Looking to set the record for largest, most expensive reel connected to the tiniest most shitty air compressor.
I know the air compressor is not connected yet, for those people assuming I did it wrong.
  • Replies 2k
  • Views 403.6k
  • Finished the mini bedroom audio rack with Rubio Monocoat and glued it up. Now in place and making me happy. Also shown are the Bendy Head headphone stand from Peter @Iron_Dreamer and coasters from Nat
  • I had previously talked about the bookstore I'm working on. It's almost open for business and I thought I'd show a few of the projects. The shelves are all solid Cyprus. The boardwalk in the back is R
  • Change of Command is this week, which means I get my 4th boss in three years (FML) so I decided I'd fabricobble the command gift.  The outgoing skipper is a Navy diver who has a penchant for clapping
Happy to see that you finally bought yourself a Makita tool. Now you're a playa.
Makita tool has been there for 6 years. Reel is the new thing as I ponder what kind of wild air compressor I need to blow dust off of wood after sanding and CNC’ing.
I think I have mentioned that my brother saved the redwood siding from the mid-century ranch-style house they took down to build their new house. I have been ripping it into various widths and planing a portion of it into interior paneling for my sister in law's tack rooms.
It has been a hassle using a Jet bench top planer that the contractor bought because the smaller Dewalt he borrowed for me was inadequate. The samples I planed in my shop flew through the Hammer and came out beautifully. With the Jet, I'm pushing and pulling and frequently having to flip the stupid switch between two speeds that trips to neutral regularly. The other pain has been the two-sided "helical" blades because the stock ones were practically pot metal and lasted only a couple of hours per side even though redwood is quite soft. We got some Jet carbide replacements that are much better, although I think I have already chipped 5-6 of them and not on nails as far as I can tell.
Still, from green or white or gray painted 70-80 year old boards are looking good and will make for beautiful if rustic paneling. I took the pics of finished boards before I was done yesterday. After adding up the boards in various lengths and in widths from 4" to 11", I realized that I have planed over 1000 linear feet of boards.
Look into California Air for the compressor. They’re very quiet.
They are on the list. Seeing a lot of reviews of the Kobalt quiet compressor as well, which comes with a longer warranty, but may not be built as well to begin with.
Look on the bright side Al. Only 8 or 9 thousand board feet to go.
Went big with the first Ipe project and made some beefy coasters.
That shit gives off some crazy neon greenish yellow sawdust that is kind of creepy.
I have one of these. It's been fine, though quiet is relative. Quiet compared to other air compressors.
So which is the HC approved model?  They have a billion but I am thinking 10-20 gallons with an aluminum tank. Not sure about auto drain.
You want auto drain. It's very easy to forget to regularly drain the system, and water builds up fast. If blowing off dust is your primary usage, the bigger the better. I wouldn't go less than 20 gallons.
Looks like you can add the auto drain to any of them but trying to determine if the air dryer is worthwhile or just do an aftermarket system.
I have a Harbor Freight refrigerant air dryer that I got on a half off sale. Reviews were as good or better than more expensive units. I’ve had it running for over a year now with no issue.
That thing looks too hugeish for the tiny shop. Probably more of a shitty little two stage simple system, since I do not use any tools with the compressor.
Edited by VPI
Yet
Applied Rubio monocoat on Milo's midi-scale equipment rack. That was my first time actually applying this finish, and I found it easy to control do to the viscosity.
Loving both the Mahogany and White Oak with finish applied!
Pics or it didn’t happen…
I imagine Milo will add pics post assembly, loaded with gear.
Also, YouTube build video or didn’t happen…
You've been watching too many arguments from Trump lawyers to Special Master Dearie.
Edited by swt61
Soooo, ended up ignoring all of Steve’s advice and got the 10 gallon California Air Tools without the automatic drain valve.
They only make the Aluminum tank up to 10 gallons and I decided I would live with the tiny tank as I wanted Aluminum and saw some reviews that showed even with continuous blow gun use the tank never really drops below 60psi. Good enough.
Also read about the auto drain and saw it only works when the compressor is running so with the amount of use I would have, I would almost never be running it enough daily to start the auto thingee so would need to drain after each use anyway. Maybe I am reading it wrong but everything I saw said it only works for heavy users.
Loose Dry fit for the Ipe/Sapele cocktail table. Hopefully it will get warm enough at some point in the shop to actually finish it.
On 11/13/2021 at 2:20 PM, Voltron said:
I made lumber! The tree cutter who took down my brother's trees gave me some small Black Acacia logs and I just tried cutting 5/4 slabs out of it. I think I may have discovered the Temple of Gozer the Gozerian in the middle of the log. 😱
I waited a year for this stuff to dry -- apparently almost to the day -- and then jointed and planed it. Looks kinda similar. But now it's flat and smooth.
