeze! My new headphone forum is going to be sooooooo cool. And I make a firm & solemn promise that all of the non-ascii characters will be represented in full force. Report
July 2, 200719 yr comment_36162 This is truly the worst forum on the internet web. Not setup for non-ascii characters? Puh-leeze! My new headphone forum is going to be sooooooo cool. And I make a firm & solemn promise that all of the non-ascii characters will be represented in full force. Quiet you!!! *pokes your belly* Report
July 3, 200719 yr comment_36172 M^3 is warmer. the Dynahi and Beta22 are even warmer. the CK2III is also a very good amp and very easy to build, but yeah the M^3 is warmer. i prefer the CK2III personally. all the FET-output amps i've heard are quite warm, while the BJT-output amps can go either way. Report
July 3, 200719 yr comment_36179 I haven't heard the M3 yet, but I've heard the PPA, warmish and PPA go together like Richard Simmons and a homophobe. Which is to say the PPA is on the cool and somewhat dry and analytical side. I didn't like it with my Grado 225's, it's more for Senn 650's. Report
July 3, 200719 yr comment_36182 I've tried them both, albeit in meet conditions, and I liked M3 better with Grados. PPA's I've tried were bit cold and too edgy for my taste with Grados. Report
July 4, 200719 yr Author comment_36301 Thanks guys for the responses. The wierd thing is that on HF (when I did a search) of the people are saying that the M^3 is colder then the PPA. hmmmm. I feel like I have to put this out there, if you're going to buy a DIY amp that you didn't build yourself be careful who you buy from. Make sure they have at least some established record of building gear (not necessarily for sale) so that you get something that's going to last. Both amps in question are relatively complicated (although the M? is a bit easier) so be sure to know what you're getting before you agree to buy. Last comment, at $200 you're going to have a tough time finding what you're looking for, especially a good M? which is slightly more expensive to build than a PPA. Feel free to post examples of what you're looking at, between a few of us around here we should be able to offer a fairly complete critique. [edit]Mods/Admin - any idea why the superscript text (the 3) doesn't show up here? It shows up when I type the post but turns into a '?' when I submit the post. I'm not sure of who I want to build this amp. I was thinking of Marshall (MisterX) but he charges a little more then others. Do you have any suggestions about who builds amps well? I would do it myself but I can barely build a pimeta correctly. Also maybe more info about my rig will help? iriver ihp140 -> entech number cruncher -> (AMP HERE) -> 225s Report
July 4, 200719 yr Author comment_36302 oh another questions, should I get steps or tread power supply? Is it worth the extra cost? Report
July 4, 200719 yr comment_36303 Ill build it, or you can make cot build it for free, just keep asking him Report
July 4, 200719 yr comment_36312 My vote is neither with the SR225s. I prefer the CK2III with the Grados just because the bass hits so much harder. The catch here is the default output transistors are not exactly the best match for the SR225s (they are on the bright side and that is the last thing those cans need IMO) Report
July 4, 200719 yr comment_36319 So which transistors do you like for the CKKIII, X? I've been thinking of putting one together just for shits and giggles, as it looks like a really good amp for the cost, and not terribly stressful to construct. Report
July 4, 200719 yr comment_36321 I kinda like the 2SC3422/2SA1359 combo because of their bass (they are just a tad on the warm side as well) but the final decision ultimately depends on what kind of sound you want from the amp. Report
July 4, 200719 yr comment_36327 I was thinking of Marshall (MisterX) but he charges a little more then others. Do you have any suggestions about who builds amps well? There is some truth in "you get what you pay for." Report
July 4, 200719 yr Author comment_36341 There is some truth in "you get what you pay for." haha yea, I always liked misterX's workmanship. His XP amp is just awesome. Hmm The CKKIII looks like a good awesome, and it might be cheaper then the others! Thanks MisterX Report
July 4, 200719 yr Author comment_36344 ooh forgot to ask, how warm is the CKKIII? I thought the GLite was pretty dry, one of the reasons that I didnt like the GLite. Report
July 4, 200719 yr comment_36370 i'm using the default transistors, and it's warmer and more natural sounding than the Gilmore V2SE. Report
July 4, 200719 yr Author comment_36372 Hmm, now the CKKIII looks really good. Its definitely cheaper then the other amps listed and if it performs near their level, then it should be a good buy. I'm still wondering how warm it is. Some of the threads on HF say that the CKKIII is pretty analytical. If anyone has impressions on how good the bass and how warm the CKKIII amp is I would appreciate it. Report
July 6, 200719 yr Author comment_36489 Ok, I'm set on the CKKIII mostly because of the price. BTW, how the heck do you edit posts? Report
