I regularly snap bands at my local HD.
I have some crown molding to hang tomorrow, so I bought a few helpers...
  • Replies 2k
  • Views 403.2k
  • Finished the mini bedroom audio rack with Rubio Monocoat and glued it up. Now in place and making me happy. Also shown are the Bendy Head headphone stand from Peter @Iron_Dreamer and coasters from Nat
  • I had previously talked about the bookstore I'm working on. It's almost open for business and I thought I'd show a few of the projects. The shelves are all solid Cyprus. The boardwalk in the back is R
  • Change of Command is this week, which means I get my 4th boss in three years (FML) so I decided I'd fabricobble the command gift.  The outgoing skipper is a Navy diver who has a penchant for clapping
54 minutes ago, VPI said:
I wonder how someone is supposed to pull out 2x4 sfs cedar in this Home Depot. They seem to be guarding it.
That’s one of the things my pocket knife is used for.
Edited by morphsci
There are generally 3 different types of crown molding. 38, 45 and 52 degrees. The Kreg jig has a tool to allow you to check what your particular spring angle is, then you set the jig to that angle. It simply holds the molding at the correct angle as you cut. Without the jig the crown tends to move slightly while cutting. A slight discrepancy can become a big gap pretty quickly. You still turn the crown upside down to cut.
The hangers are new to me. I just discovered them, and since I'll be working alone, they'll make holding the crown in place so much easier!
Interesting. Do not see myself doing crown molding but I love the brands like Kreg that just come up with ways to make things easier.
The issue with getting to the wood is that the wood stacked in front of my wood was not the wood I am looking for. I could have cut into those stacks, but that would not have helped me get to the cedar 2x4s I wanted behind the two stacks.
9 hours ago, VPI said:
If I could figure out how to fit that jointer in my one garage space wood shop I would probably grab it.
I personally wouldn't spend any actual money on an American style jointer. By the time you add a planer, it costs as much as buying a dual jointer/planer, it uses twice the space, and it leaves you with a jointer that's narrower than the planer which is dumb.
The small cheap planers make sense for saving money, or the big standalone makes sense in a commercial shop with multiple people working at once, but otherwise I think they're pretty much always the wrong choice.
I get it. I missed out on this one as I was trying to figure out how big it is, and if the ad was a scam, but she seems to be selling a lot of high end shit.
Went into the City to pick up the Penofin oil for the deck chairs and found I can get clean 2x12 cedar there for less than I was paying for rough cut 2x8 out in the country. Who would have thunk it.
Take 2. I don’t do cutting boards unless they are a gag gift.
Last cut of the entire project and I managed to throw a tire, somehow. I guess I need to buy new tires for the bandsaw now.
Do any of the SawStop crew run the overarm dust collection systems?  Looking for options to limit the massive amounts of dust on every surface of the garage. Probably upgrade from the shitty dust right dust collectors first but started watching videos on the overarm options. I see very little difference in the videos so I am wondering if they even work.
I've working in the shop in Michigan a lot lately and the dust is completely insane without any dust collection beyond the world's loudest and crappiest old shop vac vaguely stuck into the bank of the Sawstop. I have to wear a mask and it would be even worse if there wasn't an air filter. I say this because the same saw in Mayberry with the Supercell creates far, far less dust. It sucks down way more of the dust than I realized.
I looked into the overarm booms and decided it was a lot of cost for not so much difference in most cases. I don't often use the blade guard vacuum attachment but even with the Festool vacuum attached in conjunction with the Supercell on the main port, it doesn't change the dust on the saw top very much. Getting the combo arm that connects both to the Supercell didn't seem like it could be that much better. If you were cutting sheet goods all the time, the big boom arm might be useful, but it wouldn't do much in many cases. I watched all the videos too, and the results didn't seem worthwhile.
Good to know since I was considering trying some sort of over the blade method, stetting with the already included blade guard. Guess I’ll just deal with it for now.
You gents with the CNC routers can make one pretty easy.
Try it with your shop vac to see the results. Maybe it is better than I remember.
I might give it a try.
Cutting boards is done. Not perfect but getting closer on doing good inlays.
Today was finally finish day.
If anyone is looking for a project to perfect their bandsaw skills, this is the one. I am a fucking surgeon on that thing after all these cuts.
Rain delays at Lakeside Woodworking, but the assorted pieces are starting to look more like chairs.
All done and ready to be moved to the deck with the neat razor scooter wheels.
