  • Replies 2k
  • Views 385.7k
  • Finished the mini bedroom audio rack with Rubio Monocoat and glued it up. Now in place and making me happy. Also shown are the Bendy Head headphone stand from Peter @Iron_Dreamer and coasters from Nat
  • I had previously talked about the bookstore I'm working on. It's almost open for business and I thought I'd show a few of the projects. The shelves are all solid Cyprus. The boardwalk in the back is R
  • Change of Command is this week, which means I get my 4th boss in three years (FML) so I decided I'd fabricobble the command gift.  The outgoing skipper is a Navy diver who has a penchant for clapping
Cut out a ton of wasted dust collector hose from the system and added an Oneida Super Dust Deputy to try to make these Rockler PoS DCs work well enough to keep me from having to buy the big Oneida.
This is the Rolls Royce of multi-tools!
I've had 8 different multi-tools over the years, including a very nice Fein (which I keep at Al's shop), and this is by far my favorite. It's not cheap at $225 (still $75 cheaper than the Fein). However, this is the quietest, most well balanced and most vibration free multi-tool I've ever used. A real game changer IMO! The only negative I could find was that it could only use Starlock or Starlock Max blades. But just recently a Norwegian company has made an adapter specifically for this Makita tool, now allowing me to use the inexpensive Ebay blades. I buy 50 blades for approximately $30.
Looks like the Makita of multi tools, but whatever.
I haven't used the Festool multi-tool, which is highly rated. But I'm sure that's at least twice the price of the Makita, if not more. But this Makita is amazing.
I have a Rockwell that I got for $25 on clearance somewhere forever ago. It’s come in real handy when I’ve installed flooring and doing trim work. I’ll have to look at the Ferrari of multi-tools (Milwaukee) if my cheapy breaks. Or I just want to spend more money to help out the economy.
I've used the Rockwell. It was a decent tool. For that matter, the first multi-tool I bought was a $35 Harbor Freight thing, that was way better than any $35 tool had a right to be. But it was noisy and fatiguing after multiple cuts.
Granted, the average user isn't going to put the miles on one that I do.
The only Dewalts I own. I like them.
I actually picked up the baby versions of my drills and impacts last night to get into the tighter places of these rockers as I have three orders for pairs from neighbors that saw mine.
Anyone have any guesses about approaching the domino placement for this 45 degree joint between a splayed leg and the skirt of the table?
In my mind I think I use the tabs on the top (bottom in pic) to get the top domino but not sure what to reference for the lower domino.
Edited by VPI
Look Doug, if the poor bird can't see already, is it really fair to take his tail?
In reality I think I'd glue it as is. Then add a spline/dowel/screw/etc for strength if necessary.
I think you should be able to put reference centerline tick marks top/bottom on both pieces in the position you want them aligned. Could be wrong.
Got a headache planning my approach so I just fucking used nails.
I think Doug is going to need to talk to his Analyst after reading the nail comment.
It's OK Doug. Pretend you never read that.
In my last few projects I've been using this new featherboard system I purchased sometime back.
This think is really good. Very well designed, in that it easily allows stock to move forward, but is almost impossible to move backward. This will definitely negate any kind of kickback. Also, I've had the plastic fingers of standard style featherboards break off and try to imbed themselves in my face, while cutting stock. Not a pleasant experience. These are a sturdy foam, and would be a lot less menacing if they did break loose. The foam feathers are also a replaceable insert, so can be replaced when needed at a minimal cash outlay.
They also make one specific for bandsaw. Al has one, but not sure if he's tried it yet.
I have used it a bit on the bandsaw. It is a little awkward to set correctly but works well resaw cuts
I have a set of those but it seems like I never tried them. Went all Mag Switch recently as adjustables on mitre slots annoy me.
What is the HC approved battery palm router, (not Makita Steve) between Dewalt and Milwaukee, as I want to buy no more batteries and chargers?
I am leaning towards Dewalt as I have too many tools going at once with Milwaukee batteries to share another tool and I like the brakes.
I recently picked up the Milwaukee and so for it works great.
Also using the mag switch feather boards and like them a lot.
All the cool kids use Bow and Makita. So there's that.
Plus, I love how Jeff asks what tool to buy, then narrows it down to one in the next sentence.
You're not going to go wrong with Makita, Milwaukee, DeWalt or Bosch. It's just a matter of what flavor you want. They're all very well made.
I know my scattered audience. Doug will be here shortly to recommend a router plane from some Tibetan guy that only makes them once every seven years
I did almost buy one of the small Makita drills the other day as HD had one on the clearance rack for 70% off but some jag off bought it before I went back to grab it.
I really like the Bosch Cowboy or whatever the fuck corded router I use now, just want to lose the cord.  Maybe I will look at those as well.
My tool shop has 15% off all Milwaukee Friday so that might make a nice choice if I get one with yet another battery.
Edited by VPI
I really like the clamp on the DeWalt palm router. Super easy depth adjustments and bit changes. It also feels really good in the hand. I still use the corded version, that now lives in Al's shop.
That Tibetan guy makes his own "natural" finish. And you don't want to know what's in it!
